ds1307 from f877 to f452 not work
Results 1 to 24 of 24
    I interchange 18F252, 18F242, 18F2420, 18F2520 and 18F2620 with 16F876's all the time, on the same boards with a DS1307 installed (although I use different pins to you). From memory, other than CONFIG FUSES and the Weak Pull-Up's having a different Register, there's not too many other changes to look out for. Can you try another 18F PIC? what versions of PBP and MPLAB/MPASM are you using?
    microkam's Avatar
    microkam Guest
    Unhappy
    i used picbasic pro 2.4
    microcode studio 2.0.5.2
    mpasm v02.80
    whats the state of fuses you use
    i used HS are this correct
    Feb 2004
    Germany
    Quote Originally Posted by microkam
    mpasm v02.80
    There are newer Versions of all the packages available.
    (MicroCode Studio and MPASM are available for download)
    With regards to the Fuses and Config Bits:
    The Loader.HEX usually has all this preset, so you don't have to worry.
    (As long as your programmer doesn't alter them)
    regards
    Ralph
    microkam's Avatar
    microkam Guest
    Unhappy
    ok NavMicroSystems , whats the soluation i tested all thing and no result
    PBP version 2.42 introduced some timing changes to I2CREAD/I2CWRITE for
    the 18F series. That may be why you're having problems if you're using
    version 2.40.
    I've compiled your code as-is with PBP v2.46. See if this works for you.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    microkam's Avatar
    microkam Guest
    Red face
    hi Bruce...
    i downloaded your hex file and it's runing ok.
    how can i solve this problem on my compiler picbasic pro 2.4 because i dont have a newer version than 2.4..
    Version 2.40 is pretty old. If for some reason you can't upgrade to the latest
    version, then you might try contacting MeLabs directly to see what changes
    they made to the 18F I2C library routines.
    Look here http://www.microengineeringlabs.com/...pgrade.htm#pbp
    They've had a LOT of updates since v2.40 for the 18F series. Well worth the
    few bucks for an upgrade if you're using 18F parts.
    -Bruce
    tech at rentron.com
    Feb 2004
    Germany
    microcam,
    this is probably not what you wanted to hear,
    but best would be to upgrade to PBP 2.46
    regards
    Ralph
  1. pls help me verify my code not work, why???
    Last Post: - 18th January 2010, 10:19
  2. Can't get switch to work
    By JeffnDana in forum mel PIC BASIC Pro
    Last Post: - 4th April 2007, 21:44
  3. DS1307 on fire
    By brid0030 in forum General
    Last Post: - 25th November 2006, 03:44
  4. How to set ICD-2 clone to work with PBP?
    By G-R-C in forum mel PIC BASIC Pro
    Last Post: - 20th October 2006, 03:50
  5. Pin RA4 doesn't work
    Last Post: - 15th July 2004, 13:03
