Disable/Enable DT interrupt
Results 1 to 11 of 11
    May 2008
    Italy
    Default Disable/Enable DT interrupt
    Hi all, I need help in understanding how I can disabile temporarely the DT interrupt on the serial receive (RX_INT) and Enable it as soon as the special event is ended.
    Anybody has faced such a need before?
    Cheers
    Al.
    Default Re: Disable/Enable DT interrupt
    You can use the macro's
    @ INT_ENABLE RX_INT
    @ INT_DISABLE RX_INT
    or
    set / clear the pie1.rcif bit yourself (usually pie1.5) but check your data sheet
    May 2008
    Italy
    Thank you Richard for the prompt answer. Just what I was looking for!
    Cheers
    Al.
    Jun 2015
    From a newbie - Where can I download virgin copies of the latest DT-Ints-18 AND ReEnterPBP-18? I've searched everywhere, can't find ReEnterPBP-18 at all. Using PBP3, PIC18F67K90 in a smart battery. Thanks...
    May 2008
    Italy
    You can tray at this link:
    http://www.picbasic.co.uk/forum/showthread.php?t=19638
    Cheers
    Al.
    Jun 2015
    Thanks - that's just what I was looking for. Now the fun part...! Wish Darrel was still around. I'm trying to create I2C control commands in PBP3 for an interrupt handler (similar to CCS's C-code I2C_ISR_STATE, I2C_READ, I2C_WRITE).
    May 2008
    Italy
    Matthews I never used the Darrel I2C interrupt so I cannot help you. I did something with I2C few years ago, and I posted a working snippet in this thread http://www.picbasic.co.uk/forum/showthread.php?t=10141. In the thread you will find also some code using DT I2C interrupt that could help you to start with your new project.
    Longing to see your working code posted!
    Cheers
    Al.
    Feb 2003
    @ INT_ENABLE TMR1_INT
    @ INT_DISABLE TMR1_INT
    I have a chunk of time critical bit banging code for driving WS2811 LEDs so I cant allow it to be interupted.
    If I do the following.....
    {whole chunk of time critical code}
    Would TMR1 be able to flag an interrupt that would then be picked up when I re-enabled the DT Interrupt or would I miss that event completely ?
    Thanks in advance.
    Keith
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Aug 2011
    In general yes, but that depends on the version of DT-INTS you're using. Some of the ones I've seen clear the IF bit in INT_ENABLE, others don't.
    Might be easier to just set/clear the TMR1IE bit yourself (It's normally bit 0 of PIE1). If the TMR1IF bit is set when you set TMR1IE it'll generate an interrupt.
    Keith, I did the exact same thing when I wrote code some years ago for the WS2811 LEDs. That is the reason I switched to using the APA102C led's as they are SPI based and there is no need to disable the interrupts. In fact I just finished a table lamp for my daughter using 204, APA102C's and 29, 5.25 inch hard disk platters.
    EN82fn
    Feb 2003
    Thanks Tumbleweed, will do some experimenting when I get home.
    Love the lamp Dave. Looks really cool.
    I am using WS2801, WS2811, APA102 and some PL9823 LEDs in a project. Will post pictures once its complete.
    Keith
    www.diyha.co.uk
    www.kat5.tv
  1. Disable/Enable in Interrupts
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 15th June 2015, 07:47
  2. 4x40 LCD Display Enable Pin
    By rsocor01 in forum General
    Last Post: - 10th August 2011, 02:50
  3. PIC 16F616 Interrupt Enable/Disable?
    By Tobias in forum mel PIC BASIC Pro
    Last Post: - 17th May 2009, 08:17
  4. Enable and Disable in Interrupts
    By stevecrunch in forum mel PIC BASIC Pro
    Last Post: - 30th October 2007, 01:10
  5. ENABLE command not always mandatory?
    Last Post: - 23rd October 2006, 18:11
