SOLVED - Can't get IOC on pin change working
Results 1 to 9 of 9
    Question SOLVED - Can't get IOC on pin change working
    16F18877:
        __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_ON & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
    DEFINE OSC 32
    include     "DT_INTS-14.bas"
    include     "ReEnterPBP.bas"
    INT_LIST  macro      ;IntSource,  Label,     Type, ResetFlag?
            INT_Handler   IOC_INT,    _IOCinterrupts,    PBP,  yes
        INT_CREATE                      ;Creates the interrupt processor
    INTCON = %10000000
    '           bit 7   GIE         Global Interrupt Enable bit
    '                                   1 = Enables all active interrupts
    '           bit 6   PEIE        Peripheral Interrupt Enable bit
    '           bit 5-1     Unimplemented: Read as ‘0’
    '           bit 0   INTEDG      Interrupt Edge Select bit
    PIE0 = %00010000    ' PERIPHERAL INTERRUPT ENABLE REGISTER 0
    '           bit 7-6 Unimplemented: Read as ‘0’
    '           bit 5 TMR0IE: TMR0 Overflow Interrupt Enable bit
    '           bit 4 IOCIE: Interrupt-on-Change Interrupt Enable bit
    '                                   1 = Enables the IOC change interrupt
    '           bit 3-1 Unimplemented: Read as ‘0’
    '           bit 0 INTE: INT External Interrupt Flag bit
    IOCCP = %00010000   ' INTERRUPT-ON-CHANGE PORTC POSITIVE EDGE REGISTER
    '           bit 7-0 IOCCP<7:0>  Interrupt-on-Change PORTC Positive Edge Enable bits
    '                                   1 = Interrupt-on-Change enabled on the pin
    '                                       for a positive-going edge. IOCCFx bit
    '                                       and IOCIF flag will be set upon detecting an edge.
    IOCCN = %00000000   ' INTERRUPT-ON-CHANGE PORTC NEGATIVE EDGE REGISTER
    '           bit 7-0 IOCCP<7:0>  Interrupt-on-Change PORTC Negative Edge Enable bits
    '                                       for a Negative-going edge. IOCCFx bit
    ANSELA = %00000000
    ANSELB = %00000000
    ANSELC = %00000000
    ANSELD = %00000000
    ANSELE = %00000000
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00010000
    TRISD = %00000000
    TRISE = %00000000
    PushSwitch      VAR PortC.4
    InterruptLED    VAR LatC.2
    HeartbeatLED    VAR LatC.3
    ButtonWasPressed VAR byte
        Pause 500                                       ' Let PIC and LCD stabilize
        InterruptLED = 0
        ButtonWasPressed = 0
        IOCCF.4 = 0
    @ INT_ENABLE IOC_INT
        goto Mainloop
    IOCinterrupts:
        if IOCCF.4 = 1 then
            ButtonWasPressed = 1                        ' set a flag
            IOCCF.4 = 0
    @ INT_RETURN
    Mainloop:
        if ButtonWasPressed = 1 then                    ' Check flag
            InterruptLED = 1
        HeartbeatLED = 1
        HeartbeatLED = 0
        goto mainloop
    InterruptLED never lights up when I press PushSwitch, and the HeartbeatLED seems to hang for 2-3 seconds when I press.
    Default Re: Can't get IOC on pin change working
    Salaea Logic probe data:
    Name:  IOC pulses.png
    Tried it with PEIE enabled as per 7.1 of datasheet (p. 129):
    INTCON = %11000000
    Did the same thing.
    I disabled PIE0 and can confirm that the switch signal does reach the PIC (I can manually turn the LED).
        if PushSwitch = 1 then
            Toggle InterruptLED
    I removed INTCON and PIE0 as per:
    https://www.picbasic.co.uk/forum/sho...517#post154517
    The HeartbeatLED doesn't hang any more, but the ISR doesn't seem to get triggered.
    Richard gives me hope; the 16F18875 is part of the same family as the 16F18877:
    https://www.picbasic.co.uk/forum/sho...529#post154529
    You need to redo the section that #defines the interrupt bit locations.
    It's in the section that looks like this...
      #define INT_INT      	PIR0,INTF,  PIE0,INTE       ;-- External INT
      #define IOC_INT      	PIR0,IOCIF, PIE0,IOCIE     ;-- Int On Change       *
    You need to get the datasheet for the part and change the 'PIR0,INTF, PIE0,INTE' statements to match.
    I have no idea what section of the datasheet I'm supposed to be looking at.
    https://www.picbasic.co.uk/forum/sho...497#post154497
    EDIT: Found this from MpgMike (got some reading to do):
    https://support.melabs.com/forum/pic...tant-interrupt
    IOC on pin C4 now works after using custom INCLUDE DT_INTS-14_16F1885x-7x.bas:
    ;---[16F1885x7x]------------------------------------------------------------
    ; #define IOC_INT      INTCON,IOCIF, INTCON,IOCIE  ;-- Int On Change
    I need to do more testing to confirm this was all I needed, but at least it picks up the positive edge change on the pin and lights InterruptLED.
    EDIT: Complete code:
    DEFINE OSC 32
    include     "C:\PBP Includes\DT_INTS-14_16F1885x-7x.bas"
    include     "C:\PBP Includes\ReEnterPBP.bas"
            INT_Handler   IOC_INT,    _MyIOCinterrupts,    PBP,  yes
    '                           Controlled by DT-INTS
    'INTCON = %10000000
    'PIE0 = %00010000    ' PERIPHERAL INTERRUPT ENABLE REGISTER 0
    ANSELA = %00000000
    ANSELB = %00000000
    ANSELC = %00000000
    ANSELD = %00000000
    ANSELE = %00000000
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00010000
    TRISD = %00000000
    TRISE = %00000000
        Pause 500                                       ' Let PIC stabilize
        InterruptLED = 0
        IOCCF.4 = 0
    Mainloop:
            InterruptLED = 1
        goto mainloop
    MyIOCinterrupts:
        if IOCCF.4 = 1 then
            IOCCF.4 = 0
    '        INTCON.7 = 1        ' 7.1 Operation p. 129
                            ' The following events happen when an interrupt event
                            ' occurs while the GIE bit is set:
                            '   • GIE bit is cleared
    @ INT_RETURN
    Default Re: SOLVED - Can't get IOC on pin change working
    Can you post the include file? I may need that in the near future. Since you done it, it will help.
    I followed Mike's advice:
    - made a copy and named it DT_INTS-14_16F1885x-7x.bas,
    - clearly identified it as NOT being the original INCLUDE,
    - kept only the DEFINES that I need,
    - modified IOC-INT:
    '*  Name    : DT_INTS-14_16F1885x-7x.bas                                   *
    '*  Author  : Darrel Taylor (modified by Demon)                            *
    '*  Version : 1.15 (8/29/2024)                                             *
    '*  Date    : OCT 13, 2009                                                 *
    '* REV 1.15  Customized for 16F1885xx-7x (IOC, USART-RX, CCPx)             *
    '* REV 1.10  Fixes Duplicate label error when Handlers cross page boundary *
    '*           Fixes error with 16F1's and MPLAB 8.53 (high)                 *
    '* REV 1.00  Completely re-written, with optimization and F1 chips in mind *
    '* REV 0.93  Fixed CMIF and EEIF problem with older PIC's                  *
    '*           that have the Flags in PIR1 instead of PIR2                   *
    '* Rev 0.92  solves a "Missed Interrupt" and                               *
    '*           banking switching problem                                     *
    DEFINE  DT_INTS_VERSION  110
    DEFINE  INTHAND  INT_ENTRY
    ;-- Place a copy of these variables in your Main program -------------------
    ;--   The compiler will tell you which lines to un-comment                --
    ;--   Do Not un-comment these lines                                       --
    ;wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    ;wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
    ;wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    ;wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    ;wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
    ssave       VAR BYTE    BANK0   SYSTEM      ' location for STATUS register
    psave       VAR BYTE    BANK0   SYSTEM      ' location for PCLATH register
    fsave       VAR BYTE    BANK0   SYSTEM      ' location for FSR register
    RetAddr     VAR WORD    BANK0
    INT_Bits    VAR BYTE    BANK0
      Serviced  VAR INT_Bits.0
      Vars_Saved VAR INT_Bits.1
    GIE         VAR INTCON.7
    PEIE        VAR INTCON.6
      ifdef PM_USED                             ; verify MPASM is the assembler
        "ERROR: DT_INTS does not support the PM assembler, USE MPASM"
      ifdef ReEnterUsed
        ifdef ReEnterVersion
          if (ReEnterVersion < 34)
            error "Wrong version of ReEnterPBP.bas - Ver 3.4 or higher required
        if (BANK0_END == 0x7F)
          ifdef BANK1_END
            if (BANK1_END == 0xEF)   ; doesn't find 12F683
              variable ACCESSRAM = 1
              variable ACCESSRAM = 0
    #define OrChange Or change to   wsave BYTE $70 SYSTEM
    AddWsave macro B
      if (B == 0)
        if (ACCESSRAM == 1)
          error   "                     Add:"       wsave VAR BYTE $70 SYSTEM
          error   "                     Add:"       wsave VAR BYTE $20 SYSTEM
      if (B == 1)
        if (ACCESSRAM == 1)
          error   "   Add:"       wsave1 VAR BYTE $A0 SYSTEM, OrChange
      if (B == 2)
        if (ACCESSRAM == 1)
          error   "   Add:"       wsave2 VAR BYTE $120 SYSTEM, OrChange
      if (B == 3)
        if (ACCESSRAM == 1)
          error   "   Add:"       wsave3 VAR BYTE $1A0 SYSTEM, OrChange
    #define WsaveE1(B) Chip has RAM in BANK#v(B), but wsave#v(B) was not found.
    ;#define WsaveE2(B) Uncomment wsave#v(B) in the DT_INTS-14.bas file.
    #define WsaveCouldBe This chip has access RAM at $70
    #define WsaveError(B) error  WsaveE1(B)
      ifndef FSR0L     ; not a 16F1
        ifndef wsave
    ;      if (ACCESSRAM == 1)
            error wsave variable not found,
            AddWsave(0)
            variable wsave = 0 ; stop further wsave errors
    ;      else
    ;      endif
          if (wsave == 0x70)
            if (ACCESSRAM == 0)
              error This chip does not have AccessRAM at $70, change to   wsave VAR BYTE $20 SYSTEM
              if (wsave != 0x20)
                error wsave must be either $20 or $70
        ifdef BANK1_START
          ifndef wsave1
            ifdef wsave
              if (wsave != 0x70)
                WsaveError(1)
                AddWsave(1)
              if (ACCESSRAM == 1)
                if (wsave != 0x70)
                  WsaveCouldBe
        ifdef BANK2_START
          ifndef wsave2
            ifdef wsave
              if (wsave != 0x70)
                WsaveError(2)
                AddWsave(2)
        ifdef BANK3_START
          ifndef wsave3
            ifdef wsave
              if (wsave != 0x70)
                WsaveError(3)
                AddWsave(3)
    asm = 0
    Asm = 0
    ASM = 0
    pbp = 1
    Pbp = 1
    PBP = 1
    yes = 1
    Yes = 1
    YES = 1
    no  = 0
    No  = 0
    NO  = 0
    ;---[Original DEFINES]------------------------------------------------------
      #define ALL_INT      INTCON,GIE, INTCON,GIE      ;-- Global Interrupts   *
      #define RX_INT       PIR1,RCIF, PIE1,RCIE        ;-- USART Receive
      #define CCP1_INT     PIR1,CCP1IF, PIE1,CCP1IE    ;-- CCP1
      #define CCP2_INT     PIR2,CCP2IF, PIE2,CCP2IE    ;-- CCP2
      #define CCP3_INT     PIR3,CCP3IF, PIE3,CCP3IE    ;-- CCP3
      #define CCP4_INT     PIR3,CCP4IF, PIE3,CCP4IE    ;-- CCP4
      #define CCP5_INT     PIR3,CCP5IF, PIE3,CCP5IE    ;-- CCP5
    ;---[Returns the Address of a Label as a Word]------------------------------
    GetAddress macro Label, Wout
        CHK?RP Wout
        movlw low Label          ; get low byte
        movwf Wout
    ;    movlw High Label         ; get high byte  MPLAB 8.53 killed high
        movlw Label >> 8         ; get high byte
        movwf Wout + 1
    ;---[find correct bank for a BIT variable]----------------------------------
    CHKRP?T  macro reg, bit
        CHK?RP  reg
    ;---[This creates the main Interrupt Service Routine (ISR)]-----------------
    INT_CREATE  macro
      local OverCREATE
        L?GOTO OverCREATE
    INT_ENTRY
        ifndef FSR0L
          if (CODE_SIZE <= 2)
              movwf   wsave       ; 1 copy W to wsave register
              swapf   STATUS,W    ; 2 swap status reg to be saved into W
              clrf    STATUS      ; 3 change to bank 0
              movwf   ssave       ; 4 save status reg to a bank 0 register
              movf    PCLATH,W    ; 5 move PCLATH reg to be saved into W reg
              movwf   psave       ; 6 save PCLATH reg to a bank 0 register
          endIF
          movf      FSR,W         ; 7 move FSR reg to be saved into W reg
          movwf     fsave         ; 8 save FSR reg to a bank 0 register
          banksel 0               ; BANK 0 for F1 chips
        variable  PREV_BANK = 0
        MOVE?CT  0, _Vars_Saved
    List_Start
        ifdef LoopWhenServiced
          MOVE?CT  0, _Serviced   ; indicate nothing has been serviced
        INT_LIST                  ; Expand the users list of interrupt handlers
                                ; INT_LIST macro must be defined in main program
          BIT?GOTO  1, _Serviced, List_Start
        ifdef ReEnterUsed         ; if ReEnterPBP.bas was included
            CHKRP?T  _Vars_Saved
            btfss    _Vars_Saved  ; if PBP system vars have been saved
            goto     INT_EXIT
            L?GOTO   _RestorePBP  ; Restore PBP system Vars
    INT_EXIT
        ifndef FSR0L              ; if chip is not an F1 - restore context
          clrf    STATUS          ; BANK 0
          movf    fsave,W         ; Restore the FSR reg
          movwf   FSR
          movf    psave,w         ; Restore the PCLATH reg
          movwf   PCLATH
          swapf   ssave,w         ; Restore the STATUS reg
          movwf   STATUS
          swapf   wsave,f
          swapf   wsave,w         ; Restore W reg
        retfie                    ; Exit the interrupt routine
      LABEL?L OverCREATE
        bsf      INTCON, 6      ; Enable Peripheral interrupts
        bsf      INTCON, 7      ; Enable Global interrupts
    ;---[Add an Interrupt Source to the user's list of INT Handlers]------------
    #INT_HANDLER  macro  FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
      list
        local AfterSave, AfterUserRoutine, NoInt
          ifdef FlagBit
            CHK?RP   EnableReg
            btfss    EnableReg, EnableBit        ; if the INT is enabled
            goto     NoInt
            CHK?RP   FlagReg
            btfss    FlagReg, FlagBit            ; and the Flag set?
            goto     NoInt
              MOVE?CT  1, _Serviced
            if (Type == PBP)                     ; If INT handler is PBP
              ifdef ReEnterUsed
                btfsc  _Vars_Saved
                goto   AfterSave
                GetAddress  AfterSave, _RetAddr
                L?GOTO  _SavePBP                 ; Save PBP system Vars
                LABEL?L  AfterSave
                error ReEnterPBP must be INCLUDEd to use PBP type interrupts
            GetAddress  AfterUserRoutine, _RetAddr   ; save return address
            L?GOTO   Label                       ; goto the users INT handler
            LABEL?L AfterUserRoutine
            if (Reset == YES)
              CHK?RP   FlagReg
              bcf      FlagReg, FlagBit        ; reset flag (if specified)
            INT_ERROR  "INT_Handler"
    NoInt
          banksel  0
    PREV_BANK = 0
    #define INT_HANDLER(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
      ifndef INT_Handler
    #define INT_Handler(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
    #define int_handler(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
    #define Int_Handler(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
    #define Int_handler(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
    #define int_Handler(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
    ;---[Returns from a "goto" subroutine]--------(RetAddr must be set first)---
    #INT_RETURN  macro
          CHK?RP  _RetAddr
          movf    _RetAddr + 1, W  ; Set PCLATH with top byte of return address
          movwf   PCLATH
          movf    _RetAddr, W      ; Go back to where we were
          movwf   PCL
    ;_____________________________
    #define INT_RETURN  #INT_RETURN
      ifndef INT_Return
    #define INT_Return  #INT_RETURN
    #define int_return  #INT_RETURN
    #define Int_Return  #INT_RETURN
    #define Int_return  #INT_RETURN
    #define int_Return  #INT_RETURN
    ;----[Display not found error]----------------------------------------------
    INT_ERROR macro From
        error From -  Interrupt Flag ( FlagReg,FlagBit ) not found.
    ;---[Enable an interrupt source]--------------------------------------------
      ifndef INT_ENABLECLEARFIRST
        #define INT_ENABLECLEARFIRST 1             ; default to Clear First
      endif          ; use DEFINE INT_ENABLECLEARFIRST 0 to NOT clear First
    #INT_ENABLE  macro  FlagReg, FlagBit, EnableReg, EnableBit
          ifdef FlagBit
            ifdef INT_ENABLECLEARFIRST
              if (INT_ENABLECLEARFIRST == 1)       ; if specified
                MOVE?CT 0, FlagReg, FlagBit        ;   clear the flag first
            MOVE?CT  1, EnableReg, EnableBit       ; enable the INT source
            INT_ERROR  "INT_ENABLE"
    #define INT_ENABLE(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
      ifndef INT_Enable
    #define INT_Enable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define int_enable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_Enable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_enable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define int_Enable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
    ;---[Disable an interrupt source]-------------------------------------------
    #INT_DISABLE  macro  FlagReg, FlagBit, EnableReg, EnableBit
          ifdef FlagBit
            MOVE?CT  0, EnableReg, EnableBit       ; disable the INT source
            INT_ERROR  "INT_DISABLE"
    #define INT_DISABLE(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
      ifndef INT_Disable
    #define INT_Disable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define int_disable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_Disable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_disable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define int_Disable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
    ;---[Clear an interrupt Flag]-----------------------------------------------
    #INT_CLEAR  macro  FlagReg, FlagBit, EnableReg, EnableBit
          ifdef FlagBit
            INT_ERROR "INT_CLEAR"
    #define INT_CLEAR(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
      ifndef INT_Clear
    #define INT_Clear(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
    #define int_clear(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_Clear(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_clear(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
    #define int_Clear(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
    I posted my observations over here:
    https://www.picbasic.co.uk/forum/sho...080#post156080
    Great! Thanks
  1. IOC on a ACD pin ?
    Last Post: - 28th August 2013, 01:11
  2. Replies: 1
    Last Post: - 12th May 2012, 12:37
  3. A Simple IOC Routine (Interrupt On Change)
    By lugo.p in forum mel PIC BASIC Pro
    Last Post: - 8th March 2010, 19:53
  4. Interrupt-on-Change-pin!
    By PICante in forum mel PIC BASIC Pro
    Last Post: - 11th February 2009, 20:22
  5. HELP !!! How change the voltage of a pin ????
    By stormdacta in forum mel PIC BASIC Pro
    Last Post: - 21st August 2007, 20:55
