SOLVED - How to calculate Timer preload
Results 1 to 8 of 8
    Question SOLVED - How to calculate Timer preload
    From Art's Timer thread here:
    https://www.picbasic.co.uk/forum/sho...978#post131978
    Hi Guys,
    ...For the 20MHz example where the constant is 03B7h, it's the reverse of this:
    FFFFh - 03B7h = C348h (49992 decimal),
    49992 + 8 = 50000 (it must take eight instruction cycles to reload the timer)
    50000 / 10000 = 5
    5 x 4 = 20MHz
    ...Cheers, Art.
    If I reverse these steps for a 16F1936 at 32MHz, I get this:
    32 / 4 = 8
    8 x 10000 = 80000
    80000 - 8 = 79992
    And that's where I block; 79992 is > 65535
    What am I doing wrong?
    I assume this is where the Prescaler comes into play, but I don't know how.
    EDIT: So far, I have this for T1CON:
    T1CON    = %01010100     ; Prescaler=1:1, TMR3ON.
    '           bit 7-6 TMR1CS<1:0>: Timer1 Clock Source Select bits
    '                   01 =Timer1 clock source is system clock (FOSC)
    '           bit 5-4 T1CKPS<1:0>: Timer1 Input Clock Prescale Select bits
    '                   01 = 1:2 Prescale value
    '           bit 3   T1OSCEN: LP Oscillator Enable Control bit
    '                   0 = Dedicated Timer1 oscillator circuit disabled
    '           bit 2   T1SYNC: Timer1 External Clock Input Synchronization Control bit
    '                   1 = Do not synchronize external clock input
    '           Unimplemented: Read as ‘0’
    '           bit 0 TMR1ON: Timer1 On bit
    '                   1 = Enables Timer1
    I'm still looking how to use Prescaler in Art's formula.
    (moved my post out of Art's thread)
    Default Re: SOLVED - How to calculate Timer preload
    SOLVED
    16F1936 at 32MHz:
    1) Elapsed_INT.bas, used Preload from 16 MHz,
      If OSC == 32
    TimerConst = 063C7h
      EndIF
    2) Set TMR1CS to Fosc/4
    3) Set T1CKPS to 1:2 Prescaler
    It runs at same speed as timer on my cell phone.
    Compete code:
    @ ERRORLEVEL -301   ; turn off ADC clock ignored message
    @ ERRORLEVEL -306   ; turn off crossing page boundary message
     __CONFIG _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
     __CONFIG _CONFIG2, _WRT_OFF & _VCAPEN_OFF & _PLLEN_OFF & _STVREN_OFF & _BORV_LO & _LVP_OFF
    DEFINE OSC 32
    SPLLEN          CON %1                  ' PLL enable
    IRCF            CON %1110               ' to enable 8 MHz
    SCS             CON %00                 ' system clock determined by FOSC
    OSCCON = (SPLLEN << 7) | (IRCF << 3) | SCS
    INCLUDE "DT_INTS-14.bas"
    INCLUDE "ReEnterPBP.bas"
    Include "Elapsed_INT.bas"
            INT_Handler   TMR1_INT,  _ClockCount,   PBP,  yes
    T1CON    = %00010101     ; Prescaler=1:1, TMR3ON.
    '                   00 =Timer1 clock source is instruction clock (FOSC/4)
    DEFINE  LCD_DREG      PORTB             ' Set LCD data port
    DEFINE  LCD_DBIT      0                 ' Set starting data bit
    DEFINE  LCD_RSREG     PORTC             ' Set LCD register select port
    DEFINE  LCD_RSBIT     5                 ' Set LCD register select bit
    DEFINE  LCD_EREG      PORTC             ' Set LCD enable port
    DEFINE  LCD_EBIT      4                 ' Set LCD enable bit
    DEFINE  LCD_BITS      4                 ' Set LCD bus size
    DEFINE  LCD_LINES     4                 ' Set number of lines on LCD
    DEFINE  LCD_COMMANDUS 1000              ' Set command delay time in microseconds
    DEFINE  LCD_DATAUS    50                ' Set data delay time in microseconds
    define  CCP4_REG     PORTC              ' PWM Pulse out to LCD contrast
    DEFINE  CCP4_BIT     1                  '   2N2907 PNP with 1K on base
    define  CCP5_REG     PORTC              ' PWM Pulse out to LCD backlight
    DEFINE  CCP5_BIT     2                  '   2N2222A NPN with 1K on base
    ANSELA = %00000000
    ANSELB = %00000000
    TRISA = %00000111
    TRISB = %00110000
    TRISC = %10000000
    TRISE = %00000000
        HPWM 2,100,1953
        HPWM 1,180,1953
    @ INT_ENABLE TMR1_INT ; Enable Timer 1 Interrupts
        Gosub ResetTime                ' Reset Time to  0d-00:00:00.00
        Pause 500                           ' Let PIC and LCD stabilize
        LCDOUT $FE, 1 : Pauseus 1
        GOSUB StartTimer          ' Start the Elapsed Timer
    Mainloop:
        IF SecondsChanged = 1 THEN
            SecondsChanged = 0
            LCDOUT $FE,2, DEC Days,"d-",DEC2 Hours,":",DEC2 Minutes,":",DEC2 Seconds
        goto mainloop
    Art's formula with Prescaler:
    65535 - (((( MHz / Prescaler ) / 4 ) x 10000 ) - 8 )
    What are the 10000 and 8 stand for in the equation?
    I couldn't tell you. See Art's thread above.
    Aug 2011
    The 10000 comes from the fact that the intr code is assuming a 100Hz interrupt (MHz -> 100Hz = 10000),
    and the 8 is an attempt to compensate for the number of instruction cycles it takes to reload the timer.
    Demon -
    How long of a time period are you looking to measure?
    If you can live with 65536 counts (the 16-bit timer count) then you can just drop all the interrupt code, let the timer free-run, and just subtract two unsigned timer values... something like this:
    start_time = readtimer()
    'code you wish to time is here
    elapsed_time = readtimer() - start_time
    Aug 2011
    If you let the timer free-run, then at 32MHz using FOSC/4 as the timer clock and 1:1 prescaler you can count up to 8192us (8ms) with 125ns/count.
    Setting the prescaler to 1:8 extends this to 8x8192 = 65536us (roughly 65ms), but your resolution drops to 8x125ns = 1us
    Tumbleweed, that's the thing. I'm still at the research phase; trying to determine what Henrik calls velocity sensing.
    Next challenge: Velocity sensing, ie a way to detect that the user wants the value to change by a lot and not have to turn the knob 600 turns. Getting that just right seems to be tricky, even the big boys don't always... (I've never tried).
    I can flick the rotary encoder at 3.5msec from low-low to high-high, but still need to determine that cut-off speed.
    https://www.picbasic.co.uk/forum/sho...000#post156000
    And then it hit me as I'm typing this post. I can use the logic probe in real-time to find that sweet spot, instead of writing code to display that on LCD (or xmit via HSEROUT). And that's where things get crazy cause all that extra code and I/O would definitely throw off my readings.
    Can't see the forest for the trees...
  1. Replies: 11
    Last Post: - 23rd August 2024, 02:13
  2. large preload includes
    By longpole001 in forum PBP3
    Last Post: - 29th January 2020, 11:16
  3. T1 interrupt and preload confusion
    By amgen in forum General
    Last Post: - 14th September 2011, 03:24
  4. Hanging on SERIN2 - SOLVED!
    By blainecf in forum Serial
    Last Post: - 13th July 2006, 17:55
  5. Dmx Solved !!!!!!!
    By oscar in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2005, 21:57
Members who have read this thread : 4
