Joining 5 bit variables and splitting them into 8 bit ones later?
Results 1 to 24 of 24
    Default Joining 5 bit variables and splitting them into 8 bit ones later?
    Hello.
    I'm using a MAX7219 dot matrix display, 8x8 pixels, 4 daisy chained.
    I want to display some numbers on it. I can use 7x7 pixel font, so 4 digits will fit.
    But I want to use 6x7 pixel font, so can fit 5 digits on screen.
    Each letter graphics are stored in 6 bit codes, like this, for number 8
    001110
    011011
    011011
    001110
    011011
    011011
    001110
    But data to MAX7219 is being sent into 8 bit increments. So if I send it directly, there will be big gaps and each bit displayed only on single 8x8 matrix. So I need to add these 6 bits to each other, and then split them again into 8 bits. Like this:
    001110 001110 001110 001110 should become
    00111000 11100011 10001110
    Any ideas?
    OK
    Default Re: Joining 5 bit variables and splitting them into 8 bit ones later?
    Don't quite have the thought fully formed, but I'm thinking along the lines of:
    FullDigit VAR LONG
    FullDigit = ((Byte1 << 23) + (Byte2 << 17) + (Byte3 << 11)...
    This might compact the bits(?)
    You need 42 bits, but a LONG only has 32. There's an extra line that would have to be dealt with independently. Again, this isn't a "Solution", just food for thought.
    What if I create 32 bit array, write bits in sequence and then read it in appropriate chunks?
    OK
    Something like this?
    ' 001110 001110 001110 001110
    FullDisp VAR LONG
    FullDisp.31 = 0
    FullDisp.30 = 0
    FullDisp.29 = 1
    FullDisp.28 = 1
    FullDisp.27 = 1
    FullDisp.26 = 0
    FullDisp.25 = 0
    Yes, but have no idea if can use another variable instead of 31 and other digits.
    Like displayvar.X=Y
    I suspect this is what you want:
    displayvar.0[X]=Y
    But I also suspect we've covered this before so instead of me trying to repeat what's already been covered in detail I just leave it all to Melanie :-)
    http://www.picbasic.co.uk/forum/showthread.php?t=544
    So it should look like this, right? (have no access to PBP at this moment).
    SCREEN32 VAR BIT[32] 'MAIN VARIABLE
    LINE1=%10101 'VARIABLE WITH BIT DATA
    FOR X=0 TO 4 'READ BITS
    SCREEN32[X+1]=LINE1.0(X) 'WRITE INTO ARRAY
    NEXT
    So here it is, almost finished (not tested in PBP yet, written in notepad).
    Digit data are stored as 4 bit width sequences, each char compromising of 4x8 pixels (width & height). They are stored by pairs in eeprom (1st address holds bitmaps for 1 & 2, 2nd address - for 3 & 4 and so on).
    This routine should display value of 4 digit CNTR variable on screen. It does that by reading 4 bit graphic data from eeprom, adding 1 space between pixels and assembling into 32 bit array, which later should be cut into 4 bytes and sent to MAX7219. For simplicity, code is shown for sending only 1 line. However, I'm stuck, how to read values from 32 bit array and convert them into bytes.
    LINE VAR BIT[32] 'line of MAX7219 buffer
    DBIT var byte    'digit bit eeprom address
    DOFF var byte    'digit offset 0 for first, 4 for next
    DSHF var byte    'Shift value for next digit data
    CNTR var word    'Input variable
    Y var byte    'Temporary digit variable
    X var byte    'digit scan variable
    Z var byte    'digit row variable
    BT var bit    'bit variable for font hold
    ' decoder routine
    DECODER:
    DSHF=0    'reset char shift variable
    for x=0 to 3 'read all 4 digits
    Y=CNTR DIG X 'EXTRACT VARIABLE DIGIT
    IF Y=1 THEN DBIT=0: DOFF=0 'set the font offset
    IF Y=2 THEN DBIT=0: DOFF=4
    IF Y=3 THEN DBIT=8: DOFF=0
    IF Y=4 THEN DBIT=8: DOFF=4
    IF Y=5 THEN DBIT=16: DOFF=0
    IF Y=6 THEN DBIT=16: DOFF=4
    IF Y=7 THEN DBIT=24: DOFF=0
    IF Y=8 THEN DBIT=24: DOFF=4
    IF Y=9 THEN DBIT=32: DOFF=0
    IF Y=0 THEN DBIT=32: DOFF=4
    for Z=0 to 4 'read font data and write into rows
    READ DBIT+DOFF+Z,BT 'read bit from eeprom
    LINE[Z+DSHF]=BT 'write into array
    next
    DSHF=DSHF+5    'increment char shift variable
    'now here should extract bits from array and convert into bytes
    'to send to MAX7219, but how?
    next
    I decided to return to this code, and have some advancement, but having issues into reading bits from array into an variable.
    I have a SCREEN[32] bit array, which should be read into 4 consecutive variables - SEGA, SEGB, SEGC, SEGD.
    I know how to access individual bits within variable, but complete byte?
    If I understand correctly, the code should look like this
    FOR X=0 to 7
    SEGA.0(X)=SCREEN[X]
    SEGB.0(8+X)=SCREEN[X]
    SEGC.0(16+X)=SCREEN[16+X]
    SEGD.0(24+X)=SCREEN[24+X]
    NEXT
    Is this correct?
    Houston, we're having a problem!
    Below is the code which works, but it works only if bits in array are aligned to bytes. If I want to shift them to make them less spaced (characters used have 4 pixel width, +1 pixel for spacing), image becomes garbled and shifted in wrong direction, as shown on attached pictures. What I'm doing wrong?
    DATA $60,$90,$90,$90,$90,$90,$90,$60 '0  'digits, left justified 4 bits used in each 8 bits
    DATA $20,$60,$A0,$20,$20,$20,$20,$F0 '1
    DATA $60,$90,$90,$10,$60,$80,$80,$F0 '2
    DATA $60,$90,$10,$60,$10,$90,$90,$60 '3
    DATA $90,$90,$90,$70,$10,$10,$10,$10 '4
    DATA $F0,$80,$80,$E0,$10,$90,$90,$60 '5
    DATA $60,$90,$80,$E0,$90,$90,$90,$60 '6
    DATA $F0,$10,$10,$20,$20,$40,$40,$40 '7
    DATA $60,$90,$90,$60,$90,$90,$90,$60 '8
    DATA $60,$90,$90,$70,$10,$90,$90,$60 '9
    INVAR=1234
    FOR I=0 TO 7 'Read digit data from apropriate positions in EEPROM into own CHAR variables
    READ 6+I+8*INVAR DIG 3, CHAR1
    READ 6+I+8*INVAR DIG 2, CHAR2
    READ 6+I+8*INVAR DIG 1, CHAR3
    READ 6+I+8*INVAR DIG 0, CHAR4
    FOR Y=0 TO 7 'write CHAR DATA INTO ARRAY WITH OFFSET
    SCREEN32[Y]=CHAR1.0(Y)
    SCREEN32[Y+8]=CHAR2.0(Y) 'OFSETS ARE SET HERE
    SCREEN32[Y+16]=CHAR3.0(Y)
    SCREEN32[Y+24]=CHAR4.0(Y)
    NEXT
    'read array data into 8 bit variables
    FOR C=0 to 7
    SEGA.0(C)=SCREEN32[C]
    SEGB.0(C)=SCREEN32[8+C]
    SEGC.0(C)=SCREEN32[16+C]
    SEGD.0(C)=SCREEN32[24+C]
    NEXT
    'WRITE ARRAY DATA INTO DISPLAY AND GO TO NEXT LINE
    LOW LOAD
    shiftout datapin,clockpin,1,[1+I, SEGA]
    shiftout datapin,clockpin,1,[1+I, SEGB]
    shiftout datapin,clockpin,1,[1+I, SEGC]
    shiftout datapin,clockpin,1,[1+I, SEGD]
    HIGH LOAD
    NEXT
    you are dealing with a matrix that fills like this
    its not a particularly easy format to leverage font images that traverse cells , and you cannot read back the data from the matrix
    to make life easy i would make a memory array [frame buffer] mapped to the matrix like this
    it's then quite straight forward to overlay a font chr into any location
    and then create a simple routine to write the frame buffer to the display
    in the bit order the matrix demands
    Well, I already have buffer, but 32x1 pixels in size, because the data is sent to display line by line.
    But the problem is different, I can't understand why this works only per 8 bit: SCREEN32[Y+8]=CHAR2.0(Y) - if I enter any other number instead of 8, which is not multiple of 8, say 5 or 17, everything becomes garbled, while it should not. So, maybe I'm writing in array incorrectly?
    I was able to solve this problem by replacing array with string of Boolean logic operations, but I'd like to keep array, because later I want to display more letters, with variable width...
    char1=char1 | char2>>5
    char2=char2 <<3 | char3>>2
    char2=char2 | char4>>7
    char3=char4<<1
    char4=0
    Oh, and by the way, is there any possibility to increase SPI speed? I'm running 16F886 @ 8mhz, and update rate is clearly not good - forget about scrolling letters and other stuff like that.
    yes don't use shiftout, on a chip that has a mssp module it's an order of magnitude or two slower than spi
    its like having a dog and barking yourself
    yet characters persist over 8 lines and you are ignoring that present data, furthermore there is no way to recover that data from the chip
    you figure it out
    after some thought ,
    i assume SCREEN32 is your 32 bit array ,
    SCREEN32[Y+8] is then a complete nonsense as the only valid locations are 0 to 3
    similarly wtf is char2 ? if its a byte then
    CHAR2.0(Y) a valid y value can only be 0 to 7
    then we have this, wtf is char1 a byte a word an array ? , a pointless snippet
    char3=char4<<1char4=0
    Yes, SCREEN32 is 32 bit array.
    And why locations only can be from 0 to 3 ?
    There are 32 bits, or what you want to say, that is not possible to write into specific bit of bit array?
    I'm reading a bit from variable and writing it into bit of an array, to later read bits as needed.
    thats what happens with snippets ,there is no context
    SCREEN32 var bit[32] would have made it clear
    good luck
    proof of concept
    btw i like your font it looks better than my 6x5 one
    sorry for shaky vid , was trying to use mouse while steering phone , failed both accounts
    Well, I'm designing fonts for last 30 years, so no surprise mine is better
    proof of concept of what?
    Any code was posted?
    basically this , modded slightly for the 4x8 font
    http://www.picbasic.co.uk/forum/showthread.php?t=24171
    And this is proof of my code working
    So if I understood correctly, there is no HSHIFTOUT statement, like HSEROUT ?
    But I still have an issue - why reading from a bit array from arbitrary position (not byte justified) returns garbage?
    a minimal, complete and verifiable example MCVE
    https://stackoverflow.com/help/minim...ucible-example
    here is one that shows no problem at all pbp3, examination of lst file confirms reservation of the 4 bytes required for the bit array
    if there was ever any doubt
    ; pbp3 16f1825
    define OSC 32
                 __config        _CONFIG1,    _FOSC_INTOSC & _CP_OFF & _WDTE_OFF &  _PWRTE_ON  &  _MCLRE_ON  & _CLKOUTEN_OFF
    DEFINE DEBUG_REG PORTA
    DEFINE DEBUG_BIT 0
    DEFINE DEBUG_BAUD 9600
    DEFINE DEBUG_MODE 0
       OSCCON=$70
       ANSELA=0
       ANSELC=0
       barray var bit[32]
       bbyte var byte ext
       another var word
       cnt var byte
       tst var bit
       more var byte
    @bbyte = PBA01
        clear
        bbyte[0]=5
        bbyte[1]=$55
        lata.0=1
        pause 2000
        Debug "Start",13 ,10
        for cnt=31 to 0      step -1
            Debug #barray[cnt]
        next
        Debug " array by bit",13 ,10
        for cnt =3  to 0      step -1
            Debug bin8 bbyte[cnt]
        next
        barray[11] =1
        Debug " array by byte in bin",13,10,"set bit 11",13 ,10
            Debug #barray[cnt]
        next
        Debug 13 ,10
        next
        bbyte[3] =255
        Debug 13 ,10,"set byte 3",13 ,10
            Debug #barray[cnt]
        next
        Debug 13 ,10
        next
           barray[11] =0
        Debug 13 ,10,"clr bit 11",13 ,10
            Debug #barray[cnt]
        next
        Debug 13 ,10
        next
        bbyte[3] =0
        Debug 13 ,10,"clr byte 3",13 ,10
            Debug #barray[cnt]
        next
        Debug 13 ,10
        next
    printout
    Start
    00000000000000000101010100000101 array by bit
    00000000000000000101010100000101 array by byte in bin
    set bit 11
    00000000000000000101110100000101
    set byte 3
    11111111000000000101110100000101
    clr bit 11
    11111111000000000101010100000101
    clr byte 3
    Will take a look tomorrow...
    Meanwhile, added decimal point, C and F sign support...
  1. 32 Bit NEC IR Constants/Variables
    By Zebryk in forum mel PIC BASIC Pro
    Last Post: - 23rd July 2013, 15:51
  2. Joining variables and displaying on an LCD
    By Navaidstech in forum mel PIC BASIC Pro
    Last Post: - 29th April 2009, 05:12
  3. 32-bit Variables and DIV32, Hourmeter 99999.9
    Last Post: - 23rd November 2006, 08:23
  4. How to tell which PICs can handle 16 bit variables?
    By MikeTamu in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 09:44
  5. Bit variables... typo?
    Last Post: - 29th November 2004, 19:11
