symmetric power supply pic 16f877a
Results 1 to 16 of 16
    0 out of 1 members found this post helpful. Did you find this post helpful? Yes | No
    Default Re: symmetric power supply pic 16f877a
    Depends on how one is looking the case.
    Richard did his best nailing your problem and suggesting a solution. If it is not what you expected, well, OK.
    In any case this forum helped many and does have a whealth of info and solutions.
    Sorry you feel that way.
    Jul 2022
    The solution provided by Richard did not solve the problem for me, I had to correct the following in the code:
    'pv LCDOUT $FE,$A3," clean negative voltage
    LCDOUT $FE,$A3
    'pv LCDOUT $FE,$E3," " clean positive voltage
    LCDOUT $FE,$E3
  1. symmetric source code pic 16f877a
    By joseluisatmega8 in forum mel PIC BASIC Pro
    Last Post: - 30th August 2018, 13:30
  2. 0-60 vdc power supply controlled by pic 0-5vdc
    By chuzkin in forum Schematics
    Last Post: - 22nd April 2014, 22:15
  3. PIC power supply basics
    By shottootto in forum General
    Last Post: - 19th December 2013, 14:58
  4. PIC backup power supply: switchover ???
    Last Post: - 18th April 2008, 18:05
  5. Decent 24 volt Pic power supply
    By rwskinner in forum Schematics
    Last Post: - 18th December 2006, 13:27
