Calculating Daylight Saving Time
Results 1 to 20 of 20
    Sep 2009
    Default Re: Calculating Daylight Saving Time
    I don't understand your tables... Column c,d,e are years? If there are, what years?
    I was going to post my code for calculating DST, but in my country winter time is from last Sunday in October to last Sunday in March.
    Last Sundays are on same date every 28 years, in fact all days in week are on same day in month every 28 years.
    So just build 2 lookup table for 28years. And then use just Year//28 to search for date in that year.
    If you look hard you can find link between day in March and day in October.
    Here is code for that:
        Tmp=Year 'Use less code space than Year//28 in lookup table
        WHILE Tmp>27
            Tmp=Tmp-28
        WEND
        LOOKUP Tmp,[Dates in march for 28 years],Tmp'March
        IF Month=10 THEN  'October
            Tmp=Tmp-4
            IF Tmp<25 THEN Tmp=Tmp+7
    It worked for me, hope that this help.
    And using DST flag can complicate life, so I just move hours up or down.
    Oct 2009
    Utah, USA
    The seven columns represent ANY year. Since in any given year, the first day of March or November could be a Sun, Mon, Tue, etc. I had to account for that fact that there are 7 POSSIBLE starting days for each month.
    The reason I also show Sun=1, Mon=2, etc., is so I could ask "less than" or "greater than" questions.
    I wanted this to be a universal calculation for USA.
    The code will only apply for these rules...
    At present, daylight saving time in the United States
    begins at 2:00 a.m. on the second Sunday of March and
    ends at 2:00 a.m. on the first Sunday of November
    If you are in another part of the world where you have different rules (or no DST at all) then obviously this would not apply.
    Dwight
    Quebec, Canada
    Heckler don't you get your time sync from NTP? Do you have the day of week?
    If so:
    Delta = Date - 7
    IF Month=3 AND Day=Sunday AND (Delta>0 OR Delta<8) Then DST!
    By the way thank you for the ESPBasic code! Got some ideas...
    Lancashire
    Hi All
    I've used this for many years, works for Europe and I suppose could be adapted for USA. DST Europe changes in March or October, last weekend of the month. The routine calculates the date in the respective month that the change occurs on.
    DSTStart holds the start date for DST
    DSTEnd holds the end date for DST
    Year holds the year in this format e.g 2016
    DSTCheck:
    DSTStart = (31 - (((5*Year)/4)+ 4) mod 7)
    DSTEnd = (31 - (((5*Year/4)) + 1) mod 7)
    That's it, Pete
    Sep 2009
    Can you explain how did you get this formulas?
    I was searching whole net few years ago, and best I could think is to type dates for whole century find pattern, and put it in lookup table.
    EDIT:
    Heckler,
    Just found this
    http://delphiforfun.org/programs/mat...cs/dstcalc.htm
    Basically what Enigma wrote, but it have calculation for US.
    thanks enigma
    that's very neat and tidy
    for australia
    #au DSTEnd 1st sunday in april = (7- (((5*Year/4)) + 4) % 7)
    #au DSTStart 1st sunday in october = (7- (((5*Year/4)) + 5) % 7)
    Oct 2009
    Utah, USA
    @MichelJasmin
    yes I do use NTP as the starting point of my calculation and I do get the date in the following format...
    Thu Jan 01 00:00:00 1970
    But your example would (I believe) only work if I happened to check the time on the actual day that the DST or STD time began and only be persistent if I kept track of whether DST or STD was in effect.
    However in my case I may power up the clock say on March 12 or any other day of the year and need to determine the current DST/STD status.
    I could probably use your example and then check to see if the current date was before or after that date.
    @Enigma (Pete)
    So how do you translate this bit of code into PICbasic??
    Does MOD 7 mean Y= X // 7 (in your example is MOD the same as the remainder?)
    At this point I think I am going to give my code a spin and see how it performs.
    but great discussion
    Thanks all
    Dwight
    Lancashire
    Hi Heckler
    The whole subroutine is cut directly from my PBP program and will work as is. If you want to check it write it as a small program, set Year word variable to 2016 and debug out the start and end dates.
    Cheers Pete
  1. Calculating time delay between two inputs?
    By grimmjow in forum General
    Last Post: - 18th October 2010, 15:52
  2. Calculating Time for clock's preset
    By menta in forum General
    Last Post: - 5th July 2008, 07:09
  3. Calculating elapsed time, how?
    By Eng4444 in forum mel PIC BASIC Pro
    Last Post: - 1st June 2006, 10:00
  4. FYI Daylight Saving Time in the U.S.
    By ccsparky in forum General
    Last Post: - 7th November 2005, 16:05
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
