symmetric power supply pic 16f877a
Results 1 to 16 of 16
    Jul 2022
    Unhappy symmetric power supply pic 16f877a
    best regard
    I come to you for help to improve my programming code for a symmetrical digital power supply.
    well the code one part is in Spanish and the other is in English.
    In the simulation with Proteus negative voltage and positive voltage are displayed, but the voltages flicker and do not complain fixed, and I want these values to remain fixed.
    I also want to change pic 16f877a for pic 16f886
    I have also seen on the microchip page that the pic 16f877a will no longer be manufactured, in the electronic stores I could not find it, they are out of stock.
    I enclose the code, and link of the video and you will see the voltage flashing.
    I hope and help me improve my code, thanks
    Joseph
    include "fp2032.bas" ' Include file for 14-bit core with RAM at $20 (32-bit)
    DEFINE LCD_DREG PORTD
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTE
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTE
    DEFINE LCD_EBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE ADC_ SAMPLEUS 50
    ' Definición de puertos y variables
    LED VAR PORTB.6 'Define el led en el pin 6 del puerto B
    TXD VAR PORTC.6 'Define el pin de transmision serial en el pin 6 del puerto C
    B1 VAR WORD
    B2 VAR WORD
    VALOR1 VAR BYTE
    VALOR2 VAR BYTE
    fpplaces var byte ' Used to define number of decimal places in fpdisplay,fpdisplayr
    ahold var word ' Required by fpdisplay
    bhold var word ' Required by fpdisplay
    ' Inicio del programa principal
    INICIO:
    TRISC.6 = 0 'Configura puerto RC6 como salida
    TRISC.7 = 1 'Configura puerto RC7 como entrada
    TRISA = 255 'Configura puerto A como entrada
    ADCON1 = %11000010 'Justifica el resultado hacia la izquierda
    TRISB.6 = 0 'Configura puerto RB6 como salida
    LCDOUT $FE,2," FUENTE SIMETRICA "
    LCDOUT $FE,$C0," JOSE LUIS COMAS LL "
    LCDOUT $FE,$94,"VOLT.NEGATIVO:-"
    LCDOUT $FE,$D4,"VOLT.POSITIVO:+"
    COMENZAR:
    ADCIN 1, B1 'Lee el voltaje negativo en el canal 1 del ADC
    ADCIN 2, B2 'Lee el voltaje positivo en el canal 2 del ADC
    'Envia los valores del ADC a la terminal
    SEROUT2 TXD,188,["$", "$", DEC4 B1,"$", "$",DEC4 B2,10,13]
    aint = B1 'Transfiere el valor del ADC del voltaje negativo
    gosub itofa 'Conviertelo a punto flotante
    bint = 2000 'Carga el valor 2000 (5*400)
    gosub itofb 'Conviertelo en punto flotante
    gosub fpmul 'ADCres * 2000
    bint = 52224 'Carga el valor de la cuenta maxima del ADC * 51
    GOSUB fpdiv '(ADCres * 2000)/52224
    LCDOUT $FE,$A3," " 'Limpia el espacio donde se coloca el voltaje negativo
    LCDOUT $FE,$A3
    fpplaces = 2 : Gosub fpdisplayr ' Call display routine
    aint = B2 'Transfiere el valor del ADC del voltaje positivo
    bint = 35 'Carga el valor 35 (5*7)
    gosub fpmul 'ADCres * 35
    bint = 1024 'Carga el valor de la cuenta maxima del ADC
    GOSUB fpdiv '(ADCres * 35)/1024
    LCDOUT $FE,$E3," " 'Limpia el espacio donde se coloca el voltaje positivo
    LCDOUT $FE,$E3
    HIGH LED
    GOTO COMENZAR
    ' The fpdisplayr routine checks for number of places, then adds the appropriate
    ' value to achieve rounding. To save RAM space, the values are hard coded
    ' in floating point format.
    fpdisplayr: If fpplaces=0 Then ' Set floating point barg to 0.5
    bexp = $7E
    bargb0 = $00
    bargb1 = $00
    bargb2 = $01
    Endif
    If fpplaces=1 Then ' Set floating point barg to 0.05
    bexp = $7A
    bargb0 = $4C
    bargb1 = $CC
    bargb2 = $CD
    Endif
    If fpplaces=2 Then ' Set floating point barg to 0.005
    bexp = $77
    bargb0 = $23
    bargb1 = $D7
    bargb2 = $0B
    Endif
    If fpplaces=3 Then ' Set floating point barg to 0.0005
    bexp = $74
    bargb0 = $03
    bargb1 = $12
    bargb2 = $6F
    Endif
    If fpplaces=4 Then ' Set floating point barg to 0.00005
    bexp = $70
    bargb0 = $51
    bargb1 = $B7
    bargb2 = $17
    Endif
    Gosub fpadd ' add barg to aarg
    ' The fpdisplay routine outputs the signed value of aarg in decimal floating point format. It
    ' can display a positive value of 65535, and decimals to 4 places. The number of decimal
    ' places should be stored in fpplaces before calling the routine. The routine reads the
    ' floating point value of aarg. This value should NOT be converted to an integer before
    ' calling fpdisplay. The integer conversion will be perfomed as part of this routine, and
    ' aint will be returned to the calling program just as from the itofa routine.
    fpdisplay: bexp = aexp ' Store the FP value of aarg to the barg variables
    bargb0 = aargb0
    bargb1 = aargb1
    bargb2 = aargb2
    Gosub ftoia ' Convert aarg to integer
    ahold = aint ' Save this value for the final display
    Gosub itofa ' Convert integer back to float
    Swap aexp,bexp ' Swap the FP values of aarg and barg before subtraction
    Swap aargb0,bargb0
    Swap aargb1,bargb1
    Swap aargb2,bargb2
    Gosub fpsub ' Subtract the integer portion from the full number
    bint = 10 ' Make bint = 10 E fpplaces
    If fpplaces=2 Then
    bint = 100
    Endif
    If fpplaces=3 Then
    bint = 1000
    Endif
    If fpplaces=4 Then
    bint = 10000
    Endif
    bhold = bint ' Save the integer value of bint for zeros loop
    Gosub itofb ' Convert bint to integer prior to FP multiply
    Gosub fpmul ' Multiply the decimal portion x 10 E fpplaces
    Gosub ftoia ' Convert result to aint integer
    Lcdout dec ahold ' Display integer portion
    If fpplaces > 0 Then
    Lcdout "." ' Display decimal point
    zeros: bhold = bhold / 10 ' Set bhold to be next place to right
    If (aint < bhold) AND (bhold > 1) Then ' Check for leading zero in decimal
    Lcdout "0" ' Display leading zero
    Goto zeros ' loop to check for another zero
    Endif
    Lcdout dec aint ' Display the rest of the decimal portion
    Endif
    aint = ahold ' Restore the original value of aint
    https://drive.google.com/file/d/19zVIgpcGwliJ5BENU3GAp1xTRELDTNa4/view
    link of video
    0 out of 1 members found this post helpful. Did you find this post helpful? Yes | No
    Default Re: symmetric power supply pic 16f877a
    Hi, Josepic
    you should avoid floating point calculations ... it consumes much much time, and your flickering problems probably only come because of that ...
    remember the ADC is only 10 bits, so, no need to look for more than .1% to be displayed !
    Jul 2022
    Talking Re: symmetric power supply pic 16f877a
    can you please help me by correcting the friend code?
    its just like deja vu all over again
    https://support.melabs.com/forum/pic...de-pic-16f877a
    4 years later still the same scant detail
    Jul 2022
    Since nobody wanted to help me in this forum, I wanted to try again in this forum. is there a problem? if you are not going to help, do not criticize
    is there a problem?
    i doubt many would risk unvetted content from google drive, youtube would be safer.
    there is no config settings in your code.
    what type of osc and speed.
    what have you tried to port code to 16f886 and what happened.
    does it work on a 16f877a.
    has it ever worked or is it just a proteus simulation, proteus does not really work for some real time things.
    there is no schematic.
    why use fp ,can you really expect accuracy to 2 decimals.
    what does symmetric power supply pic 16f877a mean ,the code is just a display
    but the voltages flicker and do not complain fixed, what does this mean , are the voltages out of control or is it the the readings
    two dp accuracy from single asynchronous adc results is not plausible afaics esp without a stable voltage reference for adc
    Jul 2022
    In the google drive link I uploaded a video of the proteus simulation of the code with the negative and positive voltages flashing. the code works with pic 16f877a, microchip announced that it will stop making pic 16f877a and i want to migrate the code to work with pic 16f886. In addition, anyone can make a symmetrical source, in my case I implement a digital indicator with a pic and use an operational amplifier in inverter mode to input negative voltage to the pic, use a voltage divider for the positive input and not damage the adc of the pic. If it won't help, don't comment.
    Get rid of Floating point. All will be much more smoother.
    Either you like it or not, Richard has nailed the problems. If I were you, I would read carefully his suggestions.
    Jul 2022
    If I eliminated the floating point, the positive and negative voltages would NOT be the same as those recorded by the voltmeters in the Proteus simulation. attached proteus simulation image I also attach the old code when I started to make the code with the first code the negative and positive voltages are different. so i expanded the code and now the negative and positive voltages are flashing, but the negative and positive voltages that register on lcd 20 x4 are the same as the voltmeters in the proteus simulation. if it won't help don't comment
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    TRISC.6 = 0
    TRISC.7 = 1
    TRISA = 255
    ADCON1 = %11000010
    TRISB.6 = %0
    LED VAR PORTB.6
    B1 VAR WORD
    B2 VAR WORD
    VALOR1 VAR BYTE
    VALOR2 VAR BYTE
    STAR:
    ADCIN 1, B1
    ADCIN 2, B2
    VALOR1=B1/9
    VALOR2=B2/12
    SEROUT2 PORTC.6,188,["$", "$", DEC4 B1,"$", "$",DEC4 B2,10,13]
    LCDOUT $FE,2," SYMMETRIC FONT "
    LCDOUT $FE,$C4," JOSE LUIS "
    LCDOUT $FE,$90," VOLTAGE NEGATIVE:-",DEC2 VALOR1
    LCDOUT $FE,$D0," VOLTAGE POSITIVE:+",DEC2 VALOR2
    HIGH LED
    GOTO STAR
    1 out of 2 members found this post helpful. Did you find this post helpful? Yes | No
    10 bit adc @5v <=> .00488 volts per count
    point A2 in sch = @1.76 v ie. 360 counts
    360/12=30
    this is the displayed result. what were you expecting
    there is no visible relationship between A2 voltage and any other shown point in the sch.
    how A1 voltage is derived is unknowable
    pic vcc is a guess
    just found this, no wonder i felt i had seen it all before
    http://www.picbasic.co.uk/forum/showthread.php?t=24035
    still finding the same lack of detail
    Jul 2022
    attached in .zip format the simulation in proteus. to visualize the simulation of the symmetric source
    zip files from a unvetted source , no thanks
    a screen shot or a simple description of how A2 is derived and an explanation of how that voltage is to be displayed would help
    its a simple thing.
    you have two voltages A1 and A2 to be read by adc , that reading needs to scaled to display a value representing the supply outputs
    A1 and A2 obviously must have a fixed linear relationships to those outputs to get meaningful results.
    a 16f886 can do it just as well as a 16f877a can
    if you want more than 1 dp resolution you need to employ some oversampling
    to get a stable reading some low pass filtering is required , analog or digital or both
    Jul 2022
    I have solved my problem of flickering of the negative and positive voltages, change in the source code the pic 16f877a and use the pic 16f886.
    the only thing left for me is to buy pic 16f886 and design the pcb for the symmetrical source and present the project to the university.
    I really received little help in this forum
    Depends on how one is looking the case.
    Richard did his best nailing your problem and suggesting a solution. If it is not what you expected, well, OK.
    In any case this forum helped many and does have a whealth of info and solutions.
    Sorry you feel that way.
    Jul 2022
    The solution provided by Richard did not solve the problem for me, I had to correct the following in the code:
    'pv LCDOUT $FE,$A3," clean negative voltage
    LCDOUT $FE,$A3
    'pv LCDOUT $FE,$E3," " clean positive voltage
    LCDOUT $FE,$E3
  1. symmetric source code pic 16f877a
    By joseluisatmega8 in forum mel PIC BASIC Pro
    Last Post: - 30th August 2018, 12:30
  2. 0-60 vdc power supply controlled by pic 0-5vdc
    By chuzkin in forum Schematics
    Last Post: - 22nd April 2014, 21:15
  3. PIC power supply basics
    By shottootto in forum General
    Last Post: - 19th December 2013, 13:58
  4. PIC backup power supply: switchover ???
    Last Post: - 18th April 2008, 17:05
  5. Decent 24 volt Pic power supply
    By rwskinner in forum Schematics
    Last Post: - 18th December 2006, 12:27
