Hwpw
+ Reply to Thread
Results 1 to 20 of 20
Thread: Hwpw
    Aug 2009
    Paso Robles California
    Question Hwpw
    Im running a few chips 16f876a at 20 mhz, 18f26k22 10mhz with 4x speed so 40mhz
    Even using timer 1 and timer 2 with two different ports, portc1 and portc2 you can not get two different PW is this correct
    I have also noticed at times one pulse is half the duty cycle other times it can be changed this could be because i used the same timer for both
    define OSC 40
    	OSCCON2.7 = 1				' SYSTEM CLOCK  1=4XPLL  0= OSCILLATOR OTHER THAN 4XPLL
     	TRISA =	%11111010
    	TRISB =	%11111100
    	ADCON1 = %0110
    	ADCON0 = %000
    	T0CON =	 %00000000
    	INTCON = %00000000
    	INTCON2 = %00000000
    		LED	VAR  PORTA.5  		' Assign name "LED" to PORTA.5
    		HIGH LED
    		PAUSE 2000
    		LOW led
    		PWM PORTA.5, 64, 6000
    	DEFINE CCP1_REG PORTC	        ' USED FOR HWPW
    	DEFINE CCP1_BIT 2			' USED FOR HWPW PORTC PIN 2
    	DEFINE HPWM2_TIMER1 		' DEFINE TIMER USE FOR PWM
    	DEFINE CCP2_REG PORTC	        ' USED FOR HWPW
    	DEFINE CCP2_BIT 1			' USED FOR HWPW PORTC PIN 1
    	DEFINE HPWM1_TIMER2		' DEFINE TIMER USE FOR PWM
    HPWM  1, 128, 5000				' OUTPUT PORTC.2
    'HPWM  2, 64, 5000				' OUTPUT PORTC.1
    ' HPWM  1, 128, 39000				' HIGHEST HPWM @ 50% DUTY  78.06 khz
    ' HPWM  1, 128, 30000				' HPWM @ 50% DUTY  60.19 khz
    ' HPWM  1, 128, 20000				' HPWM @ 50% DUTY  39.96 khz
    ' HPWM  1, 128, 10000				' HPWM @ 50% DUTY  19.98 khz
    ' HPWM  1, 128, 5000				' HPWM @ 50% DUTY    9.99 khz
    ' HPWM  1, 128, 2441				' LOWEST HPWM @ 50% DUTY  4.88 khz
    Default Re: Hwpw
    a pic18f26k22 can have 5 different pwm streams with 3 different frequencies all with individual duty cycles, old clunker chips like 16f876a are much less capable of course
    here is 3 streams 3 frequencies
    i find the hpwm command pretty inflexible and seldom use it [the clock defines are not correct in mho] , pwm is not difficult to setup manually
    '*  Name    : PWM demo.pbp                                      *
    '*  Author  :  Richard                                          *
    '*  Notice  :                                                   *
    '*  Date    : 21/12/2024                                        *
    '*  Notes   : TMR2 CCP4 10K, TMR4 CCP5 12.5K,  TMR6 CCP1 8K     *
    '*          :18f26k22 @64Mhz                                    *
      CONFIG  FOSC = INTIO67
      CONFIG  PLLCFG = ON
      CONFIG  PRICLKEN = ON
      CONFIG  FCMEN = OFF
      CONFIG  IESO = OFF
      CONFIG  PWRTEN = ON
      CONFIG  BOREN = SBORDIS
      CONFIG  BORV = 190
      CONFIG  WDTEN = ON
      CONFIG  WDTPS = 32768
      CONFIG  CCP2MX = PORTC1
      CONFIG  PBADEN = OFF
      CONFIG  CCP3MX = PORTB5
      CONFIG  T3CMX = PORTC0
      CONFIG  HFOFST = ON
      CONFIG  P2BMX = PORTB5
      CONFIG  MCLRE = EXTMCLR
      CONFIG  STVREN = ON
      CONFIG  LVP = OFF
      CONFIG  XINST = OFF
      CONFIG  DEBUG = OFF
      CONFIG  CP0 = OFF
      CONFIG  CP1 = OFF
      CONFIG  CP2 = OFF
      CONFIG  CP3 = OFF
      CONFIG  CPB = OFF
      CONFIG  CPD = OFF
      CONFIG  WRT0 = OFF
      CONFIG  WRT1 = OFF
      CONFIG  WRT2 = OFF
      CONFIG  WRT3 = OFF
      CONFIG  WRTC = OFF
      CONFIG  WRTB = OFF
      CONFIG  WRTD = OFF
      CONFIG  EBTR0 = OFF
      CONFIG  EBTR1 = OFF
      CONFIG  EBTR2 = OFF
      CONFIG  EBTR3 = OFF
      CONFIG  EBTRB = OFF
        DEFINE OSC 64
        ANSELB=0
        ANSELC=0
        ANSELA=0
        trisa=% 11101111
        trisb=% 11111110
        trisc=% 11111001
        OSCCON=$70
        OSCTUNE.6=1
        T2CON=6         ;PRESCALE 16 TMR ON
        T4CON=6         ;PRESCALE 16 TMR ON
        T6CON=6         ;PRESCALE 16 TMR ON
        PR2=$63         ;10 KHZ
        PR4=$4F         ;12.5 KHZ
        PR6=$7C         ;8 KHZ
        CCP4CON = $0C   ;PWM MODE + DUTY LSB 2 BITS
        CCPR4L  = $32   ;DUTY MSB 8 BITS
        CCP5CON = $0C   ;PWM MODE + DUTY LSB 2 BITS
        CCPR5L  = $27   ;DUTY MSB 8 BITS
        CCP1CON = $0C   ;PWM MODE + DUTY LSB 2 BITS
        CCPR1L  = $3E   ;DUTY MSB 8 BITS
        CCPTMRS1  = 4   ;TMR2 CCP4, TMR4 CCP5
        CCPTMRS0  = 2   ;TMR6 CCP1
    Aug 2009
    Default Re: HWPW
    I ran your program and according to the scope they all are running the same freq. with different pulse width
    Default Re: Hwpw
    not really they all are running the same pulse width with different freq.
    Aug 2009
    Default Re: Hwpw
    Well, I don't know what to say. I get all the same frequency with different pulse width.
    Even the program shows different pulse width.
    I even went back to the pick basic plus and i'm running for with four different timers, and they all run the same frequency, and if you set it for a different frequency, they shut down pulse width, I can control
    Default Re: Hwpw
    what do you mean ,that makes little sense
    my code works perfectly on the simulator and the actual hardware
    post your code and schematic .
    Aug 2009
    Default Re: Hwpw
    I ran the code that you posted.
    Aug 2009
    Default Re: Hwpw
    Walking and talking on the phone does not work well.
    I ran your program my scope has measure function all 3 channels showed the same frequency. But the duty cycle was the only difference. I used pbp setting ccp1, ccp2, ccp3 and ccp5 port c1, c2, and port b0, b5 there is also no control of individual frequency only duty cycle
    Default Re: Hwpw
    If you don't get three frequencies with 50% duty cycle then you are not using my code ,chip or schema.
    Post your code and schema
    Aug 2009
    Default Re: Hwpw
    I will rerun tomorrow and post scope pictures. Its
    definitely possible. I did something wrong. I am only running at 40 MHz. At this time, I have 16 mhz crystal's coming.
    Default Re: Hwpw
    totally not needed for this simple test, it uses internal osc
    Aug 2009
    Default Re: Hwpw
    RICHARD
    I reloaded your program exactly and it gave me
    12.54khz with a duty of 48.75 PW on channel A1
    8.02khz with a duty of 49.61 on channel C2
    10.02khz with a duty of 50.01 on channel B0
    You were absolutely correct and it works perfectly
    do you have any documentation of the settings and what to change for different freq and duty cycles Im just getting back into this after years of being away
    Aug 2009
    Default Re: Hwpw
    RICHARD I need to change porta4 hwpw to another port i tried ccp3con and ccpr3l changed the ccptmrs0 but nothing works I have something else on a4 on the boards im using
    Default Re: Hwpw
    https://www.picbasic.co.uk/forum/showthread.php/4994
    https://www.picbasic.co.uk/forum/showthread.php/26615
    or use MCC
    if you need porta.4 for another purpose then you cannot use CCP5
    post the code you have tried
    Aug 2009
    Default Re: Hwpw
    first question how do you get the code box to post into
    OK I was able to change the port from port a4 to port b5 now I need to figure out this
    CCP4CON = $0C ; PWM MODE + DUTY LSB 2 BITS ' PORT B0
    CCPR4L =%110010 ; DUTY MSB 8 BITS ' $32
    it does not seem to be very straight forward I will look at the posts you sent yesterday and see if I'm able to do the math, shifting and what ever else it takes.
    I did change the numbering to BIN so when looking in the manual I could line things up with the proper bits (don't get mad)
      ERRORLEVEL -306	       			; turn off crossing page boundary message
      CONFIG  PLLCFG = ON
      CONFIG  FCMEN = OFF
      CONFIG  IESO = OFF
      CONFIG  PWRTEN = ON
      CONFIG  BORV = 190
      CONFIG  WDTEN = ON
      CONFIG  PBADEN = OFF
      CONFIG  HFOFST = ON
      CONFIG  STVREN = ON
      CONFIG  LVP = OFF
      CONFIG  XINST = OFF
      CONFIG  DEBUG = OFF
      CONFIG  CP0 = OFF
      CONFIG  CP1 = OFF
      CONFIG  CP2 = OFF
      CONFIG  CP3 = OFF
      CONFIG  CPB = OFF
      CONFIG  CPD = OFF
      CONFIG  WRT0 = OFF
      CONFIG  WRT1 = OFF
      CONFIG  WRT2 = OFF
      CONFIG  WRT3 = OFF
      CONFIG  WRTC = OFF
      CONFIG  WRTB = OFF
      CONFIG  WRTD = OFF
      CONFIG  EBTR0 = OFF
      CONFIG  EBTR1 = OFF
      CONFIG  EBTR2 = OFF
      CONFIG  EBTR3 = OFF
      CONFIG  EBTRB = OFF
        DEFINE OSC 64
        ANSELB=0
        ANSELC=0
        ANSELA=0
        trisa = %11011111
        trisb = %11011110
        trisc = %11111001
        OSCCON = %1110000		; $70
        OSCTUNE.6 = 1
        T2CON = %0110        		; PRESCALE 16 TMR ON PORT B0	6
        T4CON = %0110         		; PRESCALE 16 TMR ON	PORT B5	6
        T6CON = %0110         		; PRESCALE 16 TMR ON	PORT C2	6
        PR2 = %1100011        		; 10 KHZ 					PORT B0	$63
        PR4 = %1001111        		; 12.5 KHZ				        PORT B5     $4F
        PR6 = %1111100         		;   8 KHZ					PORT C2	$7C
        CCP3CON = $0C   			; PWM MODE + DUTY LSB 2 BITS	' PORT B5
        CCPR3L  = %10111			; DUTY MSB 8 BITS				' $27
        CCP1CON = $0C   			; PWM MODE + DUTY LSB 2 BITS	' PORT C2
        CCPR1L  = %111110  		; DUTY MSB 8 BITS				' $3E
        CCPTMRS1  = %00   		: TIMER2 = CCP4, 	 ' TIMER4 CCP5 (USED WITH BELOW)
        CCPTMRS0  = %1011010	 	; TIMER6 = CCP1, 	   TIMER4 = CCP3
    Default Re: Hwpw
    https://www.picbasic.co.uk/forum/showthread.php/19594
    it can be informative for some registers for most its just unnecessary clutter
    its certainly not helped you get this correct
    setting C2TSEL<1:0>: CCP2 Timer Selection bits to %11 "reserved" is not a good practice
    CCPTMRS0 = %01000010 ; TIMER6 = CCP1, TIMER4 = CCP3 is preferable
    Aug 2009
    Default Re: Hwpw
    Yes the 11 i wasn't sure how to deal with it. So I put it in there if it didn't work. I would have pulled it right out, but it did work in this case. Remember, it's been 15 years since I've done any programming. I wasn't sure how to deal with some of this. So what button do you use to put code in to the forum messages.
    Aug 2009
    Default Re: Hwpw
    Nevermind, I found it a pound tag.
    Aug 2009
    Default Re: Hwpw
    Where can I get this program
    mister e's pic multi-calc
    Default Re: Hwpw
    Last post zip attachment
Members who have read this thread : 14
