Instant Interrupts - Revisited - Page 19
Page 19 of 20 FirstFirst ... 9151617181920 LastLast
Results 721 to 760 of 773
  1. #721
    Default Re: Instant Interrupts - Revisited
    That is not enough code to make a whole program.
    Please post your entire code.
    Also include the PIC you are using and the compiler version.
    Jan 2014
    I work with 12F683 and MPASM v5.42.
    1000 x thx
    Code :
    '* Name : Test_SPWM.pbp *
    '* Author : Darrel Taylor *
    '* Date : 9/30/2006 *
    '* Version : 1.0 *
    '* Notes : *
    ; Initialize your hardware first
    DEFINE OSC 20
    CLEAR
    INCLUDE "..\DT_INTS-14.bas" ; Base Interrupt System
    INCLUDE "SPWM_INT.bas" ; Software PWM module
    wsave VAR BYTE $20 SYSTEM
    wsave1 VAR BYTE $A0 SYSTEM
    DEFINE SPWM_FREQ 40 ; SPWM Frequency
    DEFINE SPWM_RES 256 ; SPWM Resolution
    DutyVars VAR BYTE[3] ; DutyCycle Variables
    DutyVar1 VAR DutyVars[0] ; group them in an array for easy access
    DutyVar2 VAR DutyVars[1] ; with FOR loops etc.
    DutyVar3 VAR DutyVars[2]
    SPWM_LIST macro ; Define PIN's to use for SPWM
    SPWM_PIN GPIO, 0, _DutyVar1
    SPWM_PIN GPIO, 1, _DutyVar2
    SPWM_PIN GPIO, 2, _DutyVar3
    SPWM_INIT SPWM_LIST ; Initialize the Pins
    INT_Handler TMR1_INT, SPWMhandler, ASM, yes
    @ INT_ENABLE TMR1_INT ; enable Timer 1 interrupts
    ;_________________________________________________ ____________________________
    RandVar VAR WORD : RandVar = 12345
    LoopCount VAR WORD
    DutyVar1 = 5
    DutyVar2 = 50
    DutyVar3 = 150
    GOTO Main
  3. #723
    How fast is the led blinking?
    Jan 2014
    I apreciate 4-5 blinks/sec
  5. #725
    1) Are you really using a 20 Mhz crystal?
    Not very many people use crystals on an 8-pin PIC.
    2) 40 Hz is really slow for LED's
    Increase the SPWM_FREQ.
    Jan 2014
    I use in config : @_INTRC_OSC_NOCLKOUT . its necessary to use external crystal ?
    I increased the SPWM_FREQ at 219 and leds are relativelly well
  7. #727
    No, it is not necessary to use a crystal.
    But your DEFINE OSC must match your actual oscillator frequency.
    If you have specified the internal oscillator in your configs, then the default is 4Mhz, not 20Mhz.
    And your program is running at 1/5th the speed it is supposed to.
    Jan 2014
    Thank you for your help and patience !
  9. #729
    Jan 2014
    Can somebody help me with this code for 12F683: ?
    I want to blink very quikly a led in background ,independent of my code, random, pause between 1-20 ms. I think that this interval is ok, the best if its possible to set pause limits.
    I want learn about intrerupts but i think that I'm too old ...
    thx in advance !!
  10. #730
    Jan 2014
    ...or , how I can make SPWM without intrerupts...?
  11. #731
    Quote Originally Posted by midali View Post
    I want to blink very quikly a led in background ,independent of my code...I want learn about intrerupts but i think that I'm too old...
    Try this as an intro to Darrel Interrupts and blinking LED:
    http://darreltaylor.com/DT_INTS-14/blinky.html
    It's worth the time to practice. His routines make things so much easier and flexible later on as you add more complexity to your code.
    sougata,
    I'm glad it's working out for you. And yes, it is more managable. Kinda the whole idea behind it.
    Squibcakes,
    No, it doesn't work that way.
    The AD_INT is fired on the completion of an A/D conversion. Not when the value changes.
    So, in your AD_INT handler, you could test to see if the recent A/D reading differs from the previous A/D value. If it does, call a subroutine.
    Then start another conversion before exiting the handler.
    Added: Or like sougata said, have a timer periodicaly start a conversion, then do the same.
    HTH,
    I've been using DT_INTS-14 for a while with various types of interrupts but now I want to implement one for A/D. I've created the dummy interrupt handler, but my question is whether I can read the value of the conversion using PBP's ADCIN or should I grab directly from the registers. If the latter, I could use some help with that.
    My ADC set up is as follows:
    ; PIC12F1840
    DEFINE ADC_BITS      8       ; Set number of bits in result
    DEFINE ADC_SAMPLEUS  5       ; Set sampling time in uS
    DEFINE ADC_CLOCK     3       ; Set clock source (3=rc)
    FVRCON    = 0                ' Fixed Voltage Reference is disabled
    ANSELA    = %00000010        ; Analog on PORTA.1 (AN1) only
    ADCON0    = %00000101        ' ADC (analog-to-digital) is enabled on AN1 (RA1) only
    ADCON1.7  = 0                ; Left-justified results in 8-bits
    INT_LIST  macro    ; IntSource,           Label,  Type, ResetFlag?
            INT_Handler    INT_INT, _Flash_Mode_Btn,   PBP,  yes
            INT_Handler     AD_INT, _ADC_change,       PBP,  yes
        INT_CREATE     ; Creates the interrupt processor
    ' Enable interrupts
    @ INT_ENABLE   INT_INT      ; INT Interrupt
    @ INT_ENABLE   AD_INT       ; A/D Interrupt
    I'm working on implementing Darrel's MIBAM with a trim pot to set the brightness of an LED.
  13. #733
    Darrel came up with a terrific piece of code for my project - have a look at this thread:
    http://www.picbasic.co.uk/forum/showthread.php?t=17299
  14. #734
    I guess you COULD use ADCIN but it kind of defeats the purpose of the interrupt since it is a self timed command.
    When using ADC interrupts you basically set the GO/DONE bit to start the converstion and the interrupt fires when the ADC conversion is done. If you then use ADCIN in the interrupt handler it would perform another, self-timed, conversion which, again, kind of defeats the use of interrupts in the first place.
    The idea is to start the conversion and then either go to sleep or go do something important while the ADC does its job. The interrupt fires when the conversion is complete and you go grab the result by reading ADRESH/ADRESL register pair.
    Thanks Henrik. I've never done A/D conversion before other than through ADCIN but I guessed it wouldn't make sense to use in an interrupt. I'll have to do a search on 'ADRESH' to see how to read the result when I turn the trim pot dial.
  16. #736
    I've set up and ADC interrupt using DT_INST-14 with the following handler code:
    ' [A/D - interrupt handler]
    ADC_change:
      PAUSEUS 50              ' Wait for A/D channel acquisition time
      ADCON0.1 = 1           ' Start conversion
      WHILE ADCON0.1       ' Wait for it to complete
      WEND
      ADCInVal = ADRESH
    @ INT_RETURN
    Is that right? I just need 8-bit ADC resolution (0-255)
  17. #737
    Well, that too defeats the purpose of using the interrupt in the first place since you trig the conversion and sit around waiting for it to complete while IN the interrupt handler. You could just as well have used ADCIN in the ISR.
    One thing we need to get squared away just so we're clear. Your ISR is called ADC_Change and from that I get the feeling that you might think the ADC interrupt fires when the voltage at the input changes - that's not the case. If that was already obvious to you then I appologise, I just wanted to clarify that.
    You start the conversion from within your main code or possibly from another ISR, whatever. Then, instead of sitting around waiting for the duration of the conversion you go do something else or go to sleep to provide a quiet environment for the ADC. The interrupt then fires when the conversion is complete and all you need to do in the ISR is grab the result by reading ADRESH, just like you're doing now.
    As you probably know using, when using DT-ints, PBP needs to do a whole lot of context saving/restoring when entering/exiting the ISR and this takes time. So it might not even be worth it using interrupts as the time taken to enter and exit the ISR could very well be longer than the ADC conversion time. I don't know for sure, and it depends, just saying..... If reading the result is all you're going to do in the ISR then you can probably get away with an ASM type handler still written in PBP which will be much quicker to get in and out of - but that's always "risky" so lets not go there untill you have something that works and does what you need.
    Thanks for your detailed reply, Henrik. In the past, I've just used a GOSUB in the main loop and in the subroutine call ADCIN and compare the current value to a previous value; if it's different, I use that 8-bit value to set a PWM duty cycle to brighten/dim an LED. For this project, I thought it might be more efficient to set up an AD_INT interrupt which I thought would be triggered whenever I turn the dial on the trim pot and hence slightly more efficient. I think I see now that I'm wrong in what I thought would trigger this interrupt and that I guess I have to go back to the GOSUB approach.
  19. #739
    You don't have to go back to the GOSUB aproach but yes, it does look like you've misunderstood how the ADC interrupt works.
    If, for example, you have timer interrupt in your program you could use that to start to AD conversion and then either wait for the conversion or let the ADC trip another interrupt when it's done.
    That makes sense, thanks Henrik. I may tie this to a button so that it's not constantly reading the trim pot - I only want to adjust the LED brightness (PWM duty cycle) infrequently and deliberately.
  21. #741
    OK
    Wow! 7 years & still adding pages! A conversation with Daryl led me here. I want to have an event occur just prior to the end of a PWM period. I was told it had to be done in assembly. My project is based on the PIC16F1828, uses CCP for PWM, DSM (Digital Signal Modulation) to embed HF within a slower PWM clock, and just before the Off/On I need to trigger an event. Got it working thanks to Daryl. Here's what it looks like:
    The code looks like this:
    define OSC 32
    define ADC_BITS 8
    define ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50
    CONFIG1_FOSC_INTOSC
    CONFIG1_MCLRE_OFF
    CONFIG1_CLKOUTEN_OFF
    CONFIG2_PLLEN_ON
    #endconfig
    OSCCON = %11110011
    TRISA = %00111100
    TRISB = %01100000
    TRISC = %11001011
    ANSELA = %00011111
    ANSELB = %01100000
    ANSELC = %11001011
    WPUA = 0
    WPUB = 0
    WPUC = 0
    MDSRC = %10000010 'DSM Activated (.7) on CCP1 (RC5) (<3:0>
    MDCARH = %10000011 'OOK Mode
    MDCARL = %10100000 'Disables Low Carrier Signal; OOK Mode
    MDCON = %11000000 '.7 Enables OOK, .3 Current State (read only)
    CLKRCON = %10110000
    b0 var byte
    b1 var byte
    b1 = 0
    LED1 VAR PORTC.5
    TPS_In var PORTC.7 'AN9
    INT_Handler TMR2_INT, _SetTR4, PBP, yes
    INT_Handler TMR4_INT, _GP, PBP, yes
    'T1CON = %00110001 ; Prescaler=8, TMR1ON
    @ INT_ENABLE TMR2_INT ; enable Timer 2 interrupts
    adcin 9, b0
    hpwm 1, b0, 1056
    PAUSE 1
    GOTO Main
    SetTR4:
    T4CON = T2CON
    PR4 = PR2
    TMR4 = TMR2 - 246
    @ INT_ENABLE TMR4_INT
    @ INT_RETURN
    GP:
    pulsout PORTC.5, 5
    @ INT_DISABLE TMR4_INT
    '@ INT_CLEAR TMR1_INT
    @ INT_RETURN
    All I can say is, I'm so glad I found ME Labs and now this forum. Overwhelming thanks to Charles, Daryl, and many whose work I've gleened from, but have yet to get to know personally.
    Mike
  22. #742
    Mar 2005
    CROATIA
    Hi, is there any known error /workaround for using eeprom "read"(didn't test write) while @ INT_ENABLE TMR1_INT ; Enable Timer 1 Interrupts ?
    I use 16f1827, if I comment INT_enable line, all works great, but if line is enabled, read command return same index instead value
    i experimented with putting int_disable before read int_enable after, putting some pause between disabling/enabling GIE before/after read
    but nothing give me result, only when INT_enable commented, never executed, then works...
  23. #743
    ShoKre, I have never had a problem using the READ and WRITE commands while having the interrupts enabled. I have used it with 18F8722, 18F67k22, 18f46k22, 18f4620, 18f452, 16f1825, 18f1320, 16f88, 12f1840.
    Maybe you should post some code and we here can have a look?
    EN82fn
  24. #744
    Mar 2005
    CROATIA
    i figured out what interfere, i have readcode command in my (basic)ISR, and read in main-loop, after i commented readcode in isr read in main-loop has began to work, so, now i have to find another way
    for reading LED gamma table in isr, or pattern eeprom in main, at least I found what interfere, and the way will come, maybe put read in isr too.... there is more than 500ln of code so it will probably make
    treed dirty with non important/regarded stuff...
    ..it is good to know that there isn't other problems with dt-ints and read.
    ...found interesting or sad errata for 16f1827 http://ww1.microchip.com/downloads/e...Doc/80485G.pdf so ih you bught chip with 1M/100k read write eeprom/flash, you actually get 1k/10k , good to know for save lifespan with fewer writes... i was reading that when couldn't read eeprom...
    (sorry for my bad English if sentences sometime don't have sense
    thanx anyway,
  25. #745
    Nov 2014
    Question Re: Instant Interrupts - Revisited
    Hi all
    Could anybody help me with a problem I'm having with using instant interrupts "Thanks to Darrel for all his work" and the IC3 module of the PIC18F2431
    I can get IC1 (CAP1) to work OK also IC2(CAP2) but when I compile using IC3 (CAP3) I get the following errors.
    Symbol not previously defined (IntFlagReg)
    Symbol not previously defined (IntFlagBit)
    ERROR: (Interrupt Source IntFlagReg,IntFlagBit) not found)
    Following is a snip-it from parts of the program and if I substitute IC3DRIF_INT for IC1IF_INT or IC2QEF and change the CAP3BUF's for 1 or 2 every thing works OK.
    I've tried every thing I can think of but not bright enough to sort this out.
    Using PBX 3.0.4.1
    INT_Handler IC3DRIF_INT
    INT_LIST macro ;IntSource, Label, Type, ResetFlag?
    INT_Handler IC3DRIF_INT, _InputSignal, ASM, yes
    @ INT_Handler IC3DRIF_INT
    InputSignal: 'Input pulse width capture of CAP3
    ReciverOutput.lowbyte = CAP3BUFL
    ReciverOutput.highbyte = CAP3BUFH
    Passthrough = ReciverOutut
    Thanks in advance Geoff
  26. #746
    Totally wild guess, Darrel's routine only has code for #1 and 2. Can't check includes and asm files from my phone, but I'd start there.
    Default Re: pbppi14e.lib errors
    have a look at these threads with dt's guidance I added unsupported interrupts to dt_int18
    http://support.melabs.com/threads/39...with-pic18f248
    http://support.melabs.com/threads/32...TMR4-int-ERROR
  28. #748
    I think the problem is that you're mixing up the names of the interrupt source and the interrupt handler. The interrupt source is called IC3DRIF_INT - you can't call the interrupt handler that as well. This compiles just fine:
    Include "DT_INTS-18.pbp"                'Include the interrupt system files.
    INT_LIST    macro   ;IntSource  Label   Type ResetFlag
        INT_CREATE
    @   INT_ENABLE  IC3DRIF_INT
      Toggle PortB.0
      Pause 500
    Goto Main
    InputSignal:
    @ NOP
    @ INT_RETURN
    Nov 2014
    Hi all
    Thanks Henrik, Richard and Demon for the response with my problem, it is much appreciated.
    It turns out Henrik spotted the problem and it is now sorted. Being lazy I copied and pasted a line for the interrupt enable from the handler line but didn't change from Handler to Enable as Henrik spotted. I then spent a week of evenings trying to find the problem, it is true sometimes you cannot see the wood for the trees.
    Thanks again Geoff.
  30. #750
    Sep 2007
    Waco, Texas
    Default DT's awesome Instant Interrupts and 2 serial ports for 16F1527
    Good Afternoon All-
    I have gone through this thread and apologies if this is not the correct place for me to post this question;
    I have a home project in which I want to use 2 USARTs for my humble home automation idea. I know that DT's interrupts-18 will handle 2 serial ports and have used it - works quite well and again Kudos to DT!
    The chip I want to use is the 16F1527 which looks to be a great choice, capable and cheap!
    I see by DT's site that there is no 2nd serial interrupt as in the -18. In looking through DT_INTS-14 I do not see one either.
    My question, is there a way (surely?) to add this to DT_INTS-14?
    I read a post in where you can add an interrupt on change but I am not experienced enough to see how I might apply this philosophy to the 2nd serial port.
    Any advice would be greatly appreciated.
    BTW, after reading all 19 pages of this thread, my cap will no longer fit on my head - its swollen <grin>........
    Regards to All.
    "If we knew what we were doing, it wouldn't be called research"
    - Albert Einstein
  31. #751
    Default Re: DT's awesome Instant Interrupts and 2 serial ports for 16F1527
    If you have a way of testing the uarts you can try the below, no guarantees
    I think if you define the the interupt and related registers, DT's macro will do the rest
    for you? Edit DT_INTS-14.bas include file
    Existing uart define, from DT_INTS-14.bas version 1.10
     #define TX_INT       PIR1,TXIF, PIE1,TXIE        ;-- USART Transmit
      #define RX_INT       PIR1,RCIF, PIE1,RCIE        ;-- USART Receive
    Try adding this right below the above (info from page 89 pic16f1527 data sheet)
     #define TX1_INT	PIR1,TX1IF, PIE1,TX1IE        ;-- USART1 Transmit
     #define RX1_INT	PIR1,RC1IF, PIE1,RC1IE        ;-- USART1 Receive
     #define TX2_INT	PIR4,TX2IF, PIE4,TX2IE        ;-- USART2 Transmit
     #define RX2_INT	PIR4,RC2IF, PIE4,RC2IE        ;-- USART2 Receive
  32. #752
    I changed the file for you
    '*  Name    : DT_INTS-14.bas                                               *
    '*  Version : 1.10 (8/13/2010)                                             *
    '*  Date    : OCT 13, 2009                                                 *
    '* REV 1.10  Fixes Duplicate label error when Handlers cross page boundary *
    '*           Fixes error with 16F1's and MPLAB 8.53 (high)                 *
    '* REV 1.00  Completely re-written, with optimization and F1 chips in mind *
    '* REV 0.93  Fixed CMIF and EEIF problem with older PIC's                  *
    '*           that have the Flags in PIR1 instead of PIR2                   *
    '* Rev 0.92  solves a "Missed Interrupt" and                               *
    '*           banking switching problem                                     *
    DEFINE  DT_INTS_VERSION  110
    DEFINE  INTHAND  INT_ENTRY
    ;-- Place a copy of these variables in your Main program -------------------
    ;--   The compiler will tell you which lines to un-comment                --
    ;--   Do Not un-comment these lines                                       --
    ;wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    ;wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
    ;wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    ;wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    ;wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
    ssave       VAR BYTE    BANK0   SYSTEM      ' location for STATUS register
    psave       VAR BYTE    BANK0   SYSTEM      ' location for PCLATH register
    fsave       VAR BYTE    BANK0   SYSTEM      ' location for FSR register
    RetAddr     VAR WORD    BANK0
    INT_Bits    VAR BYTE    BANK0
      Serviced  VAR INT_Bits.0
      Vars_Saved VAR INT_Bits.1
    GIE         VAR INTCON.7
    PEIE        VAR INTCON.6
      ifdef PM_USED                             ; verify MPASM is the assembler
        "ERROR: DT_INTS does not support the PM assembler, USE MPASM"
      ifdef ReEnterUsed
        ifdef ReEnterVersion
          if (ReEnterVersion < 34)
            error "Wrong version of ReEnterPBP.bas - Ver 3.4 or higher required
        if (BANK0_END == 0x7F)
          ifdef BANK1_END
            if (BANK1_END == 0xEF)   ; doesn't find 12F683
              variable ACCESSRAM = 1
              variable ACCESSRAM = 0
    #define OrChange Or change to   wsave BYTE $70 SYSTEM
    AddWsave macro B
      if (B == 0)
        if (ACCESSRAM == 1)
          error   "                     Add:"       wsave VAR BYTE $70 SYSTEM
          error   "                     Add:"       wsave VAR BYTE $20 SYSTEM
      if (B == 1)
        if (ACCESSRAM == 1)
          error   "   Add:"       wsave1 VAR BYTE $A0 SYSTEM, OrChange
      if (B == 2)
        if (ACCESSRAM == 1)
          error   "   Add:"       wsave2 VAR BYTE $120 SYSTEM, OrChange
      if (B == 3)
        if (ACCESSRAM == 1)
          error   "   Add:"       wsave3 VAR BYTE $1A0 SYSTEM, OrChange
    #define WsaveE1(B) Chip has RAM in BANK#v(B), but wsave#v(B) was not found.
    ;#define WsaveE2(B) Uncomment wsave#v(B) in the DT_INTS-14.bas file.
    #define WsaveCouldBe This chip has access RAM at $70
    #define WsaveError(B) error  WsaveE1(B)
      ifndef FSR0L     ; not a 16F1
        ifndef wsave
    ;      if (ACCESSRAM == 1)
            error wsave variable not found,
            AddWsave(0)
            variable wsave = 0 ; stop further wsave errors
    ;      else
    ;      endif
          if (wsave == 0x70)
            if (ACCESSRAM == 0)
              error This chip does not have AccessRAM at $70, change to   wsave VAR BYTE $20 SYSTEM
              if (wsave != 0x20)
                error wsave must be either $20 or $70
        ifdef BANK1_START
          ifndef wsave1
            ifdef wsave
              if (wsave != 0x70)
                WsaveError(1)
                AddWsave(1)
              if (ACCESSRAM == 1)
                if (wsave != 0x70)
                  WsaveCouldBe
        ifdef BANK2_START
          ifndef wsave2
            ifdef wsave
              if (wsave != 0x70)
                WsaveError(2)
                AddWsave(2)
        ifdef BANK3_START
          ifndef wsave3
            ifdef wsave
              if (wsave != 0x70)
                WsaveError(3)
                AddWsave(3)
    asm = 0
    Asm = 0
    ASM = 0
    pbp = 1
    Pbp = 1
    PBP = 1
    yes = 1
    Yes = 1
    YES = 1
    no  = 0
    No  = 0
    NO  = 0
      #define ALL_INT      INTCON,GIE, INTCON,GIE      ;-- Global Interrupts   *
      #define T1GATE_INT   PIR1,TMR1GIF, PIE1,TMR1GIE  ;-- Timer1 Gate         *
      #define INT_INT      INTCON,INTF,  INTCON,INTE   ;-- External INT
      #define GPC_INT      INTCON,GPIF,  INTCON,GPIE   ;-- GPIO Int On Change  *
      #define IOC_INT      INTCON,IOCIF, INTCON,IOCIE  ;-- Int On Change       *
      #define RAC_INT      INTCON,RAIF,  INTCON,RAIE   ;-- RA Port Change      *
      #define RBC_INT      INTCON,RBIF,  INTCON,RBIE   ;-- RB Port Change
      #define RABC_INT     INTCON,RABIF, INTCON,RABIE  ;-- RAB Port Change     *
      ifdef T0IF
        #define TMR0_INT   INTCON,T0IF, INTCON,T0IE    ;-- TMR0 Overflow
        ifdef TMR0IF
          #define TMR0_INT INTCON,TMR0IF, INTCON,TMR0IE ;-- TMR0 alternate sym
      ifdef TMR1IF
        #define TMR1_INT   PIR1,TMR1IF, PIE1,TMR1IE    ;-- TMR1 Overflow
        ifdef T1IF
          #define TMR1_INT PIR1,T1IF, PIE1,T1IE        ;-- TMR1 alternate sym
      ifdef TMR2IF
        #define TMR2_INT   PIR1,TMR2IF, PIE1,TMR2IE    ;-- TMR2 - PR2 Match
        #define TMR2_INT   PIR1,T2IF, PIE1,T2IE        ;-- TMR2 - PR2 Match alt
      #define TMR4_INT     PIR3,TMR4IF, PIE3,TMR4IE    ;-- TMR4 - PR4 Match    *
      #define TMR6_INT     PIR3,TMR6IF, PIE3,TMR6IE    ;-- TMR6 - PR6 Match    *
    ;----------------------------------------------------------------------------Modified 11-2-2014
    ;----------------------------------------------------------------------------End addition
      #define PSP_INT      PIR1,PSPIF, PIE1,PSPIE      ;-- Parallel Slave Port
      #define AD_INT       PIR1,ADIF, PIE1,ADIE        ;-- A/D Converter
      ifdef SSPIF
        #define SSP_INT    PIR1,SSPIF, PIE1,SSPIE      ;-- (M)SSP module
        #define BUS_INT    PIR2,BCLIF, PIE2,BCLIE      ;-- Bus Collision
        ifdef SSP1IF
          #define SSP_INT  PIR1,SSP1IF, PIE1,SSP1IE    ;-- (M)SSP module 1     *
          #define SSP1_INT PIR1,SSP1IF, PIE1,SSP1IE    ;                       *
          #define BUS_INT  PIR2,BCL1IF, PIE2,BCL1IE    ;-- Bus Collision 1     *
          #define BUS1_INT PIR2,BCL1IF, PIE2,BCL1IE    ;                       *
        ifdef SSP2IF
          #define SSP2_INT PIR4,SSP2IF, PIE4,SSP2IE    ;-- (M)SSP module 2     *
          #define BUS2_INT PIR4,BCL2IF, PIE4,BCL2IE    ;-- Bus Collision 2     *
      #define CCP1_INT     PIR1,CCP1IF, PIE1,CCP1IE    ;-- CCP1
      #define CCP2_INT     PIR2,CCP2IF, PIE2,CCP2IE    ;-- CCP2
      #define CCP3_INT     PIR3,CCP3IF, PIE3,CCP3IE    ;-- CCP3                *
      #define CCP4_INT     PIR3,CCP4IF, PIE3,CCP4IE    ;-- CCP4                *
      #define CCP5_INT     PIR3,CCP5IF, PIE3,CCP5IE    ;-- CCP5                *
      ifdef CMIF
        ifdef PIR2
          #define CMP_INT  PIR2,CMIF, PIE2,CMIE        ;-- Comparator
          #define CMP_INT  PIR1,CMIF, PIE1,CMIE
        ifdef C1IF
          #define CMP_INT  PIR2,C1IF, PIE2,C1IE        ;-- Comparator 1        *
          #define CMP1_INT PIR2,C1IF, PIE2,C1IE        ;-- Comparator 1        *
        ifdef C2IF
          #define CMP2_INT PIR2,C2IF, PIE2,C2IE        ;-- Comparator 2        *
      ifndef PIR2
        #define EE_INT     PIR1,EEIF, PIE1,EEIE
        #define OSCF_INT   PIR1,OSFIF, PIE1,OSFIE      ;-- OSC Fail if no PIR2 *
        #define LVD_INT    PIR1,LVDIF, PIE1,LVDIE      ;-- Low-Voltage Detect  *
        #define EE_INT     PIR2,EEIF, PIE2,EEIE        ;-- EEPROM/FLASH Write
        #define OSCF_INT   PIR2,OSFIF, PIE2,OSFIE      ;-- OSC Fail            *
        #define LVD_INT    PIR2,LVDIF, PIE2,LVDIE      ;-- Low-Voltage Detect  *
      #define LCD_INT      PIR2,LCDIF, PIE2,LCDIE      ;-- LCD controller      *
      #define CRYPT_INT    PIR1,CRIF, PIE1,CRIE        ;-- KeeLoq Cryptographic*
      #define USB_INT      PIR1,USBIF, PIE1,USBIE      ;-- USB 16C745/765 only *
    ;---[Returns the Address of a Label as a Word]------------------------------
    GetAddress macro Label, Wout
        CHK?RP Wout
        movlw low Label          ; get low byte
        movwf Wout
    ;    movlw High Label         ; get high byte  MPLAB 8.53 killed high
        movlw Label >> 8         ; get high byte
        movwf Wout + 1
    ;---[find correct bank for a BIT variable]----------------------------------
    CHKRP?T  macro reg, bit
        CHK?RP  reg
    ;---[This creates the main Interrupt Service Routine (ISR)]-----------------
    INT_CREATE  macro
      local OverCREATE
        L?GOTO OverCREATE
    INT_ENTRY
        ifndef FSR0L
          if (CODE_SIZE <= 2)
              movwf   wsave       ; 1 copy W to wsave register
              swapf   STATUS,W    ; 2 swap status reg to be saved into W
              clrf    STATUS      ; 3 change to bank 0
              movwf   ssave       ; 4 save status reg to a bank 0 register
              movf    PCLATH,W    ; 5 move PCLATH reg to be saved into W reg
              movwf   psave       ; 6 save PCLATH reg to a bank 0 register
          endIF
          movf      FSR,W         ; 7 move FSR reg to be saved into W reg
          movwf     fsave         ; 8 save FSR reg to a bank 0 register
          banksel 0               ; BANK 0 for F1 chips
        variable  PREV_BANK = 0
        MOVE?CT  0, _Vars_Saved
    List_Start
        ifdef LoopWhenServiced
          MOVE?CT  0, _Serviced   ; indicate nothing has been serviced
        INT_LIST                  ; Expand the users list of interrupt handlers
                                ; INT_LIST macro must be defined in main program
          BIT?GOTO  1, _Serviced, List_Start
        ifdef ReEnterUsed         ; if ReEnterPBP.bas was included
            CHKRP?T  _Vars_Saved
            btfss    _Vars_Saved  ; if PBP system vars have been saved
            goto     INT_EXIT
            L?GOTO   _RestorePBP  ; Restore PBP system Vars
    INT_EXIT
        ifndef FSR0L              ; if chip is not an F1 - restore context
          clrf    STATUS          ; BANK 0
          movf    fsave,W         ; Restore the FSR reg
          movwf   FSR
          movf    psave,w         ; Restore the PCLATH reg
          movwf   PCLATH
          swapf   ssave,w         ; Restore the STATUS reg
          movwf   STATUS
          swapf   wsave,f
          swapf   wsave,w         ; Restore W reg
        retfie                    ; Exit the interrupt routine
      LABEL?L OverCREATE
        bsf      INTCON, 6      ; Enable Peripheral interrupts
        bsf      INTCON, 7      ; Enable Global interrupts
    ;---[Add an Interrupt Source to the user's list of INT Handlers]------------
    #INT_HANDLER  macro  FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
      list
        local AfterSave, AfterUserRoutine, NoInt
          ifdef FlagBit
            CHK?RP   EnableReg
            btfss    EnableReg, EnableBit        ; if the INT is enabled
            goto     NoInt
            CHK?RP   FlagReg
            btfss    FlagReg, FlagBit            ; and the Flag set?
            goto     NoInt
              MOVE?CT  1, _Serviced
            if (Type == PBP)                     ; If INT handler is PBP
              ifdef ReEnterUsed
                btfsc  _Vars_Saved
                goto   AfterSave
                GetAddress  AfterSave, _RetAddr
                L?GOTO  _SavePBP                 ; Save PBP system Vars
                LABEL?L  AfterSave
                error ReEnterPBP must be INCLUDEd to use PBP type interrupts
            GetAddress  AfterUserRoutine, _RetAddr   ; save return address
            L?GOTO   Label                       ; goto the users INT handler
            LABEL?L AfterUserRoutine
            if (Reset == YES)
              CHK?RP   FlagReg
              bcf      FlagReg, FlagBit        ; reset flag (if specified)
            INT_ERROR  "INT_Handler"
    NoInt
          banksel  0
    PREV_BANK = 0
    #define INT_HANDLER(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
      ifndef INT_Handler
    #define INT_Handler(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
    #define int_handler(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
    #define Int_Handler(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
    #define Int_handler(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
    #define int_Handler(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
    ;---[Returns from a "goto" subroutine]--------(RetAddr must be set first)---
    #INT_RETURN  macro
          CHK?RP  _RetAddr
          movf    _RetAddr + 1, W  ; Set PCLATH with top byte of return address
          movwf   PCLATH
          movf    _RetAddr, W      ; Go back to where we were
          movwf   PCL
    #define INT_RETURN  #INT_RETURN
      ifndef INT_Return
    #define INT_Return  #INT_RETURN
    #define int_return  #INT_RETURN
    #define Int_Return  #INT_RETURN
    #define Int_return  #INT_RETURN
    #define int_Return  #INT_RETURN
    ;----[Display not found error]----------------------------------------------
    INT_ERROR macro From
        error From -  Interrupt Flag ( FlagReg,FlagBit ) not found.
    ;---[Enable an interrupt source]--------------------------------------------
      ifndef INT_ENABLECLEARFIRST
        #define INT_ENABLECLEARFIRST 1             ; default to Clear First
      endif          ; use DEFINE INT_ENABLECLEARFIRST 0 to NOT clear First
    #INT_ENABLE  macro  FlagReg, FlagBit, EnableReg, EnableBit
          ifdef FlagBit
            ifdef INT_ENABLECLEARFIRST
              if (INT_ENABLECLEARFIRST == 1)       ; if specified
                MOVE?CT 0, FlagReg, FlagBit        ;   clear the flag first
            MOVE?CT  1, EnableReg, EnableBit       ; enable the INT source
            INT_ERROR  "INT_ENABLE"
    #define INT_ENABLE(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
      ifndef INT_Enable
    #define INT_Enable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define int_enable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_Enable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_enable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define int_Enable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
    ;---[Disable an interrupt source]-------------------------------------------
    #INT_DISABLE  macro  FlagReg, FlagBit, EnableReg, EnableBit
          ifdef FlagBit
            MOVE?CT  0, EnableReg, EnableBit       ; disable the INT source
            INT_ERROR  "INT_DISABLE"
    #define INT_DISABLE(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
      ifndef INT_Disable
    #define INT_Disable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define int_disable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_Disable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_disable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define int_Disable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
    ;---[Clear an interrupt Flag]-----------------------------------------------
    #INT_CLEAR  macro  FlagReg, FlagBit, EnableReg, EnableBit
          ifdef FlagBit
            INT_ERROR "INT_CLEAR"
    #define INT_CLEAR(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
      ifndef INT_Clear
    #define INT_Clear(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
    #define int_clear(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_Clear(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_clear(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
    #define int_Clear(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
    Sep 2007
    Waco, Texas
    Thanks to All-
    It looks as if I may be on my way!
    An AMAZING amount of info here on this board.........
    - Albert Einstein
  34. #754
    Jun 2015
    Where can I download the latest DT-Ints-18 AND ReEnterPBP-18? PIC18F67K90, PBP3 - Thanks - DarrelTaylor.com is all links, no beef.
  35. #755
    As in chat box,
    http://www.picbasic.co.uk/forum/showthread.php?t=19638
    Under 18 bit link.
    Then DOWNLOAD link at very top.
    Links are there.
    Jun 2015
    Thanks - just what I needed! Now the fun starts...
  37. #757
    Jun 2015
    Thanks a lot, Robert. I have installed them and they do exactly what I needed. Thanks Darrel...
    Now I have a question. I added the RTCC interrupt to the DT-INTS-18 coding by adding a define and the "ifdef" statement (using an 18F67K90). I noticed that after I return from my RTCC_INT handler, the RTCCIF flag bit is cleared, apparently by the INT_RETURN macro. Did I leave out more changes to the DT-INTS-18 code, or are all interrupt flags cleared by INT_RETURN? My work around was to create a copy of RTCCIF and poll it instead.
    Clock_Int: 'RTCC ISR
    RTCC_IF = 1 'set the interrupt flag copy because macro INT_RETURN clears RTCCIF
    @ INT_RETURN
    Howard
    As in chat box,
    Under 18 bit link.
    Links are there.
    Howard, you must be setting the reset flag to TRUE by entering YES in the interrupt declaration ResetFlag field like this:
    INT_CREATE
    EN82fn
  39. #759
    Jan 2008
    Hello
    Where can I find the homepage that were on these two links?
    And where do I download the latest DT_INTS?
    DT_INTS-14 (12F-16F)
    http://darreltaylor.com/DT_INTS-14/intro.html
    DT_INTS-18 (18F)
    http://darreltaylor.com/DT_INTS-18/home.html
  40. #760
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 21:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 20:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 20:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 06:32
  5. Replies: 1
    Last Post: - 1st November 2006, 03:11
Members who have read this thread : 5
