picbasic pro optimizations
Results 1 to 11 of 11
    Jun 2005
    Question picbasic pro optimizations
    Cliff Griffin lists several picbasic pro optimizations at http://www.rcfaq.com/PIC/optimize.htm. Are there more optimization tips?
    @ incf _Time ,1
    This compiles two words shorter, but is functionally equivalent to
    Time = Time + 1
    If... AND... Then's
    Using two IF commands saves five words
    looptest:
    'if (i=1) and (k=1) then looptest
    Instead, use this technique:
    if i=1 then
    if k=1 then looptest
    You might want to be carefull with those techniques.
    The way they save code space is by bypassing the normal Bank switching, and Code Page changes that PBP needs to keep track of, to continue working correctly. Under the right circumstances they can indeed save Code Space.   But, just at the time when you "Need" to have the program working, you'll be chasing bugs that seem like they "Just can't be happening". He hints at the problem with a "NOTE:" but I think it's more serious than that.   Especialy with large programs. A.K.A. Harder to Debug.
    Granted, others are valid, like separating "ANDed" IF statements etc. But, bypassing PBP's internal processes can be risky.
    Jun 2005
    Smile
    Darrel,
    Thanks for the reply and caution.
    I was surprised there wasn't more discussion on optimizing for performance
    and saving code space on the forum. I have only written a few picbasic programs. I try to save codespace and sometimes improve speed.
    Thanks for posting your averaging routine, I recommended it a few times.
    Mark
    Somethig interesting to use http://www.picbasic.co.uk/forum/showthread.php?t=2418
    Really handy to compare between 2 piece of code.
    There's always a midpoint between a tight code and a 'bullet proof' code. Yes it's interesting to have some way to reduce code size but if it gives more potential bugs or headache... will you aprreciate your tight code even if it gaves you extra debug hours? I don't think so
    PBP is stable and mature, i don't like to play with his internal ressource to save few bytes only to save few cents by choosing a smaller PIC to do the job. well it's my opinion after doing that on a full 64K of code.... yeah it's working fine now.. no problem at all. I just hope to have a 28Pin device with much codespace one day... probably there's already one that i didn't see. I'd use a 18F2680. Code overlay could be an option at that time... i'd just challenge myself to fit everything in the same PIC.
    about the speed... depending how critical your application is, using a higher crystal speed or use some assembler line could do the job as well.
    each project is different so i don't think there's an universal way to do one thing.
    Using built-in function for an application that don't need all the bells and ring and data handling include in the built-in function like ADCIN,SEROUT, HSEROUT,HSEROUT,HPWM and much other is often killer. Save code space by writing/reading directly to the internal register is the way to go. In many case, it will be done much faster too. Oh yeah much tricky... of course, but you have the full control of!
    How to save code space, how to write a program is an endless story. In many case, i'll prefer the internal register way against built-in function... well for my own application. To teach to someone else, to do some test, the use of built-in function seems to be easier/faster to understand.
    HTH
    Mark,
    Hey, glad you like the averaging routine. I was wondering if you could do me a favor? &nbsp; I made a modification to it a little while ago. &nbsp; You know how the least sigificant digit will "wobble" back and forth between 2 numbers? It's half-way between 2 numbers and it can't quite figure out which one it should be. &nbsp; Well, the modification adds hysterisis to the averaging routine to eliminate that.
    None of my current projects use the averaging, so I haven't had a chance to test it yet. &nbsp; I gave it to someone else, but never heard back from him. I assume that means it worked.
    If you have some extra time, maybe you could try this out.
    '*  Name    : Average_Hyst.pbp                                  *
    '*  Author  : Darrel Taylor                                     *
    '*  Date    : 7/19/2005                                         *
    '*  Version : 3.0                                               *
    '*  Notes   : Modified to use Hysterisis                        *
    '*          : Use as an INCLUDE file                            *
    ' This routine will keep a "Running Average" of 10-bit Analog Values
    ' Instead of adding a bunch of values together and then dividing by the number
    ' of samples, it averages each sample into the final result immediately.
    ' This eliminates the need for 32 bit math.
    ' To allow it to "Catch up" to large changes, set the FAspread to an
    ' acceptable range.
    ' Simply place the new number in VALUE and GoSub Average
    ' The Average (with Hysterisis) will be returned into the same variable VALUE
    '---- [ User Options ] ---------------------------------------------------------
    HystLevel   CON  7      ' 7 = .7 of the Least Significant Digit
                            '    Valid HystLevel is from 6 to 13
    AvgCount    CON  16     ' = Number of samples to average. For best response
                            '    times, keep AvgCount as small as you can
    FAspread    CON  50     ' = Fast Average threshold +/-
                            '  FAspread should be larger than the worst possible
                            '  noise in the A/D conversion.
    AVGchanged  VAR  BIT    ' 1 indicates that the Average Value has changed
                            ' you have to clear this bit after using it
    ADavg       VAR  WORD   ' Stores the current Average
    ADhyst      VAR  WORD   ' Stores the current Value for Hysterisis
    Value       VAR  WORD   ' Input / Output variable to be averaged
    spread      CON  FAspread * 10  ' adjust spread *10 for Hyst.
    GOTO OverAverage
    ' -=-=-=-=-=-=  Average Analog values -=-=-=-=-=-=-=-=-=-=
    Average:
        Value = Value * 10                      ' Scale value up for hysterisis
        IF Value = ADavg Then NoChange          ' if they're the same, nothing to do
        IF ABS (Value - ADavg) > spread OR Value < AvgCount Then FastAvg
        IF ABS (Value - ADavg) < AvgCount Then RealClose
        ADavg = ADavg - (ADavg/AvgCount)         ' Subtract 1 samples worth
        ADavg = ADavg + (Value/AvgCount)         ' Add in the new sample portion
        GoTo AVGok
      FastAvg:                                   ' Catch up to the changing value
        ADavg = Value                            ' Set Average to the current value
        GoTo AVGok
      RealClose:                                 ' Reduce the sample size when
        ADavg = ADavg - (ADavg/(AvgCount/4))     ' the average and the sample are
        ADavg = ADavg + (Value/(AvgCount/4))     ' "Real Close"
      AVGok:
        IF ABS (ADavg - ADhyst) > HystLevel then ' If it changed > HystLevel +/-
            ADhyst = ((ADavg + 5) / 10) * 10     ' Round ADavg to get new Value
            AVGchanged = 1                       ' Indicate that Average changed
      NoChange:
        Value = ADhyst / 10                      ' Scale the result down
    OverAverage:
    Jun 2005
    Darrel,
    I will gladly test your new modifications and post the results here after
    I return from a business trip next week!
    Mark
  1. VB.net and Picbasic Pro
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 15th November 2007, 21:18
  2. How to configure SPI in PICBASIC PRO?
  3. Replies: 0
    Last Post: - 22nd November 2005, 14:16
  4. Question for all that use MELABS PICBASIC PRO
    By oskuro in forum Off Topic
    Last Post: - 24th March 2005, 18:15
  5. PicBasic Pro & PicBasic syntax different
    By Billyc in forum General
    Last Post: - 16th April 2004, 22:19
