Infrared HPWM setup
Results 1 to 20 of 20
    Oct 2010
    Default Infrared HPWM setup
    Dear all,
    just a quick question. I didnt want to open a new thread but most of the Infrared threads are closed.
    I would like to set up the PIC18F26k22 in order to use HPWM for the 38khz IR.
    First of all i would like to ask if i can use 64Mhz as the main PIC frequency.
    i tried to use mister e's pic multi-calc and set 64Mhz. The following are the results i got.
    but from the calculations i made:
    (64Mhz / (4*TMR2 prescale value * 38Khz))-1 = PR2
    (64Mhz / (4*1*38Khz)) - 1 = PR2
    (64Mhz / (152000)) - 1 = PR2 <=>
    <=> PR2 =  ------------ -1 <=>
                 152,000
    <=> PR2 = 420
    Also calculating the bits:
                  log(FOSC / FPWM)
     Resolution = ------------------- bits
                      Log(2)
    log(64,000,000 / 38,000) = 3.226
    log(2) = 0.301
    so we have:
    3.226
    ------- = 10.17 ~ 10 bits
    0.301
    and calculating the CCPRL1:
    (PR2 + 1) * TMR2 prescale * 50% Duty Cycle = value for CCPRL1, or
    (420 + 1) * 1 * 0.50 = 421 * 0.50 = 210
    So i set in the code the following:
    TRISC.2 = 0 ' CCP1 (PortC.2 = Output)
    PR2 = 420 ' Set PWM Period for approximately 38KHz
    CCPR1L = 210 ' Set PWM Duty-Cycle to 50%
    T2CON = %00000100 ' Timer2 ON + 1:1 prescale --> i know this might not be right as at 64Mhz there is no 1:1 scale based on mister's e multi-calc.
    CCP1CON = %00001100 ' Mode select = PWM
    could you please help me to clear things up?
    I dont mind using 16Mhz as a base frequency, but still the calculations i get are not match with mister's e multi-calc.
    Thanks for your help in advance.
    2 out of 2 members found this post helpful. Did you find this post helpful? Yes | No
    Default Re: Infrared HPWM setup
    prescaler is 4 , 16 is also a possibility
    (64Mhz / (4*4*38Khz)) - 1 = PR2
    (64Mhz / (152000*4)) - 1 = PR2 <=>
    152,000*4
    <=> PR2 = 104
    (104+ 1) * 4 * 0.50 = 421 * 0.50 = 210
    T2CON = %00000101
    PR2 = 104 ' Set PWM Period for approximately 38KHz
    CCPR1L = 210>>2 ' Set PWM Duty-Cycle to 50%
    note
    PR2 is a 8bit reg it cannot ever be 420 or anything larger than 255
    CCPR1L are the upper 8 bits of the duty cycle word value
    CCP1CON bit 4 and 5 are the lower two bits
    Oct 2010
    Hi Richard,
    thanks for the clarification and answer.
    I found in the manual what you said regarding the Resolution bits.
    the duty cycle is a 10 bit value at best for that chip, not all frequencies can have the full 10bit range available
    it totally depends on choices made with regard to prescaler and period.
    no matter what bit resolution is possible the CPRxL value is the upper 8 bits of the duty cycle word valueCCP1CON bit 4 and 5 are the lower two bits
    Oct 2010
    i've also noticed you've shifted 2 bits on the right the CCPR1L
    So the CCPR1L value will be 52.
    (11010010) 210>>2 = 00110100 = 52
    why have we shifted?
    (011010010) 210>>2 = 00110100 = 52 ;high 8bits
    (011010010) 210 & 3 = 00000010 = 2 ;low 2 bits
    00000010<<4 = 00100000
    CCP1CON = 00100000 |12 to set low bits in pwmmode
    C version from microchip
    void PWM1_LoadDutyValue(uint16_t dutyValue)
       // Writing to 8 MSBs of pwm duty cycle in CCPRL register
        CCPR1L = ((dutyValue & 0x03FC)>>2);
       // Writing to 2 LSBs of pwm duty cycle in CCPCON register
        CCP1CON = ((uint8_t)(CCP1CON & 0xCF) | ((dutyValue & 0x0003)<<4));
    Oct 2010
    thanks Richard. now is clear.
    i will get back once i have a working code and establish an IR communication.
    Oct 2010
    with the following configuration i got this on the scope. So i guess we are in a good path.
    To mention that the main OSC is at 64Mhz using HPWM on the PIC18f26K22 on portc.2
    CCPR1L = 52          ' Set PWM Duty-Cycle to 50% (011010010) 210>>2 = 00110100 = 52
    T2CON = %00000101    ' Timer2 ON + 4 prescale
    CCP1CON = %00001100  ' Mode select %00001100 = PWM
    Name:  38khz frequency.jpg
    all thanks to Richard.
    now im going on the next step.
    very good.
    you could set the lower two bits of the Duty-Cycle word [CCP1CON bits 4:5] to get the duty cycle
    even closer to exactly 50%, if you wanted to
    CCP1CON = %00101100
    Oct 2010
    I will do that thanks a lot.
    Yesterday i tried till late at night to set a code for the TX and RX, a very simple one but didnt work.
    tx:
    '*----------------------- | EUART 1 Configuration  | --------------------------|
            DEFINE HSER_SPBRG 130 ' 9600 Baud @ 64MHz, -0.02%
            SPBRGH = 6
    ID	    VAR BYTE
    button1 var porta.0  ' we configure this button 1 at porta.0
    button2 var porta.1  ' we configure this button 2 at porta.1
    RED     var latc.3   ' a RED LED indicates the PIC working condition
    Blue    var lata.2   ' a Blue LED indicates the push button everytime
    high red
    low red
    pause 50
    high red
    BEGIN:
       ID	= 10
    if button1 = 0 then
        gosub button1_pressed
    low blue
    	GOTO BEGIN
    button1_pressed:
    high blue
    	    hSEROUT [ID]  ' we send at portc.6 which is connected the IR module at the 74LS00 in pin No2
    	    PAUSE 100
    button2_pressed:
    high blue
    	    hSEROUT [ID]  ' we send at portc.6 which is connected the IR module at the 74LS00 in pin No3
    	    PAUSE 100
    RX:
    '*----------------------- | EUART 2 Configuration  | --------------------------|
            DEFINE HSER2_RCSTA 90h ' Enable serial port & continuous receive
            DEFINE HSER2_TXSTA 24h ' Enable transmit, BRGH = 1
            DEFINE HSER2_CLROERR 1 ' Clear overflow automatically
            DEFINE HSER2_SPBRG 130 ' 9600 Baud @ 64MHz, -0.02%
            SPBRGH2 = 6
            BAUDCON2.3 = 1         ' Enable 16 bit baudrate generator
    ID	    con 10
    Green   var lata.1   ' a Green LED which indicates the 1st output of the IR input code
    Blue    var lata.0   ' a Blue LED indicates the 2nd output of the IR input code
    Red     var lata.2   ' a Red LED indicates the PIC working condition
    '                 RED LED indicates that PIC is up and running                 |
    high red
    low red
    Begin:
    hSERin2 [wait(ID)]
    high red
    'pause 100
       gosub FIRST_SIGNAL
    '   endif
    FIRST_SIGNAL:
    high green
    low green
    any Alias that refers to a LATx reg cannot be safely used with HIGH,LOW,TOGGLE or any other pbp high level command
    the sort of bugs it can introduce vary from chip to chip and can be difficult to understand , don't do it
    Blue var lata.2 '; an alias to a lata
    high blue ; will not work safely
    blue = 1 ; will work
    low blue ; will not work safely
    blue = 0 ; will work
    toggle blue ; will not work safely
    blue = !blue ; will work
    etc...
    how are the chips connected , show a schematic
    Oct 2010
    I will make the schematic on paper later today and will upload it here.
    thanks
    any Alias that refers to a LATx reg cannot be safely used with HIGH,LOW,TOGGLE or any other pbp high level command the sort of bugs it can introduce vary from chip to chip and can be difficult to understand , don't do it
    Though this is the recommended way to control output pins. I suppose this was before LAT registers showed up?
    Oct 2010
    Please find the schematic as follows.
    I hope i didnt forget anything. In any case is very simple.
    Name:  Schematic_IR TX_2023-06-02.png
    if you look at the data sheet for a tsop4838 you will see that you have a numbers of issues to contend with
    1. @9600baud the bit time is 100uS or approx 4 cycles of 38khz , about 2 to three times faster than the tsop4838 can cope with
    2. the max burst rate is 800/sec a 9600baud stream can exceed that
    3. after a 70 cycle transmission a 12 cycle min tx gap must be made [some devices can lock up if u don't and need a pwr cycle to recover]
    4. the device will do its very best to reject a continuous transmission and go mute till a min tx gap in tx is observed, which is what you are doing.
    overall tsop4838 is not particularly suitable for serial tx from a uart, you could try a much lower baud rate and you will need to
    invert the transmission logic so that there no transmission at idle
    i would also wire tx to rx directly to verify code works before trying ir link, also have a look at Manchester encoding and check out ir tx protocols like RC5/6 NEC etc
    Oct 2010
    Hi Richard,
    you are right, i have decreased the speed and manage to play a lit bit with the delay in useconds.
    I worked somehow but not always reliable.
    I think i will try the RC5 method.
    the series resistor for the led is wat too big, it will make range / reliability pretty low. it could go as low as 39 ohms safely [probably lower even] in a non continuously on configuration otherwise 100 ohm would be better
    Oct 2010
    I will try to change that as well before i go for the RC5.
    The following 15 days i will be in a business trip in Abu Dhabi so i will get back as soon as i have time to check this out.
    Many thanks.
    Aug 2011
    You can get rid of the transistor and associated resistors and just connect the OUT directly to RB7.
    If you need to, you can invert the RX sign with the DTRXP bit in the baudcon register.
    OK
    For most LEDs or SSRs, I found 470 ohms offers a good compromise between response time and effectiveness.
  1. Replies: 3
    Last Post: - 23rd October 2011, 13:53
  2. InfraRed Data Com
    By rayzrocket in forum Off Topic
    Last Post: - 29th March 2010, 16:42
  3. Infrared x PIC
    By ewandeur in forum mel PIC BASIC Pro
    Last Post: - 29th December 2009, 19:30
  4. infrared help
    By griffin in forum mel PIC BASIC Pro
    Last Post: - 30th December 2008, 06:34
  5. infrared
    By bmohnsen in forum General
    Last Post: - 2nd May 2007, 17:35
