Code for thermostat with 18b20
Results 1 to 12 of 12
    Apr 2011
    Default Code for thermostat with 18b20
    How to insert a setup for another temperature example, Set Temp2 for the second relay in this code? Thankes
     tmp1    var byte
         tmp2    var byte
        Temperature    Var   Word      ' Temperature storage
        TempC         Var Word
        Float         Var Word
        TargetTemp      Var   Word      ' Desired Temperature
        Hyst         Var   Word      ' Hystereris
        V            Var   Word      ' Var. for display
        B1              Var Byte            ' Byte for TargetTemp calculation
        B2              Var Byte            ' Byte for TargetTemp calculation
        Count_Remain    Var Byte      ' Count remaining
        Count_Per_C    Var   Byte      ' Count per degree C
        Sign         Var   Byte      ' +/- sign
        Mode          Var   Byte      ' 0=Temp. display, 1=Set Temp, 2=Set Hysteresis
        Twist         Var Bit
        ' Resolution
        DS18B20_9bit     CON %00011111      ' 93.75ms, 0.5°C
        DS18B20_10bit    CON %00111111      ' 187.5ms, 0.25°C  <-- My favorite
        DS18B20_11bit    CON %01011111      ' 375ms,   0.125°C
        DS18B20_12bit    CON %01111111      ' 750ms,   0.0625°C  (default)
        DATA 46, 224, 20                        ' Temp MSB, TEMP LSB, Hysteresis DIV 10
        Mode=0                                  ' Temperature display mode
        Twist = 0
        PAUSE 500
        LCDOUT $FE, 1, $FE, $0C                 ' Clear display, cursor off
        PAUSE 250
    OWOUT DQ, 1, [$CC, $4E, 0, 0, DS18B20_10bit]    'Skip ROM search and write N_bits
                                                   '  resolution to scratch pad
    Read 0, B1                              ' Read TargetTemp MSB
    Read 1, B2                              ' Read TargetTemp LSB
    TargetTemp=B1*256+B2                    ' Calculate TargetTemp value (Default=20.0 C.)
    Read 2, B1                              ' Read Hysteresis
    Hyst=10*B1                              ' Calculate Hysteresis value (Default= 2.0 C.)
    MainLoop:
    If Mode_B=0 then                      ' Mode switch pressed
      Pause 50                              ' Debounce
      LcdOut $FE, $8F, "*"                  ' Show that command is accepted
      If Mode_B=0 then MainLoop            ' Wait until button is released
      Mode=Mode+1                           ' Increment mode
      If Mode=1 then                        ' Save Target Temperature (Mode1 -> Mode2)
       Write 0, TargetTemp / 256      ' TargetTemp MSB
       Write 1, TargetTemp MOD 256          ' TargetTemp LSB
      EndIf
      If Mode > 1 Then                      ' Save Hysteresis (Mode 2 -> Mode 0)
       Mode=0                     ' Only 0, 1, 2 are valid
       Write 2, Hyst / 10                   ' Divide Hyst value to fit in Byte
      EndIf
    EndIf
    If Mode =0 then                        ' Set Target Temperature
      LcdOut $FE, $80, "Set Temp.       "   ' Show function
       V=TargetTemp                          ' TargetTemp in V
      Gosub SelectSign                      ' Select +/blank/-
      Gosub DisplayTemp                     ' Display Target Temperature
      If (UP_B=0) Or (DOWN_B=0) then    ' Up or Down button pushed
       If DOWN_B=0 then                    ' Down button
        If TargetTemp > 7500 then           ' Not lower than -25 C. (10000-MinTemp * 100)
         TargetTemp=TargetTemp-25           ' Decrease temperuture with 0.25 C.
        EndIf
       EndIf
       If UP_B=0 then                    ' Up button
        If TargetTemp < 17500 then          ' Not higher than 75 C. (10000+MaxTemp * 100)
         TargetTemp=TargetTemp+25           ' Increase temperature with 0.25 C.
        EndIf
       EndIf
       GoSub SetTargetTemp                  ' Display TargetTemp and delay 0.25 Sec.
      EndIf
    EndIf
    If Mode=1 then                         ' Set Hysteresis
      LcdOut $FE, $80, "Hysteresys:     "   ' Show function
       Sign= " "                              ' No sign
      V= 10000+Hyst                         ' Set value for V
      Gosub DisplayTemp                     ' Display Hysteresis
      If (UP_B=0) Or (DOWN_B=0) then    ' Up or down button pushed
       Sign= " "                             ' No sign for Hysteresis
        If Hyst > 10 then Hyst=Hyst-10      ' Not less than 0.1 C.
       EndIf
        If Hyst < 1000 then Hyst=Hyst+10    ' Not more than 10.0 C.
       EndIf
       Pause 250                            ' Delay 0.25 Sec.
      EndIf
    EndIf
    if Mode > 0 then Mainloop              ' Setting TargetTemperature or Hysteresis
     goto mainloop                         ' Check again
            ' SUBROUTINES:
            SelectSign:
            If v = 10000 then                      ' Temperature = 0 C.
              Sign=" "             ' No sign
            Else
              If v < 10000 then                 ' <> 0
               Sign="-"            ' Temperature below 0 C.
              Else
               Sign="+"            ' Temperature above 0 C.
              EndIf
            EndIf
            DisplayTemp:
             If V >= 10000 then                     ' Above 0 C.
              Temperature=V-10000
             Else
              Temperature=10000-V                   ' Below 0 C.
             EndIf
             LcdOut $FE, $C0, Sign, DEC (Temperature / 100), ".", DEC2 Temperature, " ",223,"C "
            SetTargetTemp:
            V=TargetTemp
            Gosub SelectSign
            Gosub DisplayTemp
            Pause 250
    Oct 2009
    Default Re: Code for thermostat with 18b20
    Did you write the code, or is it cut and paste from some other example?
    You need to post more details, hardware config etc. - There are other examples of reading multiple DS18B20's, but the one I use has individual pins for each sensor, rather then individually addressed on the one bus wire, and uses a case statement in the selection process. I also use DT's 18B20 include file which makes working with these sensors a lot simpler
    SelectSensor:
      SELECT CASE Channel
        CASE 0 : @ DS1820_Select  _TempSensor1      ; Select the DS18x20 pin
        CASE 1 : @ DS1820_Select  _TempSensor2
        CASE 2 : @ DS1820_Select  _TempSensor3
        CASE 3 : @ DS1820_Select  _TempSensor4
      END SELECT
    Apr 2011
    Only one temp sensor (one input) and two relay output. In relation to one temp. sensor manage two different temperature settings. How to add another one setting in meny for temp set2?
    '* Universal thermostat -25/+75 C.  by R.T.G. van Steenis                  *
    '* Compiler : PicBasic Pro 2.45                                            *
    '* B0 = Mode switch in (In)            A0 = LCD Enable    (Out)            *
    '* B1 = + switch in    (In)            A1 = LCD RS        (Out)            *
    '* B2 = - switch in    (In)            A2 = "Warm" Output (Out)            *
    '* B3 = Not connected  (Out)           A3 = "Cold" Output (Out)            *
    '* B4 = LCD Bit 4      (Out)           A4 = DQ DS1820     (In)             *
    '* B5 = LCD Bit 5      (Out)                                               *
    '* B6 = LCD Bit 6      (Out)                                               *
    '* B7 = LCD Bit 7      (Out            PIC16F628 Code size = 1124 Words    *
    '* Oscillator XP (4 MHz.) - Power up timer enabled - MCR enable            *
    TRISA= %11110000                        ' RA0..3=Outputs RA4=Input
    TRISB= %00000111 			' RB0..RB2=Inputs, RB3..RB7=Outputs
    CMCON=7                                 ' Disable comparators
    DEFINE LCD_DREG PORTB                   ' LCD on port B
    DEFINE LCD_DBIT 4                       ' Data bits B4..B7
    DEFINE LCD_RSREG PORTA                  ' RS on PORTA
    DEFINE LCD_RSBIT 1                      ' RS on A1
    DEFINE LCD_EREG PORTA                   ' E on PORTA
    DEFINE LCD_EBIT 0                       ' E on A0
    DEFINE LCD_BITS 4                       ' LCD 4 bit mode
    DEFINE LCD_LINES 2                      ' 2 line LCD display
    DQ		Var	PORTA.4		' One-wire data pin
    PORTA.2=0                               ' Warm Output Low
    PORTA.3=0                               ' Cold Output Low
    MainLoop:
     If PORTB.0=0 then                      ' Mode switch pressed
      Pause 50                              ' Debounce
      If PORTB.0=0 then MainLoop            ' Wait until button is released
      If Mode=2 then                        ' Save Target Temperature (Mode1 -> Mode2)
      EndIf
      If Mode > 2 Then                      ' Save Hysteresis (Mode 2 -> Mode 0)
      EndIf
     EndIf
     If Mode =1 then                        ' Set Target Temperature
      LcdOut $FE, $80, "SET TEMPERATURE "   ' Show function
      If (PORTB.1=0) Or (PORTB.2=0) then    ' Up or Down button pushed
       If PORTB.2=0 then                    ' Down button
        EndIf
       EndIf
       If PORTB.1=0 then                    ' Up button
        EndIf
       EndIf
      EndIf
     EndIf
     If Mode=2 then                         ' Set Hysteresis
      LcdOut $FE, $80, "HYSTERESIS      "   ' Show function
      Sign=" "                              ' No sign
      If (PORTB.1=0) Or (PORTB.2=0) then    ' Up or down button pushed
       Sign=" "                             ' No sign for Hysteresis
       EndIf
       EndIf
      EndIf
     EndIf
     If Mode > 0 then Mainloop              ' Setting TargetTemperature or Hysteresis
     LcdOut $FE, $80, "TEMPERATURE     "    ' Show function
     Output DQ             			' Make Pin Output
     DQ=0					' OneWire line Low
     PauseUs 480                            ' Keep down for 480 µS
     Input DQ                               ' Make Pin Input
     PauseUs 70                             ' Wait 70 µS
     If DQ=1 then                           ' No presence pulse from DS1820
      LcdOut $FE, $1, "** No sensor! **"    ' Show message
      Pause 500                             ' Wait 0.5 Sec.
      Goto MainLoop                         ' Check again
     EndIf
     OWOut DQ, 1, [$CC, $44]       		' Start temperature conversion
    WaitLoop: OWIn DQ, 4, [Count_Remain]	' Check for still busy converting
     If Count_Remain = 0 Then WaitLoop      ' Busy
     OWOut DQ, 1, [$CC, $BE]		' Read the temperature
     OWIn DQ, 0, [Temperature.LowByte, Temperature.HighByte, Skip 4, Count_Remain, Count_Per_C]
     Temperature = (((Temperature >> 1) * 100) - 25) + (((Count_Per_C - Count_Remain) * 100) / Count_Per_C)
     if Temperature > 32767 then
      Temperature= ~Temperature
      V= 10000 - Temperature                ' 25 C=12500  0 C=10000  -10 C=9000
      V= 10000 + Temperature
     EndIf
     If V < TargetTemp - Hyst then          ' Below Target temperature - Hysteresis
      PORTA.2=1                             ' Activate   Warm Output
      PORTA.3=0                             ' Deactivate Cold Output
     EndIf
     If V > TargetTemp + Hyst then          ' Above Target temperature + Hysteresis
      PORTA.2=0                             ' Deactivate Warm output
      PORTA.3=1                             ' Activate   Cold Output
     EndIf
     GoSub SelectSign                       ' +/blank/- Sign
     GoSub DisplayTemp                      ' Temperature to LCD
    Goto MainLoop				' Do it forever
    ' SUBROUTINES:
    SelectSign:
      Sign=" " 				' No sign
     Else
      Else
      EndIf
     EndIf
    DisplayTemp:
      Temperature=V-10000
     Else
     EndIf
    SetTargetTemp:
     V=TargetTemp
     Gosub SelectSign
     Gosub DisplayTemp
     Pause 250
    that code is for ds18s20 it won't be right for a ds18b20 anyway
    Apr 2011
    my mistake, I accidentally wrote the title theme 18b20
    Apr 2011
    I need only how to add in code setting for another temperature
    Apr 2011
    anybody help me?
    Oct 2009
    [QUOTE=electron;132640]Only one temp sensor (one input) and two relay output. In relation to one temp. sensor manage two different temperature settings. How to add another one setting in meny for temp set2?
    So you have one sensor, but want two relays, each to trigger at different temperatures. Once you have defined another pin as an output then just use the "IF / THEN" statements:
    If temperature => targettemp1 then turn on relay 1
    If temperature => targettemp2 then turn on relay 2
    You'll do better if you have a go at writing your own code, and then post that up. People here will help, and the help is good, but don't expect folk to write you a program and hand it to you, at least not without being personally commissioned
    Oct 2009
    Just googled and found this which shouldn't take much to modify
    http://pic-microcontroller.com/one-w...-pro-compiler/
    Apr 2011
    OK, but how to this code
     clear
        DEFINE OSC 8                '8MHz << NOTICE UPPERCASE ON DEFINE
         'END of timer/oscillator defines
         OSCCON = %01110001          'Int CLK 8MHz
         ANSEL = %00000000           'All digital
         ANSELH = %00000000
         OPTION_REG.7 = 1            'Weak pull-ups enabled
        DEFINE  LCD_DREG    PORTC
        DEFINE  LCD_DBIT    4
        DEFINE  LCD_RSREG   PORTB
        DEFINE  LCD_RSBIT   1     'Register select pin
        DEFINE  LCD_EREG    PORTB
        DEFINE  LCD_EBIT    0     'Enable pin
        DEFINE  LCD_BITS    4     '4-bitni data bus
        DEFINE  LCD_LINES   2      'LCD
        DEFINE BUTTON_PAUSE 100
        'Pinout for EasyPic5
            DQ            Var   PORTA.0   ' One-wire data pin
            Mode_B         Var PORTC.2
            DOWN_B         Var PORTC.3
            UP_B           Var PORTC.0
            symbol UP=PORTC.0
            symbol SET=PORTC.1
            symbol MO=PORTC.2
            symbol DN=PORTC.3
            symbol STA=PORTA.5
            symbol STO=PORTA.4
            symbol SO=PORTA.2    '
            symbol GR=PORTB.3
            symbol DOZ=PORTB.4
            symbol VE=PORTB.5
        TRISA= %00111111
        TRISB= %00000000
        portb = %00000000
            ' Variables
             I var word
             J var word
             tmp1    var byte
             tmp2    var byte
            TempC         Var Word
            Float         Var Word
            Twist         Var Bit
            ' Resolution
            Twist = 0
            PAUSE 500
            PAUSE 250
            MainLoop:
              Pause 50                              ' Debounce
              EndIf
              EndIf
            EndIf
              LcdOut $FE, $80, "Set Temp1       "   ' Show function
                EndIf
               EndIf
                EndIf
               EndIf
              EndIf
            EndIf
               Sign= " "                              ' No sign
               EndIf
               EndIf
              EndIf
            EndIf
            ' SUBROUTINES:
            SelectSign:
              Sign=" "             ' No sign
            Else
              Else
              EndIf
            EndIf
            DisplayTemp:
              Temperature=V-10000
             Else
             EndIf
            SetTargetTemp:
            V=TargetTemp
            Gosub SelectSign
            Gosub DisplayTemp
            Pause 250
    add this
                EndIf
               EndIf
                EndIf
               EndIf
              EndIf
            EndIf
    but for Set temp 2
    What to modify?
    Oct 2009
    Can you actually explain what you want to do.
    Cutting and pasting code from the web doesn't help. Paste up YOUR code and let us see what it is you are trying to do.
    Oct 2009
  1. 18B20 and Multi_SPWM issue
    By Scampy in forum mel PIC BASIC Pro
    Last Post: - 9th May 2014, 16:41
  2. Help with 18b20 Stuck with busy bit
    By xapmanis in forum mel PIC BASIC Pro
    Last Post: - 9th October 2012, 14:52
  3. ds 18b20 circuit.
    By johnyp in forum mel PIC BASIC Pro
    Last Post: - 6th March 2010, 17:40
  4. 18B20 temperature sensor and PIC
    By boban in forum Schematics
    Last Post: - 4th June 2007, 13:51
  5. 18B20 Thermometer Question
    By Travin77 in forum mel PIC BASIC Pro
    Last Post: - 5th April 2006, 01:18
