Serial Comms and Crystals
Results 1 to 40 of 43
    Default Re: Serial Comms and Crystals
    Dec 2010
    You could use an HIH 4030. It outputs a voltage that you read with the ADC - as fast as you like.
    Oct 2009
    Thanks for the link. It states that it was for a 64mhz clock speed. Any idea what I need to change to make it run at 40 mhz ?
    this should be close
    if ((tmr6 <75)||(tmr6>85))then goto badread
    would become
    if ((tmr6 <45)||(tmr6>55))then goto badread
    and
    if ((tmr6>20)&&(tmr6<80)) then     ' noise ?
               if (tmr6 >50 ) then
    would become
     if ((tmr6>12)&&(tmr6<50 then     ' noise ?
               if (tmr6 >31 ) then
    Oct 2009
    Richard, thanks for the suggestions.
    I'm in the process of editing the code (to reflect the pins I'm using and that I don't have a serial LCD), and came up with an error, presumably as I'm using 2.60 version rather than PBP 3 related to tmr6 and t6con statements. Any ideas
    pic 18F4580 has no timer6 try using tmr2 or rework the timer counts for timer3 with a 8:1 prescale
    Oct 2009
    Richard,
    need some additional help. The following code compiled, but displayed RH 0.0 and tmr 0 on the LCD. I changed the values for badread and noise as suggested, but still have the same result. As mentioned I'm using a 10 mhz crystal with HS_ppl enabled to run the pic at 40 Mhz. Could you point me in the right direction as to what I'm doing wrong ?
    ; config settings 18F4580, 10mhz crystal HSPPL
      __CONFIG    _CONFIG1H, _OSC_HSPLL_1H
      __CONFIG    _CONFIG2L, _PWRT_ON_2L
      __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
      __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    DEFINE  OSC 40
    ADCON1 = $0F
    clear
    INCLUDE "alldigital.pbp"
    CMCON = 7
    TRISA = %11001111
    DEFINE LCD_DREG  PORTB           ' LCD Data port
    DEFINE LCD_DBIT  0               ' starting Data bit (0 or 4)
    DEFINE LCD_EREG  PORTB           ' LCD Enable port
    DEFINE LCD_EBIT  5               '     Enable bit  (on EasyPIC 5 LCD)
    DEFINE LCD_RSREG PORTB           ' LCD Register Select port
    DEFINE LCD_RSBIT 4               '     Register Select bit   (on EasyPIC 5 LCD)
    DEFINE LCD_BITS  4               ' LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 4               ' number of lines on LCD
    DEFINE LCD_COMMANDUS 2000        ' Command delay time in us
    DEFINE LCD_DATAUS 50             ' Data delay time in us
    hum          = _dht+3
    tempa         = _dht+1
    T1CON = %00000001                               ; free-running, 1:1 prescaler
    dht_data var PORTA.1
    dht_dir var TRISA.1
    dht var byte[5]
    tempa var word EXT
    bits var byte
    crc   var byte
    hum  var word EXT
    gosub read_dht
    LCDOut $FE,$94,"rh ",#hum/10,".",dec1 hum//10
    pause 4000
    read_dht:
         for bits=4 to 0 step-1
           dht[bits]=0
         next
         tmr2=0
         dht_dir=0
         dht_data=0
         pauseus 1000                   'start it up
         dht_data=1
         pauseus 30
         dht_dir=1
         pauseus 40                    'wait till middle of response pulse window
         if ( dht_data)then goto badread   'no response then  give up
         while (!dht_data)
         wend
         t2con=6
         while ( dht_data)
         wend
         t2con=0
         if ((tmr2 <75)||(tmr2>85))then goto badread      ' confirm presence ?
         for  bits =39 to 0  step -1
             tmr2=0
             while (!dht_data)
             wend
             t2con=6
             while ( dht_data)
             wend
             t2con=0
             if ((tmr2>20)&&(tmr2<80)) then     ' noise ?
               if (tmr2 >50 ) then
                  dht.0[bits] =  1
              goto badread          ' noise ?
         next
         crc=0
         for bits=1 to 4
           crc=crc+ dht[bits]
         next
         if crc !=  dht[0] then goto badcrc    'crc
    badread:
    LCDOut $FE,$94 +8,"tmr6 ",#tmr2
           dht[bits]=0
        next
    badcrc:
    LCDOut $FE,$94 +16,hex dht[bits],","
        next
    you did not make the changes I suggested
    __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H
    DEFINE OSC 40
    ADCON1 = $0F
    clear
    CMCON = 7
    TRISA = %11001111
    hum = _dht+3
    tempa = _dht+1
    dht_dir var TRISA.1
    dht var byte[5]
    tempa var word EXT
    bits var byte
    crc var byte
    hum var word EXT
    gosub read_dht
    pause 4000
    read_dht:
    dht[bits]=0
    next
    tmr2=0
    dht_dir=0
    dht_data=0
    dht_data=1
    pauseus 30
    dht_dir=1
    while (!dht_data)
    wend
    t2con=6
    while ( dht_data)
    wend
    t2con=0
    if ((tmr2 <45)||(tmr2>55))then goto badread ' confirm presence ?
    tmr2=0
    while (!dht_data)
    wend
    t2con=6
    while ( dht_data)
    wend
    t2con=0
    if ((tmr2>12)&&(tmr2<50)) then ' noise ?
    if (tmr2 >31 ) then
    dht.0[bits] = 1
    next
    crc=0
    for bits=1 to 4
    crc=crc+ dht[bits]
    next
    badread:
    dht[bits]=0
    next
    badcrc:
    next
  1. PC Serial comms
    By Bill Legge in forum Serial
    Last Post: - 13th December 2009, 23:37
  2. Simple Serial Comms.
    Last Post: - 23rd November 2007, 08:12
  3. Some comments on serial comms please.
    By muddy0409 in forum Schematics
    Last Post: - 15th June 2007, 09:53
  4. Serial Comms Buffer?
    Last Post: - 2nd December 2005, 01:29
  5. Serial comms / Bootloader
    Last Post: - 30th October 2005, 18:48
