Discovering PIC 16F18446 - TOGGLE "ASM WARNING - Invalid RAM location"
Results 1 to 11 of 11
    SWITZERLAND (french speaking)
    Default Discovering PIC 16F18446 - TOGGLE "ASM WARNING - Invalid RAM location"
    ...only if you want your code to work correctly
    Who wouldn't?
    At this point, it's just about blinking that LED.
    But after that, how will I be able to avoid any such kind of "mistakes"?
    Please, please don't answer "Easy! Just rfm!!!"
    For week-ends hobbyist like me, is it better to stay with more "modest" PICs and/or always use workarounds like instead of:
    TOGGLE LATB.6
    PAUSE 500
    ...I should choose to stay with:
    LATB.6 = 1
    PAUSE 500
    LATB.6 = 0
    PAUSE 500
    Roger
    Default Re: Discovering PIC 16F18446 - TOGGLE "ASM WARNING - Invalid RAM location"
    it has nothing to do with with the pic chip at all. its simply incorrect usage of the pbp high level commands
    did you even look at the link i suggested ? i don't know why i bother
    all pbp "high level" commands that set a pin direction use a fixed offset to get to the tris reg
    it simply will not work correctly from a LATx offset [serout , serout2, toggle,high,low,i2cread........................... ....... ie all of them
    PORTx + offset always equals the TRISx register, LATx + offset does not equal the TRISx register ever
    if you don't believe my then look at the lst file generated by your code
    TOGGLE LATB.6
    PAUSE 500
    is improper use
    TOGGLE PORTB.6
    PAUSE 500
    is proper use
    LATB.6 = 1
    PAUSE 500
    LATB.6 = 0
    PAUSE 500
    is proper use
    latb.6=!latb.6
    PAUSE 500
    is proper use
  1. How to do the "SerIN" and "SerOut " for the usb ?
    By vicce67 in forum mel PIC BASIC Pro
    Last Post: - 13th March 2015, 03:01
  2. Replies: 0
    Last Post: - 14th November 2013, 04:32
  3. Replies: 3
    Last Post: - 15th October 2012, 09:06
  4. PBP 2.6/MPLab 8.33 ASM "COD" error message
    By reddog24 in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2009, 21:09
  5. Adding data to an "array" in ASM
    Last Post: - 22nd November 2009, 04:21
