Heart rate sensor MAX30102
Results 1 to 40 of 85
Threaded View
  1. #23
    Default Re: Heart rate sensor MAX30102
    my code , you should know i have no idea :-
    1, what led pwr to use
    2, what led pwidth to use
    3, what sample rate to use
    4, what sample resolution to use
    5, if there are any fifo overflows and if it matters much
    6, what led the readings represents
    7, how to interpret the data
    8, how much data to collect [i assume at least 2 seconds worth]
    when graphed i see no regular pattern that could be a heart beat
    there is a difference between finger and no finger pattern
    '****************************************************************'*  Name    : MAX30102  FOR PIC 18 test                         *
    '*  Author  :  Richard                                          *
    '*  Notice  :                                                   *
    '*  Date    : 9/1/2022                                          *
    '*  Notes   : MAX30102                                          *
    '*          :18f26k22 @64Mhz                                    *
      #CONFIG   ;  The PBP configuration for the PIC18F26K22 is:
        CONFIG FOSC     = INTIO67
        CONFIG PLLCFG   = OFF	        ;Oscillator multiplied by 4
        CONFIG PRICLKEN  = ON	        ;Primary clock enabled
        CONFIG FCMEN     = OFF	        ;Fail-Safe Clock Monitor disabled
        CONFIG IESO      = OFF	        ;Oscillator Switchover mode disabled
        CONFIG  BOREN    = SBORDIS      ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
        CONFIG  WDTEN    = ON           ; WDT is always enabled. SWDTEN bit has no effect                     ;|
        CONFIG  WDTPS    = 32768        ; 1:32768 ---> HERE enable the watchdog timer with a 1:32768 postscale;|
        CONFIG  PWRTEN   = ON
        CONFIG  HFOFST   = ON           ; HFINTOSC output and ready status are not delayed by the oscillator stable status
        CONFIG  MCLRE    = EXTMCLR      ; MCLR pin enabled, RE3 input pin disabled
        CONFIG  LVP      = OFF          ; Single-Supply ICSP disabled
        CONFIG  XINST    = OFF          ; Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
        CONFIG  DEBUG    = OFF          ; Disabled
        CONFIG  CP0 = OFF             ; Block 0 (000800-003FFFh) not code-protected
        CONFIG  CP1 = OFF             ; Block 1 (004000-007FFFh) not code-protected
        CONFIG  CP2 = OFF             ; Block 2 (008000-00BFFFh) not code-protected
        CONFIG  CP3 = OFF             ; Block 3 (00C000-00FFFFh) not code-protected
        CONFIG  CPB = OFF             ; Boot block (000000-0007FFh) not code-protected
        CONFIG  WRT0 = OFF            ; Block 0 (000800-003FFFh) not write-protected
        CONFIG  WRT1 = OFF            ; Block 1 (004000-007FFFh) not write-protected
        CONFIG  WRT2 = OFF            ; Block 2 (008000-00BFFFh) not write-protected
        CONFIG  WRT3 = OFF            ; Block 3 (00C000-00FFFFh) not write-protected
        CONFIG  WRTC = OFF            ; Configuration registers (300000-3000FFh) not write-protected
        CONFIG  WRTB = OFF            ; Boot Block (000000-0007FFh) not write-protected
        CONFIG  EBTR0 = OFF           ; Block 0 (000800-003FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR1 = OFF           ; Block 1 (004000-007FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR2 = OFF           ; Block 2 (008000-00BFFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR3 = OFF           ; Block 3 (00C000-00FFFFh) not protected from table reads executed in other blocks
        CONFIG  EBTRB = OFF           ; Boot Block (000000-0007FFh) not protected from table reads executed in other blocks
    'define I2C_SLOW 1
    define  OSC 64
    OSCCON    = %01110000   ; 16Mhz
    OSCTUNE.6 = 1           ; Enable 4x PLL
    while ! osccon2.7 :WEND ; to make sure the pll has stabilised before you run any other code
    TRISC = %11011000
    ANSELC=0
    #DEFINE    DEBUGING 1
    #IFNDEF  DEBUGING
        DEFINE HSER_SPBRG 160 ' 38400 Baud @ 64MHz, -0.08%
        SPBRGH = 1
    #ELSE
        DEFINE DEBUG_REG PORTB
        DEFINE DEBUG_BIT 7
        DEFINE DEBUG_BAUD 9600
        DEFINE DEBUG_MODE 0
        ANSELB=0
        LATB.7=1
    #ENDIF
    SDA     var portc.4  ' DATA PIN
    SCL     VAR portc.3  ' CLOCK PIN
    Timeout    cON 2000
    reg        var BYTE
    fifo       var byte[6]
    addr       var byte
    REVISION   var byte
    PARTID     var byte
    buffer     var byte[1152]
    ptr        var byte
    btr        var byte
    index      var word
    ;-----------------------  REGISTER -------------------------
    REG_TEMP_INT         con $1F
    REG_TEMP_FRAC        con $20
    REG_TEMP_CONFIG      con $21
    REG_PART_REVISION    con $FE
    REG_MODE             con $09
    REG_SPO2_CONFIG      con $0A        ;SPO2_ADC_RGE[6:5]SPO2_SR[4:2]LED_PW[1:0]
    REG_LED1_PA          con $0C
    REG_LED2_PA          con $0D
    FIFO_WR_PTR          con $04        ;FIFO_WR_PTR[4:0]
    FIFO_RD_PTR          con $06
    FIFO_DATA            con $07
    FIFO_CONFIG          con $08        ;FIFO_A_FULL[3:0]   SMP_AVE[7:5]
    STATUS1              con 0          ;A_FULL[7]
    #IFDEF  DEBUGING
        PAUSE 2000
        DEBUG 13,10,  "READY"
    #ENDIF
        ADDR  =  $ae     ; addr is  0x57 << 1
        reg= REG_PART_REVISION
        i2cread  SDA,scl,ADDR,reg,[REVISION,PARTID]
        reg= REG_MODE
        i2cwrite  SDA,scl,ADDR,reg,[3]
        reg= REG_SPO2_CONFIG
        i2cwrite  SDA,scl,ADDR,reg,[$30]
        reg = REG_LED2_PA
        i2cwrite  SDA,scl,ADDR,reg,[2]
        reg = REG_LED1_PA
        reg = FIFO_CONFIG
        i2cwrite  SDA,scl,ADDR,reg,[16]
    #IFNDEF  DEBUGING
        HSEROUT [$73,$03,$04,$11,$ff,$ff,"PART ID: 0X",hex PARTID,"/0X", hex REVISION,$00]
        Hserin  timeout,error,[wait(6)]
    #ELSE
        DEBUG 13,10,  "PART ID: 0X",hex PARTID,"/0X",hex REVISION
    #ENDIF
    start:
        reg= REG_TEMP_CONFIG
        i2cwrite  SDA,scl,ADDR,reg,[1]
        reg= REG_TEMP_INT
        i2cread  sda,scl,ADDR,reg,[fifo[0],fifo[1]]
    #IFNDEF  DEBUGING
        HSEROUT [$73,$05,$0A,$11,$07,$E0,"TEMP: ",DEC fifo[0],".",DEC2( fifo[1]<<6),$00]
    #ELSE
        DEBUG 13,10, "TEMP: ",DEC fifo[0],".",DEC2( fifo[1]<<6)
    #ENDIF
        GOSUB AQUIRE
        pause 5000
    goto start
    aquire:
        reg= FIFO_WR_PTR
        i2cwrite  SDA,scl,ADDR,reg,[0]
        reg= FIFO_RD_PTR
     FOR index = 0 TO 1151 STEP 0
        btr =0
        reg= STATUS1
        WHILE btr&$80=0
        i2cread  sda,scl,ADDR,reg,[btr]
        WEND
        reg= FIFO_RD_PTR
        i2cread  SDA,scl,ADDR,reg,[btr]
        btr =  (btr- ptr) &  31
        WHILE btr
        reg = FIFO_DATA
        i2cread  sda,scl,ADDR,reg,[buffer[index],buffer[index+1],buffer[index+0],buffer[index+5],buffer[index+4],buffer[index+3]]
        index=index+6
        btr=btr-1
        ptr = (Ptr+1) &  31
        WEND
        pause 200 ; no sure about this either
     NEXT
        DEBUG 13,10,HEX2 buffer[index+0],HEX2 buffer[index+1],9,HEX2 buffer[index+3],HEX2 buffer[index+4]
        index=index+6
       NEXT
  1. New PIC failure rate
    By timmers in forum General
    Last Post: - 26th March 2009, 13:11
  2. Rf module baud rate
    By tazntex in forum Serial
    Last Post: - 5th August 2008, 19:47
  3. Replies: 6
    Last Post: - 18th January 2008, 09:17
  4. SHIFTOUT Clock rate
    By Brock in forum mel PIC BASIC Pro
    Last Post: - 9th July 2006, 00:42
  5. Detect baud rate
    By Dick M in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2005, 22:10
