I2C LCD 16x2 Pic16f628 Code
+ Reply to Thread
Results 1 to 8 of 8
    Dec 2025
    Default I2C LCD 16x2 Pic16f628 Code
    I have I2C attached to LCD 16x2 using Pic16f628, internal OSC 4Mhz, DSA on B.1, SLC on B.2, LED on B.5 for Blink at the end, there are 4.7k pull up resistors on the expansion board. I am not getting anything readable. The hardware verified with the Arduino uno "Nice display". I am looking for some simple code that gives something readable to be able to change around to study changes.
    Default Re: I2C LCD 16x2 Pic16f628 Code
    Dec 2025
    I have gone through all those posts that I thought were remotely pertinent. I have tried all the code available in those posts. I have changed every variable possible that I know to try. I don’t understand the details of insertion of the code and variables but somewhat I think the concept. Do I need to learn C first or something else to figure this out? I have not posted any of my code because it has no viability. I have spent countless hours on this. Any information would be much appreciated.
    There a a few variants of backpack lcd's there are pcf8574 ones and pcf8574a ones. they have different i2c address' ranges.
    there are at least two differently wired versions also.
    there are also dfrobot lcds that look similar but are completely different.
    so what settings from arduino were used to get that result ?
    C has nothing to do with it , first step is know what the actual hardware is and its i2c address and how its configured
    so nobody has any idea of what you are trying and can not possibly see where you have gone wrong
    do post your best effort
    Dec 2025
    ''This is as far as I have got. I know it is not much. I am having great dificulty in breaking down
    '' the elements of the I2CWrite. I get a lit up display and that is all. Any help would be greatly ''appreciated.
    '* Pic16f628 LCD I2C 01 260110 *
    '* Display output to LCD of Something Readable *
    '* Display lights Nothing else *
    '* Internal Oscillator *
    cfg = _FOSC_INTOSCCLK ; INTOSC oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN
    ; _FOSC_ERCLK _ER_OSC_CLKOUT _FOSC_ERIO
    ; _ER_OSC_NOCLKOUT _FOSC_INTOSCCLK _INTRC_OSC_CLKOUT
    ; _FOSC_INTOSCIO _INTRC_OSC_NOCLKOUT _FOSC_ECIO
    ; _EXTCLK_OSC _FOSC_HS _HS_OSC _FOSC_XT
    ; _XT_OSC _FOSC_LP _LP_OSC
    cfg&= _WDT_ON ; WDT enabled (MUST USE CAPS)
    cfg&= _WDTE_OFF ; WDT disabled
    cfg&= _PWRTE_ON ; PWRT disabled (MUST USE CAPS)
    cfg&= _MCLRE_OFF ; RA5/MCLR/VPP pin function is digital input, MCLR internally tied to VDD
    cfg&= _LVP_OFF ; RB4/PGM pin has digital I/O function, HV on MCLR must be used for programming
    cfg&= _BOREN_OFF ; BOD Reset disabled
    cfg&= _CPD_OFF ; Data memory code protection off
    cfg&= _BODEN_OFF ; BOD Reset disabled
    cfg&= _CP_OFF ; Code protection off
    __CONFIG cfg
    define I2C_SLOW 1
    DEFINE I2C_INTERNAL 1
    '#define I2C_SLOW 1 ' Not sure if it gets #
    '#DEFINE I2C_INTERNAL 1 ' Not sure if it gets #
    TrisB = 0
    SDA VAR PORTB.1 'SDA Pin#7 on Pic16f628
    SCL VAR PORTB.2 'SCL Pin#8 on Pic16f628
    Five var PORTB.5 'Pin#11 LED Output to indicate program is running
    Tim var byte ' Variable for Time
    Tim =500
    Tim2 var byte ' Variable for Time
    Tim2 =40
    Control Var byte
    Control = %10100000 'Page 157 PBP Control byte would be %10100000 or $A0
    Address var byte 'LCD address:With Arduino I2C Scan Program 39 Dec or 0x27 Hex
    Address = 39 'LCD address:With Arduino I2C Scan Program 39 Dec or 0x27 Hex
    I2CWRITE SDA,SCL,Control,[$00,$01]'clear display
    pause Tim2
    I2CWRITE SDA,SCL,Control,[$00,$0C]'display on/off
    pause Tim2
    ' Don't know where the below $FE,$50,$04,$0A,$15,$0E,$04,$0A,$0A,$00]
    ' are from they were copied from another program.
    I2CWRITE SDA,SCL,Control,[Address,$FE,$50,$04,$0A,$15,$0E,$04,$0A,$0A,$00]' Hello
    pause Tim2
    low Five 'This is to see that the program is running It does Blink
    pause Tim
    high Five
    pause Tim
    low Five
    Goto Main
    there are a number of issues here
    ;cfg = _FOSC_INTOSCCLK ; INTOSC oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN do you really need clockout on RA6
    cfg = _INTRC_OSC_NOCLKOUT        ;INTRC oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN
    ;__CONFIG cfg    ;error not correct or needed
    ;define I2C_SLOW 1     not relevant
    ;DEFINE I2C_INTERNAL 1  incorrect
    TrisB = 0 ;   i2c pins should not be set as outputs
    ;Tim var byte ' Variable for Time   a byte cannot hold such a large number byte range 0 to 255
    Tim var word ' Variable for Time
    Tim =500
    Tim2 =40
    ;Control Var byte ;  the example in manual is for an eeprom , there is no eeprom here
    ;Control = 100000 'Page 157 PBP Control byte would be 100000 or $A0
    ; arduino i2c address is a 7 bit address pbp uses an 8 bit address
    Address = Address <<1 ; convert to 8 bit
    I2CWRITE SDA,SCL,Address ,[$00,$01]'clear display
    pause Tim2
    I2CWRITE SDA,SCL,Address ,[$00,$0C]'display on/off
    pause Tim2
    ' are from they were copied from another program. they come from the Darrel Taylor LCD_PCF8574A.pbp i2c lcd include file and are pointless here
    I2CWRITE SDA,SCL,Address ,[$FE,$50,$04,$0A,$15,$0E,$04,$0A,$0A,$00]' Hello
    pause Tim2
    low Five 'This is to see that the program is running It does Blink at twice the expected rate due to incorrect var type
    pause Tim
    high Five
    pause Tim
    low Five
    Goto Main
    the lcd has not been initialized
    nor have you sent the lcd data in a nibblised format with correct strobe pulses being generated
    its much simpler to use the Darrel Taylor LCD_PCF8574A.pbp i2c lcd include
    there are plenty of example in the links given
    Dec 2025
    Where can the Darrel Taylor LCD_PCF8574A.pbp i2c lcd include be found?
    This is the only forum I have ever been on, I am trying to learn how to navigate around. Thank you very much for pointing out the each of the code errors.
    [open in an incognito window in chrome]
    support.melabs.com/forum/picbasic-pro-compiler-3-0-and-later/pbp3-picbasic-pro-3-0/773-i2c-pcf8574-20x4-lcd
    original ver in post #3
    alternative ver in post #6
  1. Pic16f616 with lcd 16x2 problem
    By juanen19 in forum mel PIC BASIC
    Last Post: - 29th August 2013, 18:20
  2. Lcd 16x2 circuit and sample program...
    By larzazral in forum mel PIC BASIC Pro
    Last Post: - 22nd July 2012, 11:21
  3. Interfacing 16x2 LCD to PIC18F2520
    By spotlite in forum mel PIC BASIC Pro
    Last Post: - 21st January 2012, 08:29
  4. Sample code for I2C text LCD needed
    By Alexey in forum Code Examples
    Last Post: - 15th September 2011, 01:29
  5. swap lcd 16x2 with 20x2
    By kzeoprf in forum General
    Last Post: - 2nd September 2011, 16:25
Members who have read this thread : 8
