Resetting a slave from master mcu
Results 1 to 26 of 26
    Default Re: Resetting a slave from master mcu
    crap, I figured you were a kid .....
    I'm a kid at heart, and I get out of bed at the same speed as them.
    ..... I always put the pics in sockets, saves a lot of F-ups....
    Yeah, I'd hate to notice a mistake at the end of assembling my boards.
    ... For transistor, logic level MOSFET is good to use. The logic level means it will be full on with 5 volts on gate, no resistors required.... N-channel like BS170 ... with this, the reset is a high pulse on master...(dah)
    I finally got a few SN7407 thanks to Mr E's suggestion a while back. This runs awesome, and I have room for 6 slaves, that should be enough for my boards.
    Name:  MCLR slaves from master.png
    I don't have to worry about the surges up towards the Master during programming the Slave.
    (Which is good, cause my MeLabs U2 programmer doesn't do LVP, and I can't get my PicKit4 to run properly).
    No, but the 120 ohm pullup will be a pin killer if the vdd is 5v
    Yeah, I was blindly following SN7407 datasheet. I don't really care about timing, so I upped it to 1K pull-up.
    given that I-inh max for a SN7407 gate is 40uA and a pic output pin could drive more than 20 of them and still produce a clean TTL signal.
    i cannot see that signal timing would even be a consideration. just what need does the pullup fulfill ?
    Except from preventing the input pin on the SN7407 from floating, I don't see one for my application.
    I don't really care about "precision timing"; I just trigger the MCLR reset on the Slave with a 10usec pause. I still have a pull-up downstream on the Slave PIC.
    SlaveMCLR = 0
    PauseUS 10
    SlaveMCLR = 1
    EDIT: I figured I'd read the instructions AFTER posting that reply.
    11.1 Layout Guidelines: ... All unused inputs of digital logic devices must be connected to a high or low bias to prevent them from floating.
    Promptly runs over to breadboard to pull down the other 5 unused inputs.
  1. Master to slave 16F767
    By sachymo in forum General
    Last Post: - 3rd June 2008, 21:22
  2. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
  3. PIC master slave howto
    Last Post: - 18th September 2007, 23:35
  4. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 23:59
  5. i2c master/slave
    By lab310 in forum mel PIC BASIC Pro
    Last Post: - 8th April 2005, 23:23
