OWOUT Glitch
Results 1 to 8 of 8
Thread: OWOUT Glitch
    Default OWOUT Glitch
    I'm using a PIC18F2680 at 32mhz
    I'm struggling with communicating with a DS18B20 sensor.
    I plugged my Saleae Logic analyser into the system and can see there is a glitch in the OWOUT $33 rom command at about 2.2ms.
    So the result is garbage..
    The DS18B20 does respond to the reset request though just prior to the above.
    DEFINE OSC 32           '8mhz Clock (x4 = 32mhz)
    OSCCON = %01110000      'Internal 32 mhz Osc and stable
    OSCTUNE = %01000000     'Enable PLL 8mhz x 4
    WDTCON = %00010101		'Set watchdog Timer for 1 second
    CCP1CON= %00001100		'CCP1 Module PWM Mode
    HLVDCON= %00000000		'HLVCON Disabled
    T1CON  = %00110000		'$30 = Prescaler 1:8, TMR1 OFF
    TRISA = %00000011 		'SET PORTA0.1,2 AS INPUT, REST AS OUTPUTS
    TRISB = %00001000 		'SET PORTB.3 AS INPUT REST AS OUTPUTS
    TRISC = %10000000 		'SET PORTC.7 AS INPUT REST AS OUTPUTS
    DQ          var PORTC.4     'One-wire Data-Pin "DQ" on PortC.4
    MainLoop:
        OWOUT DQ, 1, [$33]  ' Issue Read ROM command
        OWIN DQ, 0, [STR ID\8]' Read 64-bit device data into the 8-byte array "ID"
        lcdout LCM,LCL,LCM,L12,"Fam ",HEX2 ID[0],"h"
        lcdout LCM,L22,"Ser ",HEX2 ID[1],HEX2 ID[2],HEX2 ID[3],HEX2 ID[4],HEX2 ID[5],HEX2 ID[6],"h"
        lcdout LCM,L32,"CRC ",HEX2 ID[7],"h"
        PAUSE 500         '500ms second pause, replace sensor for next read
        lcdout LCM,LCL
    goto MainLoop
    See the weird glitch in the $33 bits being sent..
    Any ideas.
    Angry Re: OWOUT Glitch
    More testing reveals if I just change one Alias and then change the output the program works or doesn't.
    ChargerMain var PORTA.6 'Charger Mains Relay Out (OWOUT Works)
    low ChargerMain 'This Works
    high ChargerMain 'This Works
    ChargerMain var LATA.6 'Charger Mains Relay Out (OWOUT Fails if I do either of the next lines)
    low ChargerMain 'This Fails
    high ChargerMain 'This Fails
    If I don't do HIGH or LOW OWOUT works.
    It's not even the same PORT or BIT the DS18B20 sensor is connected to PORTC.4
    I don't see any PIC internal connection or multiplexing/alternate functions etc between A.6 and C.4
    Default Re: OWOUT Glitch
    not surprising at all. using pbp "high level" commands like HIGH,LOW is not allowable
    with LATX registers . its in the manual
    2.2.3 Use in High-Level Commands
    The data-direction is set automatically for most of the PBP high-level commands. If the command sends output, the pin is set for output. If the command reads the digital state of the pin, the pin will be set to input. PBP does not set the data-direction back to its original state after such commands are executed.
    Either the PORT.PIN designations or the aliases you have assigned may be used directly in PBP commands. For instance, there is no need to read a pin value to a variable before testing it. You can test an input pin directly with:
    IF switch = 0 THEN ' Check state of switch pin
    HIGH led1 ' LED on
    PAUSE 500 ' Delay 500mS
    LOW led1 ' LED off
    I2CREAD PORTB.5, PORTB.4, $A0, location,[B_val]
    Note the use of the HIGH and LOW commands in the preceding example. These are considered high-level commands because they do more than just set the bit in the PORTx register. They also set the data-direction to output.
    But why does doing something wrong with PORTA LAT affect PORTC????
    it doesn't, LOW lata.6 turns the PLL OFF as with HIGH lata.6
    porta address + 18 = trisa
    lata address + 18 = osctune on that chip [it varies]
    all pbp "high level" commands that set a pin direction use a fixed offset to get to the tris reg
    it simply will not work correctly from a LATx offset
    Thanks that explains it..
    using pbp "high level" commands with LATX registers is a great way to introduce hard to find bugs in your code
    5 stars
    Hi, Peter
    just some reading ... from that F... Manual, $ 5.27 :
    Since this command automatically sets the data-direction of the pin it acts on, the Pin parameter should only be a PORT or GPIO register (or an alias to a PORT or GPIO register). If the command is directed to act upon a LAT output or a bit within a variable or SFR, it will attempt to set a data-direction register that doesn't exist. The result may be unexpected behavior since a bit is changed in a seemingly random memory location. This can be very difficult to debug.
    B.R.
  1. NCO Glitch
    By mpgmike in forum mel PIC BASIC Pro
    Last Post: - 19th December 2017, 15:30
  2. OWIN - OWOUT problem
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 7th November 2011, 19:22
  3. Owin / owout
    By pyrogeek in forum mel PIC BASIC Pro
    Last Post: - 3rd September 2011, 09:08
  4. help on OWIN and OWOUT fucntion
    By eddy45 in forum Code Examples
    Last Post: - 10th September 2010, 11:04
  5. can i slowdown owin and owout
    By Eugen in forum mel PIC BASIC Pro
    Last Post: - 29th January 2005, 22:17
