could do.........
1)
restarting:
pause 1000 ............... wait a second or 2 to reset all
@ RESET
or 2)................
if all slaves are on same 5 or 3 volt supply, then use a small NC (normally closed) relay to turn off power for few seconds to restart all slaves
What is the @ RESET command? (I'm using PBP3.1)
I prefer to avoid relays and mechanical devices. Contacts generally consume more current than ICs and discretes, and contacts wear out.
I've got an order for some SN7407N from Digikey; gonna check out Mr E's suggestion.
