Pot jitters during ADC capture
Results 1 to 34 of 34
Threaded View
  1. #22
    Default Re: Pot jitters during ADC capture
    a voltage follower amp is really only a benefit if the signal source impedance is so high that the adc input loads the signal so much to make it inaccurate. it will not smooth out a crappy pot if anything it may accentuate it.
    a lowpass filter will help whether its analog pre adc or digital post adc will make little difference
    right now I'm working with FSR'S [force sensitive resistors] with 200k to 500k resistances on a pic 16f18426
    no problem what so ever
    what do the pots perform like when measured on a ohmmeter [an analog one would be ideal]
    if they are really that bad then the resolution achievable will be low no matter how you go about it
    especially if there are dead spots
  1. Using hardware capture
    Last Post: - 25th March 2012, 05:52
  2. Capture woes...
    By ardhuru in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2011, 08:36
  3. Capture with PIC16F88
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 27th March 2010, 13:05
  4. Capture without CCP
    Last Post: - 28th March 2009, 23:09
  5. Capture
    By SlotH in forum mel PIC BASIC Pro
    Last Post: - 18th May 2005, 19:17
Members who have read this thread : 14
