Resetting a slave from master mcu
Results 1 to 26 of 26
    Default Resetting a slave from master mcu
    See post #22:
    https://www.picbasic.co.uk/forum/sho...323#post156323
    A SN7407 Buffer works great!
    I have a reset button on the master PIC, and I'd like to reset all the slaves internally. This is what I have so far:
    I found formulas to calculate the base resistor, like this one:
    https://breadboardcircuits.com/how-transistors-work/
    But they're dependent on preliminary calculations done for the load current, and I have no clue how that is calculated with a PIC pin. I see several current loads in the datasheet for the 16F1933, but no clue which is the appropriate one to use in the formulas.
    Default Re: Resetting a slave from master mcu
    The main Load Current for the PNP transistor will come from the 10K, R5 resistor, that goes to +Vdd and not from the PIC /MCLR pin. Do not worry about that.
    I had gotten that circuit from "somewhere", but I can't find any more. So, I'm looking at this guy:
    https://www.electro-tech-online.com/...d-reset.17256/
    He's using a NPN transistor, and I notice he's missing a pull-down on the base of the NPN.
    I added labels to make it clear what attaches where, and I end up with this:
    Do you see a problem if I have the programmer on the slave PIC at the same time as the pin from master PIC is connected?
    I can always unconnect everything when I program, but I know "one day", I'm gonna rush and program with everything connected.
    The base of the transistor is grounded through R6. The other end of R6 is Vss, meaning ground.
    To Reset the system you have to feed high to the transistor in this circuit.
    I am a bit worry about the collector that is connected to a 100 ohm and this to the programmer. In programming, there might be 13 or more volts. At this time you have to be sure that the transistor will be in OFF state, that is [/MCLR Slave from master PIC] be low. If you can be sure of this then I see no problem.
    Yeah, this seems so sketchy to me. I'm thinking it would be safer to be able to connect only one at a time; either the programmer, or the master PIC.
    I ended up with this design, using tri-state pin on master to reset all the slaves when required. This will not be used for programming the slaves, only resets.
    Name:  Slave MCLR from master TRI-STATE.png
    It's simple, uses a single general I/O pin on master, and no extra components on slaves.
    I include that 100R res on slaves "just in case" I need them one day with my Pik-Kit.
    EDIT: For those that want to ICSP as well, look at the SN7407, and thank Mr E for the info (master on Input A, slave on Output Y)
  1. Master to slave 16F767
    By sachymo in forum General
    Last Post: - 3rd June 2008, 20:22
  2. I2C Master Slave issues.
    Last Post: - 29th March 2008, 19:33
  3. PIC master slave howto
    Last Post: - 18th September 2007, 22:35
  4. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 22:59
  5. i2c master/slave
    By lab310 in forum mel PIC BASIC Pro
    Last Post: - 8th April 2005, 22:23
