SOLVED: System RESET works, sort of
Results 1 to 7 of 7
    Default Re: System RESET works, sort of
    GOT IT! Reinstalled the 555 timer with 7404 inverter.
    I had to up the capacitor to 100uF. Works beautifully with 10K.
    Just over a second (by eye), so now I can blip the button and reset is complete.
    Default Re: SOLVED: System RESET works, sort of
    Nope, no difference.
    I tried this guy's idea of a RC delay on the mosfet.
    https://electronics.stackexchange.co.../322184#322184
    I tried with 10uF and all the way up to 1M (both to VDD like that link), no difference. I didn't even get a delay.
    How can that be true? I really cannot understand... A simple cap with a resistor will give the required RC delay. And if you want to quickly reset again, the diode, reverse biased in parallel with the resistor will rapid discharge the cap, even if it is big enough.
    Don't get it why it failed...
  1. Replies: 19
    Last Post: - 27th September 2024, 20:56
  2. SOLVED - IOC works on B0 but not B5
    By Demon in forum General
    Last Post: - 26th September 2024, 22:11
  3. Replies: 4
    Last Post: - 22nd March 2023, 12:32
  4. Number Sort Algorithm
    Last Post: - 1st September 2021, 21:08
