USB and EasyHID Problems
Results 1 to 9 of 9
    Feb 2005
    Essex, UK
    Question USB and EasyHID Problems
    sorry to post a question but I've been trying for hours now and have been reading through other problems trying to find an answer.
    I was very interested in this post:
    http://www.picbasic.co.uk/forum/showthread.php?t=3039
    where sean-h posted this:
    "Using easyhid is not that bad.
    Basic steps are run up the easyhid program and set the basics like Pid/Vid and buffer size for bytes you want to send back and forth from PC to Pic.
    It then by default creates two folders under a top level folder called USBProject
    The first folder is PICBasicPRO
    This contains the basic code you will need for your pic chip and the include files, do not rename or move this directory once it is created, work from this location.
    It will create a example PBP file called USBProject.pbp"
    I have done exactly this and have not moved the files created but when I try to compile the "USBProject" in Microcode Studio, the Results box throws up this error:
    Fatal c:\progra~1\picbas~1.46\pbp\pbpusb18.lib 11 : [302]Unable to Open File '\PBP\PBPPIC18.lib'
    I believe I've had a similar error before but can't remember how I resolved it. Any help is much appreciated
    Rob
    Feb 2005
    Essex, UK
    Default Corrected but further errors
    Ok,
    after another couple of hours last night, I realised that the pbpusb18.lib file includes the file "PBPPIC18.lib" from the default location of Pic Basic Pro i.e. c:\PBP\. I renamed the folder after I installed it but I have never had this problem before (I have never tried to do USB before now though!)
    I have renamed the folder to PBP now which has resolved the first issue but now I have another problem:
    Fatal USBDESC.ASM 5 : [302] unable to open file 'descusbproject.asm'
    I have tried copying these files, which were created by Easy HID, into the PBP folder but it makes no difference.
    Please help me
    Thanks a lot
    Rob
    Feb 2005
    Essex, UK
    Talking Don't worry!
    I have figured out how to do it now (after a fair few painful hours!)
    Mar 2006
    Gothenburgh, Sweden
    I have the same problem. Can you tell me how you did?
    Thx Stefan
    Feb 2005
    Essex, UK
    Quote Originally Posted by sjohansson View Post
    Thx Stefan
    Hi Stefan,
    I can't remember exactly how I did fix it as this was a while ago now but I will have a look when I get in to work tomorrow and then let you know.
    Rob
    Feb 2005
    Essex, UK
    Hi Stefan,
    you need to make sure that you have the Pic Basic Pro folder installed to C:\PBP.
    Next, make sure that you have the files created by Easy HID somewhere close to the root of the drive e.g. C:\Pic Programs\HID Prog 1 or something along those lines. I had my files in a folder on the Desktop which creates a long file path and this was causing my error.
    I think, but can't remember for sure, that you also need to use the MPASM assembler from "View, Compile and Program Options...".
    Let me know if this helps. If not, post exactly what the problem is you are having and I (or someone else) maybe able to help you further.
    Rob
  1. EasyHID and USB for Newbies??
    By Squibcakes in forum USB
    Last Post: - 26th November 2015, 23:41
  2. Simple USB Comms Problem
    By awmt102 in forum mel PIC BASIC Pro
    Last Post: - 6th January 2010, 21:17
  3. EasyHID max usb buffer size
    By jizyjuice in forum USB
    Last Post: - 29th November 2007, 06:12
  4. Speed of USB EasyHID and Time problem
    By sjohansson in forum USB
    Last Post: - 18th January 2007, 23:21
  5. USB PIC without USB Connection
    Last Post: - 26th December 2005, 18:39
