Resetting a slave from master mcu
Results 1 to 26 of 26
    Default Re: Resetting a slave from master mcu
    Yeah, I was blindly following SN7407 datasheet. I don't really care about timing, so I upped it to 1K pull-up.
    given that I-inh max for a SN7407 gate is 40uA and a pic output pin could drive more than 20 of them and still produce a clean TTL signal.
    i cannot see that signal timing would even be a consideration. just what need does the pullup fulfill ?
    Except from preventing the input pin on the SN7407 from floating, I don't see one for my application.
    I don't really care about "precision timing"; I just trigger the MCLR reset on the Slave with a 10usec pause. I still have a pull-up downstream on the Slave PIC.
    SlaveMCLR = 0
    PauseUS 10
    SlaveMCLR = 1
    EDIT: I figured I'd read the instructions AFTER posting that reply.
    11.1 Layout Guidelines: ... All unused inputs of digital logic devices must be connected to a high or low bias to prevent them from floating.
    Promptly runs over to breadboard to pull down the other 5 unused inputs.
  1. Master to slave 16F767
    By sachymo in forum General
    Last Post: - 3rd June 2008, 21:22
  2. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
  3. PIC master slave howto
    Last Post: - 18th September 2007, 23:35
  4. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 23:59
  5. i2c master/slave
    By lab310 in forum mel PIC BASIC Pro
    Last Post: - 8th April 2005, 23:23
