Instant Interrupts - Revisited
Results 1 to 40 of 773
    Default Re: Instant Interrupts - Revisited
    As in chat box,
    http://www.picbasic.co.uk/forum/showthread.php?t=19638
    Under 18 bit link.
    Then DOWNLOAD link at very top.
    Links are there.
    Jun 2015
    Thanks - just what I needed! Now the fun starts...
    Jun 2015
    Thanks a lot, Robert. I have installed them and they do exactly what I needed. Thanks Darrel...
    Now I have a question. I added the RTCC interrupt to the DT-INTS-18 coding by adding a define and the "ifdef" statement (using an 18F67K90). I noticed that after I return from my RTCC_INT handler, the RTCCIF flag bit is cleared, apparently by the INT_RETURN macro. Did I leave out more changes to the DT-INTS-18 code, or are all interrupt flags cleared by INT_RETURN? My work around was to create a copy of RTCCIF and poll it instead.
    Clock_Int: 'RTCC ISR
    RTCC_IF = 1 'set the interrupt flag copy because macro INT_RETURN clears RTCCIF
    @ INT_RETURN
    Howard
    As in chat box,
    Under 18 bit link.
    Links are there.
    Howard, you must be setting the reset flag to TRUE by entering YES in the interrupt declaration ResetFlag field like this:
    INT_LIST macro ;IntSource Label Type ResetFlag
    INT_Handler IC3DRIF_INT, _InputSignal, ASM, yes
    INT_CREATE
    EN82fn
    Jan 2008
    Hello
    Where can I find the homepage that were on these two links?
    And where do I download the latest DT_INTS?
    DT_INTS-14 (12F-16F)
    http://darreltaylor.com/DT_INTS-14/intro.html
    DT_INTS-18 (18F)
    http://darreltaylor.com/DT_INTS-18/home.html
    Jul 2008
    TURKIYE-KONYA
    I'm working on a project using 18LF13K22. I need to use RAB Change Interrupt with DT Ints18. I made changes on DT_INTS-18.bas below but i couldn't succeed. Any suggestion?
    #define RABC_INT  INTCON, RABIF   ;-- RAB Port Change
    ifdef RABIF
          INT_Source  INTCON,RABIF, INTCON, RABIE,INTCON2,RABIP
    Thanks..
    Nov 2007
    West Covina, CA
    I had to do the same thing with the PIC18F14K50.
    Our entries look similar except your label is RABC_INT.
    #define RAB_INT   INTCON, RABIF   ;-- RAB Port Change, Added 3/15/14 for PIC18F14K50
    and
      ifdef RABIF    ;----{ RAB Port Change Interrupt }-----------[INTCON, RABIF]--- (Added 3/15/14 for PIC18F14K50
          INT_Source  INTCON,RABIF, INTCON,RABIE, INTCON2,RABIP
    Could it be you're not enabling it with:
    INT_ENABLE  RABC_INT   ; Enable IOC
    Louie
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 21:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 20:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 20:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 06:32
  5. Replies: 1
    Last Post: - 1st November 2006, 03:11
Members who have read this thread : 5
