My rotary encoder adventures
Results 1 to 17 of 17
    Default Re: My rotary encoder adventures
    Here's one of my faster ones:
    A is 15.22ms duration
    Difference between rise of A and B is 3.50ms
    I nearly had time to send LCDOUT twice.
    Name:  Encoder probe g.png
    I'm more than satisfied with what I have so far as encoder logic. When I remove LCDOUT, this is how many times the encoder logic can cycle during a fast pulse; a gazillion.
    Name:  Encoder probe h.png
    I'm thrilled actually; with a big smile on my face as I type this.
    Very good, then there's plenty of margin.
    Next challenge: Velocity sensing, ie a way to detect that the user wants the value to change by a lot and not have to turn the knob 600 turns. Getting that just right seems to be tricky, even the big boys don't always... (I've never tried).
    How will you transfer the count from one PIC to the other? Keep track of your timing, you might be able to do it all with a single PIC. If needed, divide the LCDOutput routine in two (or more) parts if needed.
    You can experiment with
    DEFINE LCD_COMMANDUS 2500
    And
    DEFINE LCD_DATAUS 50
    parameters in order to match your LCD module. Maybe you are lucky and have a faster one. But be carefull as these might not work with all modules.
    The Velocity sensing is a really good one. Indeed, if the user has to to change values in a broad range it is very handy. Maybe if Timer is involved can make things simpler.
    Next challenge: Velocity sensing, ie a way to detect that the user wants the value to change by a lot and not have to turn the knob 600 turns. Getting that just right seems to be tricky, even the big boys don't always... (I've never tried). ...
    That's exactly why I started looking up Elapsed Timer last night. I already have an idea in mind; rotate the encoder at 3 speeds, record the time elapsed between pulses, and then use that to determine if I increment/decrement by ones, fives or tens. I figure with some tweaking I can generate a decent compromise.
    I've already adjusted my logic this morning to fall down to 359 when it goes below 0; to better simulate a heading gauge in flight sim, and inverse, flip up to 0 after moving up past 359.
    ... How will you transfer the count from one PIC to the other? ...
    HSEROUT, that's why I had it in my early tests. It compares somewhat with LCDOUT timewise, maybe a tad slower.
    I have a lot of R&D to go on that subject (like protocol and such).
    ... If needed, divide the LCDOutput routine in two (or more) parts if needed.
    Nah, I have a LOT of controls to manage. I'm putting encoders as priority on a PIC, then switches and pots separately (ADC probably takes forever in comparison), and 4 LCDs wherever I have room and time available.
    This is a preliminary layout; 3 enclosures: left, center and right . The right side has the most encoders with:
    - 4 dual encoders
    - 7 single encoders
    - 1 mouse wheel (essentially a single encoder)
    Those Custom Keys in the middle are just a reminder for a 4th optional enclosure at far left.
    The thin red stripes are LED stripes; shielded towards the controls to simulate a red glow, like this:
    Name:  Cockpit 50pct.png
    Dec 2010
    Melbourne Australia
    I'm in the middle of a project requiring a rotary encoder to set a weight target for a loadcell. I plan on using Richard's graphical LCD driver for a dot matrix display (not superfast update refreshing), so I actually needed something like what you've described there Henrik. Using Demon's code, I twiddled it a bit to utilise (elapsed) Timer0 on an 18F26K22 to provide the screen refreshing. This is what I basically came up with (which I'm happy with):
    'REMOVED ALL THE INIALIZATION STUFF FOR THIS PASTING
    Enc1_counter = 1000
    SETFONT FONT5x7
    'SETFONT bignum5
    LATC.4 = 0 'using a pic pin output as a temporary ground rail for the rotary encoder
    gosub grf_clr
    T0CON.7 = 1 'enable timer 0
    T0CON.6 = 0 'timer 0 in 16 bit mode
    T0CON.5 = 0 'timer 0 clock source = internal instruction clock
    'T0CON.4
    T0CON.3 = 0 'timer prescaler assigned
    T0CON.2 = 0 ' prescaler assigned to 1:4
    T0CON.1 = 0 ' "
    T0CON.0 = 1 ' "
    Timer_Counter = 0
    Change = 0
    MainLoop:
        Timer_Counter.lowbyte = TMR0L
        Timer_Counter.highbyte = TMR0H
        New_Encoder = (PortB.4 << 1) + PortB.5
        IF New_Encoder != Old_Encoder THEN
            IF New_Encoder = %00000011 THEN
                IF Old_Encoder = %00000010 THEN
                    Change = Change+1
                    Enc1_counter = Enc1_counter + Change
                    IF Old_Encoder = %00000001 THEN
                        Change = Change+1
                        Enc1_counter = Enc1_counter - Change
                IF New_Encoder = %00000000 THEN
                        Change = Change+1
                            Change = Change+1
        if change >= 1 and Timer_Counter>60000 then
            TMR0H=0
            TMR0L=0
            ARRAYWRITE BUFF,[sdec Enc1_counter,0]
            gosub grf_clr
            'DMDSTR 10,10, BUFFp,1
            DMDSTR 10,10, BUFF,1
            gosub show
            Change = 0
            pause 5
        Old_Encoder = New_Encoder
    goto MainLoop:
    Troy
  1. Rotary encoder with DT interrupts
    By louislouis in forum mel PIC BASIC Pro
    Last Post: - 21st March 2021, 16:45
  2. Rotary encoder subroutine
    By Fanias in forum mel PIC BASIC Pro
    Last Post: - 10th October 2018, 14:13
  3. Using an incremental rotary encoder?
    By keithv in forum mel PIC BASIC Pro
    Last Post: - 12th January 2016, 23:23
  4. New approach to Rotary Encoder
    By Ioannis in forum Code Examples
    Last Post: - 11th July 2013, 22:05
