Heart rate sensor MAX30102
Results 1 to 40 of 85
    Default Re: Heart rate sensor MAX30102
    The breadboarding....i think is clear as schematic, if you like schematic i could also make one
    not really , i looked at 3 modules the mikroe one is 3.3v only .the one mouser/e14 sell is 3.3 or 5v and has a logic level converter on board
    another provides no schematic and only vague spec no schema, i cannot identify your module
    by the look of your cro traces you are belting 5v in on the scl,sda pins , better hope its 5v tolerant
    TRISC = %10000100 ' portc.7 and portc.2 set as input.
    is wrong both must be input , the routine will switch tris as req
    if the module have 3.3 v pull ups might be better to use the open collector/drain method for i2c command
    [edit] forget that ,its open collecter by default.
    all other unused ports are configured as output and set to low.
    unnecessary
    SDA var portc.1
    SCL var portc.2
    conflicts with your tris statement anyway
    Now regarding the FIFO_WR_PTR it is not clear to me in the manual what data to write to it.
    me either but it will do something if everything else is correct
    Oct 2010
    Changed to input both portc.1 and portc.2
    This is the module.
    https://reedpaper.wordpress.com/2018...x-wrong-board/
    I have also following the "fix". Well module is 3.3V but i have never seen in all of the Arduino connections any note.
    I have changed the connections and used the 3.3V output from the Display to power the rest of the circuit.
    I dont beleive that i have burned the module as this is the result before i change the voltage supply from 5V to 3.3V.
    i2cwrite sda,scl,$AE,$04
    This is the proof of ACK in 9th bit. As from the data sheet if the Id is the right one, the module pulls down the SDA during 9th bit to acknowledge receipt of data.
    Name:  ACK correct.png
    i see you're still torturing the device sending incomplete write resister i2c control messages at it
    Oct 2010
    yes i havent send any data yet as i'm searching in the i2c how to do that corresponds to the max30102 manual.
    At least i know sensor is responded by pulling SDA down on 9th bit. This is something for me.
    Oct 2010
    i've done many tries. I just want to see if the red LED inside the sensor is alive. At least by sending a command to activate it.
    This is as from the pseudo code the first step. I really do not know if that is the right way to send Device ID + write mode
    Then send the FIFO_WR_PTR (i still dont know what are the bits needs to be configured)
    REPEAT START
    addr = $04   ; FIFO WRITE POINTER REG ADDR IS 0X04
    i2cwrite  SDA,scl,contwr
    i2cwrite  SDA,scl,contwr,addr
    Apart from pseudo code in the datasheet, Next i tried to send mode for the heart rate mode only
    addr = $09   ' mode configuration
    i2cwrite  SDA,scl,contwr,addr,[modled],error ' ModLED = $02 as per data sheet heart rate mode only
    In the end i tried to send the led pulse amplitute.
    addr = $0C   ' led pulse amplitute
    i2cwrite  SDA,scl,contwr,addr,[led1_pa],error' LED1_PA = $3F  , 12.6 mA
    no luck......keep walking.
    given that you can buy these for < $20us delivered to your door i doubt its worth while making them other than as an intellectual exercise
    https://au.banggood.com/BOXYM-oFit-2...r_warehouse=CN
    i have tried the sparkfun arduino demos and was not particularly impressed with accuracy or stability of readings obtained
    {maybe my heart is inaccurate and unstable}
    the raspberrypi code goes about it quite differently&nbsp; with some dsp done on data collected in a fixed sampling period [not tried it].
    i have no experience with these things , i don't know if reverse engineering the arduino code is even worthwhile
    but no matter how you go about it the sort of digital signal processing needed will be lots and lots of hard work with pbp
    do you have a plan ? have you established optimal device settings to get the best readings ? how much data is needed and from where ?
    reading and writing to the device is child's play, setting it up to get meaningful data and being able to extract information from that data is another story
    I double what Richard pointed.
  1. New PIC failure rate
    By timmers in forum General
    Last Post: - 26th March 2009, 13:11
  2. Rf module baud rate
    By tazntex in forum Serial
    Last Post: - 5th August 2008, 19:47
  3. Replies: 6
    Last Post: - 18th January 2008, 09:17
  4. SHIFTOUT Clock rate
    By Brock in forum mel PIC BASIC Pro
    Last Post: - 9th July 2006, 00:42
  5. Detect baud rate
    By Dick M in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2005, 22:10
