I2C problems
Results 1 to 3 of 3
Thread: I2C problems
    Mad_Labs's Avatar
    Mad_Labs Guest
    Default I2C problems
    Hi All,
    I'm having trouble with I2C. I am trying to communicate with a MAX6953, which is a 5x7 LED matrix display driver. I have had the device up and running with a Stamp, but can't get it to work with a PIC.
    The PIC I am using is the 16F88. I am using the internal OSC at 8mHz. I am using portb.0 for SDA and portb.1 for SCL. I have tried using the DEFINE I2C_Slow.
    Any ideas what could be causing the problem?
    Jonathan
    Defines should all be in UPPERCASE and ensure you check your SPELLINGS of them, as they may not flag errors in any compilation...
    http://www.picbasic.co.uk/forum/showthread.php?t=558
    I2CREAD and I2CWRITE are really easy to fly with no issues providing you follow the rules in the PICBasic manual...
    http://www.picbasic.co.uk/forum/showthread.php?t=587
    Please do check the FAQ's...
    Mad_Labs's Avatar
    Mad_Labs Guest
    Melanie,
    I had checked the FAQ, your posts and the book. The problem turned out to be (after mucho hair pulling) a bum PIC pin.
    Thanks for the help tho!
    Jonathan
  1. I2C Master/Slave 16F88/16F767 working code
    By DanPBP in forum Code Examples
    Last Post: - 23rd October 2012, 22:31
  2. HARDWARE I2C SAMPLE CODE question
    By Michael Wakileh in forum Code Examples
    Last Post: - 16th June 2009, 21:07
  3. I2C Read/Write problems
    By Dispersion123 in forum mel PIC BASIC Pro
    Last Post: - 5th April 2008, 15:11
  4. I2C Master Slave issues.
    By cpayne in forum mel PIC BASIC Pro
    Last Post: - 29th March 2008, 19:33
  5. Please help with i2cslave i2c slave
    By cycle_girl in forum mel PIC BASIC Pro
    Last Post: - 1st December 2005, 13:55
