Serial Comms and Crystals
Results 1 to 40 of 43
    Default Re: Serial Comms and Crystals
    pic 18F4580 has no timer6 try using tmr2 or rework the timer counts for timer3 with a 8:1 prescale
    Oct 2009
    Richard,
    need some additional help. The following code compiled, but displayed RH 0.0 and tmr 0 on the LCD. I changed the values for badread and noise as suggested, but still have the same result. As mentioned I'm using a 10 mhz crystal with HS_ppl enabled to run the pic at 40 Mhz. Could you point me in the right direction as to what I'm doing wrong ?
    ; config settings 18F4580, 10mhz crystal HSPPL
      __CONFIG    _CONFIG1H, _OSC_HSPLL_1H
      __CONFIG    _CONFIG2L, _PWRT_ON_2L
      __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
      __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    DEFINE  OSC 40
    ADCON1 = $0F
    clear
    INCLUDE "alldigital.pbp"
    CMCON = 7
    TRISA = %11001111
    DEFINE LCD_DREG  PORTB           ' LCD Data port
    DEFINE LCD_DBIT  0               ' starting Data bit (0 or 4)
    DEFINE LCD_EREG  PORTB           ' LCD Enable port
    DEFINE LCD_EBIT  5               '     Enable bit  (on EasyPIC 5 LCD)
    DEFINE LCD_RSREG PORTB           ' LCD Register Select port
    DEFINE LCD_RSBIT 4               '     Register Select bit   (on EasyPIC 5 LCD)
    DEFINE LCD_BITS  4               ' LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 4               ' number of lines on LCD
    DEFINE LCD_COMMANDUS 2000        ' Command delay time in us
    DEFINE LCD_DATAUS 50             ' Data delay time in us
    hum          = _dht+3
    tempa         = _dht+1
    T1CON = %00000001                               ; free-running, 1:1 prescaler
    dht_data var PORTA.1
    dht_dir var TRISA.1
    dht var byte[5]
    tempa var word EXT
    bits var byte
    crc   var byte
    hum  var word EXT
    gosub read_dht
    LCDOut $FE,$94,"rh ",#hum/10,".",dec1 hum//10
    pause 4000
    read_dht:
         for bits=4 to 0 step-1
           dht[bits]=0
         next
         tmr2=0
         dht_dir=0
         dht_data=0
         pauseus 1000                   'start it up
         dht_data=1
         pauseus 30
         dht_dir=1
         pauseus 40                    'wait till middle of response pulse window
         if ( dht_data)then goto badread   'no response then  give up
         while (!dht_data)
         wend
         t2con=6
         while ( dht_data)
         wend
         t2con=0
         if ((tmr2 <75)||(tmr2>85))then goto badread      ' confirm presence ?
         for  bits =39 to 0  step -1
             tmr2=0
             while (!dht_data)
             wend
             t2con=6
             while ( dht_data)
             wend
             t2con=0
             if ((tmr2>20)&&(tmr2<80)) then     ' noise ?
               if (tmr2 >50 ) then
                  dht.0[bits] =  1
              goto badread          ' noise ?
         next
         crc=0
         for bits=1 to 4
           crc=crc+ dht[bits]
         next
         if crc !=  dht[0] then goto badcrc    'crc
    badread:
    LCDOut $FE,$94 +8,"tmr6 ",#tmr2
           dht[bits]=0
        next
    badcrc:
    LCDOut $FE,$94 +16,hex dht[bits],","
        next
    you did not make the changes I suggested
    __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H
    DEFINE OSC 40
    ADCON1 = $0F
    clear
    CMCON = 7
    TRISA = %11001111
    hum = _dht+3
    tempa = _dht+1
    dht_dir var TRISA.1
    dht var byte[5]
    tempa var word EXT
    bits var byte
    crc var byte
    hum var word EXT
    gosub read_dht
    pause 4000
    read_dht:
    dht[bits]=0
    next
    tmr2=0
    dht_dir=0
    dht_data=0
    dht_data=1
    pauseus 30
    dht_dir=1
    while (!dht_data)
    wend
    t2con=6
    while ( dht_data)
    wend
    t2con=0
    if ((tmr2 <45)||(tmr2>55))then goto badread ' confirm presence ?
    tmr2=0
    while (!dht_data)
    wend
    t2con=6
    while ( dht_data)
    wend
    t2con=0
    if ((tmr2>12)&&(tmr2<50)) then ' noise ?
    if (tmr2 >31 ) then
    dht.0[bits] = 1
    next
    crc=0
    for bits=1 to 4
    crc=crc+ dht[bits]
    next
    badread:
    dht[bits]=0
    next
    badcrc:
    next
    if you don't have a oscilloscope or logic analyser add some more diagnostics to the program
     DEFINE OSC 40
     ADCON1 = $0F
     clear
     CMCON = 7
     TRISA = %11001111
     hum = _dht+3
     tempa = _dht+1
     dht_dir var TRISA.1
     dht var byte[5]
     tempa var word EXT
     bits var byte
     crc var byte
     hum var word EXT
     gosub read_dht
     pause 4000
     read_dht:
     dht[bits]=0
     next
     tmr2=0
     dht_dir=0
     dht_data=0
     dht_data=1
     pauseus 30
     dht_dir=1
     if ( dht_data)then goto badresponce 'no response then give up
     while (!dht_data)
     wend
     t2con=6
     while ( dht_data)
     wend
     t2con=0
     if ((tmr2 <45)||(tmr2>55))then goto badpresence ' confirm presence ?
     tmr2=0
     while (!dht_data)
     wend
     t2con=6
     while ( dht_data)
     wend
     t2con=0
     if (tmr2 >31 ) then
     dht.0[bits] = 1
     next
     crc=0
     for bits=1 to 4
     crc=crc+ dht[bits]
     next
     badread:
     LCDOut $FE,$94 +8,"tmr2 ",#tmr2
     next
     badcrc:
    pause 5000
     next
    badresponse:
     LCDOut $FE,$94 +8,"nr "
    badpresence:
     LCDOut $FE,$94 +8,"pr",#tmr2
    Oct 2009
    Quote Originally Posted by Scampy View Post
    Sorry Richard, I must of confused you by posting the code with the values in the original code.
    I'll take a look at your suggested code tomorrow and let you know - cheers for your help
    EDIT - loaded the code as is and the LCD displays rh 0.0 nr
    I assume that it's not getting a response from the sensor ? I have checked the connections and they appear correct (+ve to 5v, GND to ground, and signal to PORT A pin 1) this is connected via a header to the EasyPIC5 board with the 10K pull up resistors enabled (also tried without) I have a Hantek PC scope which I can use to test. I'm guessing I should see pin A1 going from high to low for the initial handshake between PIC and sensor ??
    expected dht response to start signal
    Oct 2009
    OK seems to of been a hardware issue. Replaced the sensor and now get a value on the lcd. The program is giving a reading of 870.4 - how would I turn this into a percentage
    Jan 2013
    Texas USA
    Just to get a sense of the raw data collected, perhaps you can change your "main" subroutine to the follow and post the results output on the LCD?
     gosub read_dht
     'LCDOut $FE,$94,"rh ",#hum/10,".",dec1 hum//10
     lcdout $FE, $94, hex2 dht(0), " ", hex2 dht(1), " ",hex2 dht(2), " ", hex2 dht(3), " ", hex2 dht(4)
     pause 4000
    TABSoft
  1. PC Serial comms
    By Bill Legge in forum Serial
    Last Post: - 14th December 2009, 00:37
  2. Simple Serial Comms.
    Last Post: - 23rd November 2007, 09:12
  3. Some comments on serial comms please.
    By muddy0409 in forum Schematics
    Last Post: - 15th June 2007, 10:53
  4. Serial Comms Buffer?
    Last Post: - 2nd December 2005, 02:29
  5. Serial comms / Bootloader
    Last Post: - 30th October 2005, 19:48
