Discovering PIC 16F18446 - TOGGLE "ASM WARNING - Invalid RAM location"
Results 1 to 11 of 11
    SWITZERLAND (french speaking)
    Default Discovering PIC 16F18446 - TOGGLE "ASM WARNING - Invalid RAM location"
    Hi there,
    I'm playing around the 16F18446.
    I just noticed the following:
    Name:  2024-02-17 22_02_55-PBP3 - Post New Thread.jpg
    I have used 73 words.
    Now I'm trying to go for TOGGLE so:
    Name:  2024-02-17 22_04_57-Clipboard.jpg
    I "spared" 4 words and the blinker still works.
    Do I have to care about this warning?
    Roger
    Default Re: Discovering PIC 16F18446 - TOGGLE "ASM WARNING - Invalid RAM location"
    substituting LATx registers for PORTx registers in pbp high level command statements will not work as you might hope
    it can introduce subtle and difficult to diagnose bugs, it also will never set the TRISx registers in the manner those statements expect
    only if you want your code to work correctly
    see this
    https://www.picbasic.co.uk/forum/sho...1-OWOUT-Glitch
    Since the introduction of LAT registers, I cannot remember where I read it, maybe it was in Melabs either help file or this forum, we had to use LAT instead of PORT registers.
    Οn some PIC it will not work properly.
    But I have not found an explanation on this matter.
    ...only if you want your code to work correctly
    Who wouldn't?
    At this point, it's just about blinking that LED.
    But after that, how will I be able to avoid any such kind of "mistakes"?
    Please, please don't answer "Easy! Just rfm!!!"
    For week-ends hobbyist like me, is it better to stay with more "modest" PICs and/or always use workarounds like instead of:
    TOGGLE LATB.6
    PAUSE 500
    ...I should choose to stay with:
    LATB.6 = 1
    PAUSE 500
    LATB.6 = 0
    PAUSE 500
    Roger
    it has nothing to do with with the pic chip at all. its simply incorrect usage of the pbp high level commands
    did you even look at the link i suggested ? i don't know why i bother
    all pbp "high level" commands that set a pin direction use a fixed offset to get to the tris reg
    it simply will not work correctly from a LATx offset [serout , serout2, toggle,high,low,i2cread........................... ....... ie all of them
    PORTx + offset always equals the TRISx register, LATx + offset does not equal the TRISx register ever
    if you don't believe my then look at the lst file generated by your code
    TOGGLE LATB.6
    PAUSE 500
    is improper use
    TOGGLE PORTB.6
    PAUSE 500
    is proper use
    LATB.6 = 1
    PAUSE 500
    LATB.6 = 0
    PAUSE 500
    is proper use
    latb.6=!latb.6
    PAUSE 500
    is proper use
    TRY THIS
    ' PIC 16F18446
        __config _CONFIG1, _FEXTOSC_OFF & _RSTOSC_HFINT1 & _CLKOUTEN_OFF & _CSWEN_ON & _FCMEN_ON
        __config _CONFIG2, _MCLRE_ON & _PWRTS_PWRT_64 & _LPBOREN_OFF & _BOREN_SBOREN & _BORV_LO & _ZCDDIS_OFF & _PPS1WAY_OFF & _STVREN_ON
        __config _CONFIG3, _WDTCPS_WDTCPS_31 & _WDTE_SWDTEN & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
        __config _CONFIG4, _BBSIZE_BB512 & _BBEN_OFF & _SAFEN_OFF & _WRTAPP_OFF & _WRTB_OFF & _WRTC_OFF & _WRTD_OFF & _WRTSAF_OFF & _LVP_OFF
        __config _CONFIG5, _CP_OFF
        ANSELB = $B0;
        OSCCON1 = $60; // CSWHOLD may proceed; SOSCPWR Low power;
        OSCCON3 = 0;  // MFOEN disabled; LFOEN disabled; ADOEN disabled; SOSCEN disabled; EXTOEN disabled; HFOEN disabled;
        OSCEN = 0 ;    // HFFRQ 4_MHz;
        OSCFRQ = 2;  // HFTUN 0;
        OSCTUNE = 0
    ' ====== TEST PROGRAM ==============================================================================
    TEST:
        TOGGLE PORTB.6
    GOTO TEST
    THEN THIS
    ' PIC 16F18446
        ANSELB = $B0;
        OSCTUNE = 0
    TEST:
        TOGGLE LATB.6
    GOTO TEST
    WHICH ONE WORKS ?
    Richard,
    Sorry for my late reply.
    First or upper code in your previous message dosen't work. The LED is steady ON and no warning message.
    Lower or second code doesn't work either; no LED blinking AND I do have the warning message showing up again.
    And "yes", I went to read the post you pointed me at.
    Currently, this is the code that will make the LED blink and have no warnings after compiling:
    ' PIC 16F18446
    ' ====== REGISTERS SETTINGS =======================================================================
    TRISB.6 = 0
    ' Oscillator Control Register1
    OSCCON1 = %01100000 ' $60
    ' HFFRQ - Oscillator's Frequency Selection Register
    OSCFRQ  = %00000010 ' 4MHz
    TEST:
        LATB.6 = 1
        PAUSE 500
        LATB.6 = 0
        PAUSE 500
    GOTO TEST
    Roger
    That is the proper way to do it.
    this works perfectly for me, i doubt you implemented it exactly as posted
    i notice you don't set the pins used to digital mode
    another correct way
    ' PIC 16F18426
        ANSELC = $DF;
        OSCTUNE = 0
    TEST:
        TOGGLE PORTC.5
    GOTO TEST
    Last edited by richard; - 24th February 2024 at 23:49. Reason: i cant use b6 on a 16f18426 my closest match
    Richard, this is your exact code (no changes at all) and it lights the LED steady ON:
    ' PIC 16F18446
        ANSELB = $B0;
        OSCTUNE = 0
    TEST:
        TOGGLE PORTB.6
    GOTO TEST
    Unfortunately, the third example dosen't work either, this one:
    ' PIC 16F18426
        ANSELC = $DF;
        OSCTUNE = 0
    TEST:
        TOGGLE PORTC.5
    GOTO TEST
    Maybe this last code doesnt work because you seem to use a 16F8246 not a 16F18446 like I have.
    Honestly, I can have a real good life with LATBs commands instead of TOGGLEs
    Roger
    TOGGLE will not work.
    Richard did explain why at post #5.
    So, you have to use either directly PORT or LAT commands. Personally, never liked the TOGGLE command and always preferred to use discrete commands. Bonus that you know the final state of the register. With TOGGLE you only know that it has changed. Not how.
  1. How to do the "SerIN" and "SerOut " for the usb ?
    By vicce67 in forum mel PIC BASIC Pro
    Last Post: - 13th March 2015, 03:01
  2. Replies: 0
    Last Post: - 14th November 2013, 04:32
  3. Replies: 3
    Last Post: - 15th October 2012, 09:06
  4. PBP 2.6/MPLab 8.33 ASM "COD" error message
    By reddog24 in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2009, 21:09
  5. Adding data to an "array" in ASM
    Last Post: - 22nd November 2009, 04:21
