EasyHID and USB for Newbies??
Results 1 to 40 of 69
    Ok, I've reread this thread hoping to find a hint why the device is not recognized by windows.
    I had it working using HIDMaker FS, but I'm trying to use EasyHID since the resulting code is MUCH more compact. Here's what I've done so far:
    - generated code with EasyHID, 1 byte to PC, 30 bytes to PIC.
    - modified generated PBP program to include an LCD, that works great.
    - move MCHID.dll to VB6 working folder.
    - compiled the generated VB code using VB6.
    - started up the executable.
    - reset the PIC and that's when the error appears in Windows.
    Can the generated VB6 code work without doing any input or output? I was trying to just get a skeleton VB6 program working first, and then add 1 feature at a time.
    Sure the VB program can work without any in/out.
    Well that's good news.
    One thing that I find strange is that I don't get the same number of generated files between each software. I would have expected that both would have to override the same number of files.
    EasyHID:
    - DESCProject.ASM
    - USBDESC.ASM
    - Project.ASM
    - Project.PBP
    HIDMaker:
    - descript.ASM
    - usb18.ASM
    - usb18.INC
    - usb18mem.ASM
    - usbdesc.ASM
    - Project.BAS
    Is that normal?
    sure it is as log it's two diferent company.
    Let's see a common example.. Darrel's codes have more INCLUDE than mine and all other folks here... is it normal? Sure
    Yup, the includes are normal. I compiled the original generated code from EasyHID and the device is recognized. I'm in the process of trying to get an interrupt working for USBSERVICE. After that I'll add basic I/O between the PC and PIC and then I'll post the results.
    bigbear's Avatar
    bigbear Guest
    I have converted the easy HID VB template to a RealBasic Template, and it was tested by Sean (thanks again) and it works. You can download the template here.
    http://www.members.cox.net/walachcnc/usb.html
  1. Simple USB Comms Problem
    Last Post: - 6th January 2010, 20:17
  2. EasyHID max usb buffer size
    By jizyjuice in forum USB
    Last Post: - 29th November 2007, 05:12
  3. Speed of USB EasyHID and Time problem
    By sjohansson in forum USB
    Last Post: - 18th January 2007, 22:21
  4. USB and EasyHID Problems
    By Rob in forum USB
    Last Post: - 6th January 2007, 18:19
  5. USB PIC without USB Connection
    Last Post: - 26th December 2005, 17:39
