Hwpw
+ Reply to Thread
Results 1 to 20 of 20
Thread: Hwpw
    Default Re: Hwpw
    Even the program shows different pulse width.
    what do you mean ,that makes little sense
    Well, I don't know what to say. I get all the same frequency with different pulse width.
    my code works perfectly on the simulator and the actual hardware
    post your code and schematic .
    Aug 2009
    Paso Robles California
    Default Re: Hwpw
    I ran the code that you posted.
    Aug 2009
    Default Re: Hwpw
    Walking and talking on the phone does not work well.
    I ran your program my scope has measure function all 3 channels showed the same frequency. But the duty cycle was the only difference. I used pbp setting ccp1, ccp2, ccp3 and ccp5 port c1, c2, and port b0, b5 there is also no control of individual frequency only duty cycle
    Default Re: Hwpw
    If you don't get three frequencies with 50% duty cycle then you are not using my code ,chip or schema.
    Post your code and schema
    Aug 2009
    Default Re: Hwpw
    I will rerun tomorrow and post scope pictures. Its
    definitely possible. I did something wrong. I am only running at 40 MHz. At this time, I have 16 mhz crystal's coming.
    Default Re: Hwpw
    totally not needed for this simple test, it uses internal osc
    Aug 2009
    Default Re: Hwpw
    RICHARD
    I reloaded your program exactly and it gave me
    12.54khz with a duty of 48.75 PW on channel A1
    8.02khz with a duty of 49.61 on channel C2
    10.02khz with a duty of 50.01 on channel B0
    You were absolutely correct and it works perfectly
    do you have any documentation of the settings and what to change for different freq and duty cycles Im just getting back into this after years of being away
    Aug 2009
    Default Re: Hwpw
    RICHARD I need to change porta4 hwpw to another port i tried ccp3con and ccpr3l changed the ccptmrs0 but nothing works I have something else on a4 on the boards im using
Members who have read this thread : 14
