Joining 5 bit variables and splitting them into 8 bit ones later?
Results 1 to 24 of 24
    Default Re: Joining 5 bit variables and splitting them into 8 bit ones later?
    proof of concept
    btw i like your font it looks better than my 6x5 one
    sorry for shaky vid , was trying to use mouse while steering phone , failed both accounts
    Well, I'm designing fonts for last 30 years, so no surprise mine is better
    proof of concept of what?
    Any code was posted?
    basically this , modded slightly for the 4x8 font
    http://www.picbasic.co.uk/forum/showthread.php?t=24171
    And this is proof of my code working
    So if I understood correctly, there is no HSHIFTOUT statement, like HSEROUT ?
    But I still have an issue - why reading from a bit array from arbitrary position (not byte justified) returns garbage?
    a minimal, complete and verifiable example MCVE
    https://stackoverflow.com/help/minim...ucible-example
    here is one that shows no problem at all pbp3, examination of lst file confirms reservation of the 4 bytes required for the bit array
    if there was ever any doubt
    ; pbp3 16f1825
    define OSC 32
                 __config        _CONFIG1,    _FOSC_INTOSC & _CP_OFF & _WDTE_OFF &  _PWRTE_ON  &  _MCLRE_ON  & _CLKOUTEN_OFF
    DEFINE DEBUG_REG PORTA
    DEFINE DEBUG_BIT 0
    DEFINE DEBUG_BAUD 9600
    DEFINE DEBUG_MODE 0
       OSCCON=$70
       ANSELA=0
       ANSELC=0
       barray var bit[32]
       bbyte var byte ext
       another var word
       cnt var byte
       tst var bit
       more var byte
    @bbyte = PBA01
        clear
        bbyte[0]=5
        bbyte[1]=$55
        lata.0=1
        pause 2000
        Debug "Start",13 ,10
        for cnt=31 to 0      step -1
            Debug #barray[cnt]
        next
        Debug " array by bit",13 ,10
        for cnt =3  to 0      step -1
            Debug bin8 bbyte[cnt]
        next
        barray[11] =1
        Debug " array by byte in bin",13,10,"set bit 11",13 ,10
            Debug #barray[cnt]
        next
        Debug 13 ,10
        next
        bbyte[3] =255
        Debug 13 ,10,"set byte 3",13 ,10
            Debug #barray[cnt]
        next
        Debug 13 ,10
        next
           barray[11] =0
        Debug 13 ,10,"clr bit 11",13 ,10
            Debug #barray[cnt]
        next
        Debug 13 ,10
        next
        bbyte[3] =0
        Debug 13 ,10,"clr byte 3",13 ,10
            Debug #barray[cnt]
        next
        Debug 13 ,10
        next
    printout
    Start
    00000000000000000101010100000101 array by bit
    00000000000000000101010100000101 array by byte in bin
    set bit 11
    00000000000000000101110100000101
    set byte 3
    11111111000000000101110100000101
    clr bit 11
    11111111000000000101010100000101
    clr byte 3
    Will take a look tomorrow...
    Meanwhile, added decimal point, C and F sign support...
  1. 32 Bit NEC IR Constants/Variables
    By Zebryk in forum mel PIC BASIC Pro
    Last Post: - 23rd July 2013, 14:51
  2. Joining variables and displaying on an LCD
    By Navaidstech in forum mel PIC BASIC Pro
    Last Post: - 29th April 2009, 04:12
  3. 32-bit Variables and DIV32, Hourmeter 99999.9
    Last Post: - 23rd November 2006, 07:23
  4. How to tell which PICs can handle 16 bit variables?
    By MikeTamu in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 08:44
  5. Bit variables... typo?
    Last Post: - 29th November 2004, 18:11
