symmetric power supply pic 16f877a
Results 1 to 16 of 16
    Jul 2022
    Default Re: symmetric power supply pic 16f877a
    Since nobody wanted to help me in this forum, I wanted to try again in this forum. is there a problem? if you are not going to help, do not criticize
    0 out of 1 members found this post helpful. Did you find this post helpful? Yes | No
    is there a problem?
    i doubt many would risk unvetted content from google drive, youtube would be safer.
    there is no config settings in your code.
    what type of osc and speed.
    what have you tried to port code to 16f886 and what happened.
    does it work on a 16f877a.
    has it ever worked or is it just a proteus simulation, proteus does not really work for some real time things.
    there is no schematic.
    why use fp ,can you really expect accuracy to 2 decimals.
    what does symmetric power supply pic 16f877a mean ,the code is just a display
    but the voltages flicker and do not complain fixed, what does this mean , are the voltages out of control or is it the the readings
    two dp accuracy from single asynchronous adc results is not plausible afaics esp without a stable voltage reference for adc
    Jul 2022
    In the google drive link I uploaded a video of the proteus simulation of the code with the negative and positive voltages flashing. the code works with pic 16f877a, microchip announced that it will stop making pic 16f877a and i want to migrate the code to work with pic 16f886. In addition, anyone can make a symmetrical source, in my case I implement a digital indicator with a pic and use an operational amplifier in inverter mode to input negative voltage to the pic, use a voltage divider for the positive input and not damage the adc of the pic. If it won't help, don't comment.
    Get rid of Floating point. All will be much more smoother.
    Either you like it or not, Richard has nailed the problems. If I were you, I would read carefully his suggestions.
    Jul 2022
    If I eliminated the floating point, the positive and negative voltages would NOT be the same as those recorded by the voltmeters in the Proteus simulation. attached proteus simulation image I also attach the old code when I started to make the code with the first code the negative and positive voltages are different. so i expanded the code and now the negative and positive voltages are flashing, but the negative and positive voltages that register on lcd 20 x4 are the same as the voltmeters in the proteus simulation. if it won't help don't comment
    DEFINE LCD_DREG PORTD
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTE
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTE
    DEFINE LCD_EBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE ADC_ SAMPLEUS 50
    TRISC.6 = 0
    TRISC.7 = 1
    TRISA = 255
    ADCON1 = %11000010
    TRISB.6 = %0
    LED VAR PORTB.6
    B1 VAR WORD
    B2 VAR WORD
    VALOR1 VAR BYTE
    VALOR2 VAR BYTE
    STAR:
    ADCIN 1, B1
    ADCIN 2, B2
    VALOR1=B1/9
    VALOR2=B2/12
    SEROUT2 PORTC.6,188,["$", "$", DEC4 B1,"$", "$",DEC4 B2,10,13]
    LCDOUT $FE,2," SYMMETRIC FONT "
    LCDOUT $FE,$C4," JOSE LUIS "
    LCDOUT $FE,$90," VOLTAGE NEGATIVE:-",DEC2 VALOR1
    LCDOUT $FE,$D0," VOLTAGE POSITIVE:+",DEC2 VALOR2
    HIGH LED
    GOTO STAR
    1 out of 2 members found this post helpful. Did you find this post helpful? Yes | No
    10 bit adc @5v <=> .00488 volts per count
    point A2 in sch = @1.76 v ie. 360 counts
    360/12=30
    this is the displayed result. what were you expecting
    there is no visible relationship between A2 voltage and any other shown point in the sch.
    how A1 voltage is derived is unknowable
    pic vcc is a guess
    just found this, no wonder i felt i had seen it all before
    http://www.picbasic.co.uk/forum/showthread.php?t=24035
    still finding the same lack of detail
  1. symmetric source code pic 16f877a
    By joseluisatmega8 in forum mel PIC BASIC Pro
    Last Post: - 30th August 2018, 13:30
  2. 0-60 vdc power supply controlled by pic 0-5vdc
    By chuzkin in forum Schematics
    Last Post: - 22nd April 2014, 22:15
  3. PIC power supply basics
    By shottootto in forum General
    Last Post: - 19th December 2013, 14:58
  4. PIC backup power supply: switchover ???
    Last Post: - 18th April 2008, 18:05
  5. Decent 24 volt Pic power supply
    By rwskinner in forum Schematics
    Last Post: - 18th December 2006, 13:27
