Holtek Encoder HT6P20
Results 1 to 22 of 22
    Jul 2005
    Thumbs up Ht6p20b
    Hello....
    If someone have interest in HT6P20B decoding, feel free to use the code below.
    Is ugly to see, but works fine.
    And if someone help me to let this code more short and clean, antecipately thanks.
    Carlos W. Rett
    ________________________________________________
    INCLUDE "BS2DEFS.BAS"
    DEFINE CHAR_PACING 1000 'Serout character pacing in us
    DEFINE PULSIN_MAX 6200
    DEFINE OSC 20 'Oscilator Speed
    ADCON1 = 7 ' Set PORTA and PORTE to digital
    'Define nome de variáveis
    BITVALUE VAR WORD
    ADDRESS VAR WORD
    CODE VAR BYTE
    BTRES VAR BIT
    IRIN1 VAR PORTA.0
    SERPC VAR PORTA.1
    CLEAR 'Clear All Variables
    'Port Adjust
    TRISA = %11111101 'PortA Adjusted .
    SEROUT2 SERPC,16390,["--Program initialized--",13,10] 'SERIAL Speed = 38400
    Start:
    CLEAR
    PULSIN IRIN1,0,BITVALUE
    IF (BITVALUE > 5400) and (bitvalue < 6100) THEN
    Goto LEDADOS
    goto Start
    LEDADOS:
    GOSUB TESTABIT
    ADDRESS.15 = BTRES
    GOSUB TESTABIT
    ADDRESS.14 = BTRES
    GOSUB TESTABIT
    ADDRESS.13 = BTRES
    GOSUB TESTABIT
    ADDRESS.12 = BTRES
    GOSUB TESTABIT
    ADDRESS.11 = BTRES
    GOSUB TESTABIT
    ADDRESS.10 = BTRES
    GOSUB TESTABIT
    ADDRESS.9 = BTRES
    GOSUB TESTABIT
    ADDRESS.8 = BTRES
    GOSUB TESTABIT
    ADDRESS.7 = BTRES
    GOSUB TESTABIT
    ADDRESS.6 = BTRES
    GOSUB TESTABIT
    ADDRESS.5 = BTRES
    GOSUB TESTABIT
    ADDRESS.4 = BTRES
    GOSUB TESTABIT
    ADDRESS.3 = BTRES
    GOSUB TESTABIT
    ADDRESS.2 = BTRES
    GOSUB TESTABIT
    ADDRESS.1 = BTRES
    GOSUB TESTABIT
    ADDRESS.0 = BTRES
    GOSUB TESTABIT
    CODE.7 = BTRES
    GOSUB TESTABIT
    CODE.6 = BTRES
    GOSUB TESTABIT
    CODE.5 = BTRES
    GOSUB TESTABIT
    CODE.4 = BTRES
    GOSUB TESTABIT
    CODE.3 = BTRES
    GOSUB TESTABIT
    CODE.2 = BTRES
    GOSUB TESTABIT
    CODE.1 = BTRES
    GOSUB TESTABIT
    CODE.0 = BTRES
    GOSUB TESTABIT
    SEROUT2 SERPC,16390,["Address= ",BIN16 ADDRESS," Code = ",BIN8 CODE,13,10]
    GOTO Start
    TESTABIT:
    BITVALUE = 0
    PULSIN IRIN1, 1, BITVALUE
    IF (BITVALUE < 200) OR (BITVALUE > 600) THEN
    SEROUT2 SERPC,16390,["Interrupted Code or Garbage ",13,10]
    GOTO Start
    IF BITVALUE < 400 THEN
    Btres = 1
    Btres = 0
    leko's Avatar
    leko Guest
    Lightbulb ht6p20b
    Hi Carlos!! You know the manchester code!!Some small alterations based on the examples of manchester code can be useful!
    Você conhece o codigo manchester? Algumas pequenas alterações baseadas nos exemplos do codigo manchester podem ser interessantes!Vc ja olhou os exemplos para codificacao manchester!! No codigo da Melaine me parece que ela monta os dados seriais. Olhei muito rápido!! Qualquer coisa me manda um email [email protected]
    http://www.picbasic.co.uk/forum/show...ght=Manchester
    Red face
    Hi Carlos,
    Utilizei o seu código para decodificar o sinal enviado por um sensor de presença sem fio que utiliza o padrão 6p20b. O código compilou direitinho mas não consegui a decodificação do sinal. O meu receptor de RF está recebendo o sinal mas não consigo decodificá-lo. O que será que pode estar acontecendo?
    Jul 2005
    Lightbulb 6p20b
    Olá MARCANTONIO,
    Especifique melhor o seu projeto para que eu possa entender o que pode estar acontecendo, como o tipo de PIC utilizado, se está utilizando Display, o tipo de receptor, e poste a sua rotina ou parte dela para que eu possa estar dando uma olhada.
    Já adiantando, você pode olhar algumas coisinha básicas, como a configuração correta das portas do PIC, se estão definidas como entrada ou saída corretamente, se estão setadas como entrada/saída DIGITAL e não analógica, se você está usando a saída digital do seu receptor de RF e não a analógica, se as variáveis de programa estão com o tamanho correto (Byte,Word, Bit) etc.
    Espero que tenha sucesso, depois poste aqui os resultados.
    [ ]s
    C.W.Rett
    Hi Carlos,
    Estou utilizando o seu código com quase nenhuma alteração. As alterações que fiz foram basicamente na apresentação dos dados via LCD. O PIC utilizado é um 16f877 - 20MHz, conforme você tinha sugerido.
    O meu receptor de rf é este comercializado na Tato
    http://www.tato.ind.br/files/RxD1.pdf
    Estou pretendendo decoficar os sinais enviados via RF para sistemas de alarme sem fio. Se pelo menos eu conseguisse fazer a decodificação já seria de grande ajuda pois era só ir adaptando o código.
    Você conseguiu fazer a decodificação do ht6p20B com o exemplo acima? Como os dados eram apresentados? Você teria mais alguma dica ou exemplo?
    Você pode entrar em contato direto comigo pelo e-mail abaixo
    [email protected]
    Um grande abraço.
    Jul 2005
    Lightbulb
    Marcantonio, o receptor que eu tenho utilizado, é o DHAY 433MHz do link below :
    http://www.dhay.com.br/Produtos/Plug-in/RX.htm
    Não conheço este módulo da TATO ao qual você se referiu, não sei se a saída do mesmo é digital ou analógica, e se a saída de dados do mesmo é da mesma fase que o DHAY, talvez também seja necessário colocar um resistor de Pull-Up ou Pull-Down na saída do seu módulo para melhor definição do sinal.
    Caso Você esteja em São Paulo, te aconselho comprar um destes módulos híbridos da DHAY, você os encontra na Multicomercial (Sta. Ifigênia), e o custo do mesmo é em torno de R$12,00 a R$15,00 aproximadamente, assim você poderia testar a rotina para ver o funcionamento da mesma, e talvez adaptar a seu receptor.
    Já utilizei esta rotina em vários projetos, e funciona perfeitamente além de ser bem rápida na leitura e não apresentar leituras errôneas.
    [ ]s
    C.W.Rett
    Hey boys, you happen to be in an english language speaking (=writing) forum!
  1. Quadrature encoder and ASM Interrupts. questions..
    By godfodder in forum mel PIC BASIC Pro
    Last Post: - 17th March 2013, 15:45
  2. Instant Int and encoder (Elect. Gearing)
    Last Post: - 29th November 2009, 03:29
  3. encoder HEDL 5540
    By kutsi in forum mel PIC BASIC Pro
    Last Post: - 11th June 2007, 15:00
  4. Holtek - HT6012 Encoder
    By ero in forum mel PIC BASIC Pro
    Last Post: - 9th March 2006, 14:02
  5. encoder wowes
    By wallaby in forum mel PIC BASIC Pro
    Last Post: - 6th December 2005, 22:56
