symmetric power supply pic 16f877a
Results 1 to 16 of 16
    0 out of 1 members found this post helpful. Did you find this post helpful? Yes | No
    Default Re: symmetric power supply pic 16f877a
    Get rid of Floating point. All will be much more smoother.
    Either you like it or not, Richard has nailed the problems. If I were you, I would read carefully his suggestions.
    Jul 2022
    If I eliminated the floating point, the positive and negative voltages would NOT be the same as those recorded by the voltmeters in the Proteus simulation. attached proteus simulation image I also attach the old code when I started to make the code with the first code the negative and positive voltages are different. so i expanded the code and now the negative and positive voltages are flashing, but the negative and positive voltages that register on lcd 20 x4 are the same as the voltmeters in the proteus simulation. if it won't help don't comment
    DEFINE LCD_DREG PORTD
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTE
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTE
    DEFINE LCD_EBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE ADC_ SAMPLEUS 50
    TRISC.6 = 0
    TRISC.7 = 1
    TRISA = 255
    ADCON1 = %11000010
    TRISB.6 = %0
    LED VAR PORTB.6
    B1 VAR WORD
    B2 VAR WORD
    VALOR1 VAR BYTE
    VALOR2 VAR BYTE
    STAR:
    ADCIN 1, B1
    ADCIN 2, B2
    VALOR1=B1/9
    VALOR2=B2/12
    SEROUT2 PORTC.6,188,["$", "$", DEC4 B1,"$", "$",DEC4 B2,10,13]
    LCDOUT $FE,2," SYMMETRIC FONT "
    LCDOUT $FE,$C4," JOSE LUIS "
    LCDOUT $FE,$90," VOLTAGE NEGATIVE:-",DEC2 VALOR1
    LCDOUT $FE,$D0," VOLTAGE POSITIVE:+",DEC2 VALOR2
    HIGH LED
    GOTO STAR
    1 out of 2 members found this post helpful. Did you find this post helpful? Yes | No
    10 bit adc @5v <=> .00488 volts per count
    point A2 in sch = @1.76 v ie. 360 counts
    360/12=30
    this is the displayed result. what were you expecting
    there is no visible relationship between A2 voltage and any other shown point in the sch.
    how A1 voltage is derived is unknowable
    pic vcc is a guess
    just found this, no wonder i felt i had seen it all before
    http://www.picbasic.co.uk/forum/showthread.php?t=24035
    still finding the same lack of detail
  1. symmetric source code pic 16f877a
    By joseluisatmega8 in forum mel PIC BASIC Pro
    Last Post: - 30th August 2018, 12:30
  2. 0-60 vdc power supply controlled by pic 0-5vdc
    By chuzkin in forum Schematics
    Last Post: - 22nd April 2014, 21:15
  3. PIC power supply basics
    By shottootto in forum General
    Last Post: - 19th December 2013, 13:58
  4. PIC backup power supply: switchover ???
    Last Post: - 18th April 2008, 17:05
  5. Decent 24 volt Pic power supply
    By rwskinner in forum Schematics
    Last Post: - 18th December 2006, 12:27
