ds1307 from f877 to f452 not work
Results 1 to 24 of 24
    PBP version 2.42 introduced some timing changes to I2CREAD/I2CWRITE for
    the 18F series. That may be why you're having problems if you're using
    version 2.40.
    I've compiled your code as-is with PBP v2.46. See if this works for you.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    microkam's Avatar
    microkam Guest
    Red face
    hi Bruce...
    i downloaded your hex file and it's runing ok.
    how can i solve this problem on my compiler picbasic pro 2.4 because i dont have a newer version than 2.4..
    Version 2.40 is pretty old. If for some reason you can't upgrade to the latest
    version, then you might try contacting MeLabs directly to see what changes
    they made to the 18F I2C library routines.
    Look here http://www.microengineeringlabs.com/...pgrade.htm#pbp
    They've had a LOT of updates since v2.40 for the 18F series. Well worth the
    few bucks for an upgrade if you're using 18F parts.
    -Bruce
    tech at rentron.com
    Feb 2004
    Germany
    microcam,
    this is probably not what you wanted to hear,
    but best would be to upgrade to PBP 2.46
    regards
    Ralph
    microkam's Avatar
    microkam Guest
    is this update free ,can i update to 2.46 free
    Contact the distributor you originally purchased PBP from. They should be
    able to get you going.
    -Bruce
    tech at rentron.com
    mytekcontrols's Avatar
    mytekcontrols Guest
    Smile
    If you don't want to upgrade PBP, and you don't mind adding some additional code, here is a customizable I2C routine that will work with the DS1307 (it could also be set-up to work with multiple I2C devices):
    ' SDA = I2C serial data line
    ' SCL = I2C serial clock lines
    DS1307 Con $D0                     ' I2C Slave Device "Write" Address (DS1307)
    I2Cdelay con 15                    ' usec delay used in SDA and SCL timing
                                       ' routines.
    blocksize con 8                    ' maximum # of bytes to send or receive
    i2cBytes var byte                   ' # of bytes in data array
    i2cData var byte[blocksize]         ' data array
    i2cWork var byte                    ' work byte for TX routine
    i2cDevAddr var byte                 ' Device Slave Address
    i2cAddr var word                    ' Memory Address
    i2cloop var byte
    i2cindex var byte
    ' Subroutines
    'DS1307 RTC Time/Date Register Block Write Routine
    '(i2cData = data array, i2cbytes = # of bytes to send)
    DS1307blkwrite:
        i2cDevAddr = DS1307                ' set slave device WRITE address
        Gosub I2C_AddrSend                 ' Send Address Info!
        For i2cindex = 0 To (i2cbytes-1)   ' loop for number of bytes in array
        i2cWork = i2cData[i2cindex]        ' xfer from array to temp
        Gosub I2C_TX_Byte                  ' Send Data!
        Next i2cindex
        Gosub I2C_Stop                     ' Finished!
    'DS1307 RTC Time/Date Register Byte Write Routine
    '(i2cData = byte to send, i2caddr = address of byte to write)
    DS1307bytewrite:
        i2cWork = i2cData                  ' Transfer data!
    'DS1307 RTC Time/Date Register Block Read Routine
    '(i2cData = data array, i2cbytes = # of bytes to read)
    DS1307blkread:
        Gosub I2C_Stop                     ' break between events and
        Gosub I2C_Start                    ' re-start for device read
        i2cWork = (DS1307+1)               ' set slave device READ address
        Gosub I2C_TX_Byte
        Gosub I2C_RX_Byte                  ' Receive Data!
        i2cData[i2cindex] = i2cWork        ' Transfer Data!
        If i2cindex != 6 Then Gosub I2C_ACK
        Next i2cindex
    'DS1307 RTC Time/Date Register Byte Read Routine
    '(i2cData = byte to receive, i2caddr = address of byte to read)
    DS1307byteread:
        Gosub I2C_TX_Byte
        i2cData = i2cWork                  ' Transfer Data!
    'I2C Device Read/Write and Memory Address Routine
    '(i2cDevAddr = Device Address, i2caddr = Memory Address)
    I2C_AddrSend:
        Gosub I2C_Stop                      ' Normalize Bus/Recover from errors
        Gosub I2C_Start                     ' send Start
        i2cWork = i2cDevAddr                ' send slave WRITE address
        Gosub I2C_TX_Byte
        i2cWork = i2caddr // 256            ' send LSB ADDRESS
        Gosub I2C_TX_Byte
        If i2cDevAddr = DS1307 Then Return  ' 1 byte memory address
        i2cWork = i2caddr / 256             ' send MSB ADDRESS
        Goto I2C_TX_Byte
    ' Low Level I2C Subroutines
    ' --- Start ---
    I2C_Start:                          ' I2C start bit sequence
        Gosub SCLlo
        Gosub SDAhi
        Gosub SCLhi
        Gosub SDAlo                     ' SDA -> low while SCL high
        Goto SCLlo
    ' --- Stop ---
    I2C_Stop:                            ' I2C stop bit sequence
        Gosub SCLlo
        Gosub SDAlo
        Gosub SCLhi
        Gosub SDAhi                      ' SDA --> high while SCL high
        Goto SCLlo
    ' --- Transmit ---
    I2C_TX_Byte:
        For i2cloop = 0 to 7
        If i2cWork.7 = 0 Then
        Gosub SDAlo
        Else
        Gosub SDAhi
        Endif
        Gosub SCLhi
        Gosub SCLlo
        i2cWork = i2cWork << 1
        Next i2cloop
        Goto I2C_NACK
    ' --- Receive ---
    I2C_RX_Byte:
        Gosub SCLhi
        i2cWork = (i2cWork*2)+ SDA       ' shift left and insert bit
        Gosub SCLlo
        Next i2cloop
    'Get Acknowledge Bit
    I2C_NACK:
        Gosub SDAhi
        Gosub SCLhi
        Goto SCLlo
    'Send Acknowledge Bit
    I2C_ACK:
        Gosub SDAlo
        Gosub SCLhi
        Gosub SCLlo
        Goto SDAhi
    SDAhi:
        Input SDA
        Pauseus I2Cdelay
    SDAlo:
        Low SDA
        Pauseus I2Cdelay
    SCLhi:
        High SCL
        Pauseus I2Cdelay
    SCLlo:
        Low SCL
        Pauseus I2Cdelay
    There are 2 sets of routines, block read/write, and byte read/write.
    Here is an example using block read to fetch the time/date registers:
    'Retrieve RTC values
    getclk:
        i2caddr = 0
        i2cbytes = 7
        Gosub DS1307blkread
        For indx = 0 to 6
        Select Case indx
        Case 0            'seconds
        secs = i2cData[indx]
        Case 1            'minutes
        mins = i2cData[indx]
        Case 2            'hours
        hours = i2cData[indx]
        Case 3            'day of the week
        dweek = i2cData[indx]
        Case 4            'day
        day = i2cData[indx]
        Case 5            'month
        month = i2cData[indx]
        Case 6            'year
        year = i2cData[indx]
        End Select
        Next indx
    And here is a way to update those same registers with the block write routine:
    'Update RTC registers from system variables
    UpdateRTC:
        Gosub RTCoff
        For indx = 0 to 6
            Select Case indx
            Case 0            'seconds
            If newsecs = $FF Then newsecs = 59
            If newsecs > 59 Then newsecs = 0
            tTemp = newsecs
            Gosub dec2BCD
            Case 1            'minutes
            If newmins = $FF Then newmins = 59
            If newmins > 59 Then newmins = 0
            tTemp = newmins
            Gosub dec2BCD
            Case 2            'hours
            If newhours = $FF Then newhours = 23
            If newhours > 23 Then newhours = 0
            tTemp = newhours
            Gosub dec2BCD
            If newdweek = $FF Or newdweek = 0 Then newdweek = 7
            If newdweek > 7 Then newdweek = 1
            tTemp = newdweek
            Gosub dec2BCD
            Case 4            'day
            tTemp = month
            Gosub BCD2dec
            If tTemp // 2 = 0 Then
                daytop = 30
            Else
                daytop = 31
            Endif
            If tTemp = 2 Then
                tTemp = year
                Gosub BCD2dec
                If tTemp // 4 = 0 Then
                    daytop = 29
                Else
                    daytop = 28
                Endif
            Endif
            If newday = $FF Or newday = 0 Then newday = daytop
            If newday > daytop Then newday = 1
            tTemp = newday
            Gosub dec2BCD
            Case 5            'month
            If newmonth = $FF Or newmonth = 0 Then newmonth = 12
            If newmonth > 12 Then newmonth = 1
            tTemp = newmonth
            Gosub dec2BCD
            Case 6            'year
            If newyear = $FF Then newyear = 99
            If newyear > 99 Then newyear = 0
            tTemp = newyear
            Gosub dec2BCD
            End Select
        Next indx
        i2caddr = 0
        i2cbytes = 7
        Gosub DS1307blkwrite
        Goto RTCon
    dec2BCD:
        tTemp = ((tTemp DIG 1) << 4) | (tTemp DIG 0)
        i2cData[indx] = tTemp
    BCD2dec:
        tTemp = ((tTemp >> 4)*10) + (tTemp & %1111)
    And here are some handy low level byte write routines:
    RTCon:
        i2caddr = 0
        Gosub DS1307byteread
        If i2cData.7 = 0 Then Return
        i2cData = i2cData & %01111111
        i2caddr = 0
        Goto DS1307bytewrite
    RTCoff:
        i2caddr = 0
        If i2cData.7 = 1 Then Return
        i2cData = i2cData | %10000000
        i2caddr = 0
    RTChour24:
        i2caddr = 2
        If i2cData.6 = 0 Then Return
        i2cData = 0
        i2caddr = 2
    And here is a routine that will do a block read and then update your system variables directly from the time/date registers:
    'Refresh system variables from RTC registers
    RTCrefresh:
        Gosub getclk
        tTemp = secs
        Gosub BCD2dec
        newsecs = tTemp
        tTemp = mins
        Gosub BCD2dec
        newmins = tTemp
        tTemp = hours
        Gosub BCD2dec
        newhours = tTemp
        tTemp = dweek
        Gosub BCD2dec
        newdweek = tTemp
        tTemp = day
        Gosub BCD2dec
        newday = tTemp
        tTemp = month
        Gosub BCD2dec
        newmonth = tTemp
        tTemp = year
        Gosub BCD2dec
        newyear = tTemp
    I don't know if any of this will be of use to you, but I had it laying around and I figured I should at least offer it up.
  1. pls help me verify my code not work, why???
    Last Post: - 18th January 2010, 10:19
  2. Can't get switch to work
    By JeffnDana in forum mel PIC BASIC Pro
    Last Post: - 4th April 2007, 21:44
  3. DS1307 on fire
    By brid0030 in forum General
    Last Post: - 25th November 2006, 03:44
  4. How to set ICD-2 clone to work with PBP?
    By G-R-C in forum mel PIC BASIC Pro
    Last Post: - 20th October 2006, 03:50
  5. Pin RA4 doesn't work
    Last Post: - 15th July 2004, 13:03
