What a Pain In The USB-utt
Results 1 to 20 of 20
    Default Re: What a Pain In The USB-utt
    Thanks to you, Dave and this thread I managed to get a HID keyboard using a 18F46J50. (On this nice little board).
    One thing I've been thinking about is how you could check that the device actually got enumerated (from the PIC that is) so you don't start sending stuff untill it is. The USB.txt file in the PBP folder says you should call USBService every ~250us untill USBDeviceState == CONFIGURED_STATE. I tried polling for that but needless to say it didn't compile.
    Looking a bit further it seems like those are an assembly variable/constant repectively so PBP wouldn't know they exist. I wonder if the EXT modifier is the place for this.....
    Anyway, thanks again for final push I needed!
    If PC is the Host, shouldn't the host ask the slave device to start sending data? So, maybe PIC should wait until a request is received.
    Nice boards Henrik. I think it is time to try USB again.
    Well, I don't know if that's actually what it does at the low level (ie within the USBSERVICE "command") but for a basic HID keyboard there's, to my knowledge, no "user readable" data (ie to be read with USBIN) sent from the PC to PIC.
    I can't test this at the moment but I think what I want is something like:
    USBDeviceState VAR BYTE EXT
    CONFIGURED_STATE CON EXT
    And then I should be able to do something like:
    ' Don't proceed until device enumerates
    WHILE USBDeviceState <> CONFIGURED_STATE
       USBService
    WEND
    Yeah the board is quite nice, pretty bare bones but a simple way to get up and running. - and it has the 32768Hz x-tal for the 46J50 on-board RTC. It took me a bit a longer than usual (like an hour and a half) to get the obligatory blink-a-led going, mostly due to not knowing how the Microchip HID bootloader was setup, then another hour or two to get the USB stuff going. Will probably order a couple more to add my growing collection of dev.boards.
    Sep 2008
    Here is some code in this link that looks like it will work for the USBDeviceState initialization.
    http://mac.mf3x3.com/A_PIC_PROGS/USB...SBDemo2_DT.txt
    Also, here is some information on the keyboard receiving information from the PC. The PC tells the keyboard when to turn on the NumLock, CapLock, and ScrollLock LED.
    http://www.picbasic.co.uk/forum/showthread.php?t=8925
    I've seen another thread where someone was able to demonstrate "stealing" information from a PC a few bits at a time using the NumLock, CapLock, and ScrollLock signals. The sensitive information was sent back through the keyboard device and recorded on a microcontroller USB board.
    Hi Phil,
    Thanks! That verifies my idea about interregoating the underlying statemachine - in fact exactly as I thought :-)
    Although there's some valid information in that other thread the tone and attidue in it reminds of why some members gets kicked off the forum....
  1. USB to USB flash Drive File Copier
    By surya089 in forum USB
    Last Post: - 16th December 2012, 02:22
  2. USB to USB flash Drive File Copier
    By emildownloads in forum General
    Last Post: - 27th October 2011, 02:23
  3. Start with USB and USB comands
    By SKOLS1 in forum mel PIC BASIC Pro
    Last Post: - 12th August 2011, 13:41
  4. usb to usb direct data transfer
    By sharath in forum USB
    Last Post: - 17th July 2011, 14:23
  5. USB PIC without USB Connection
    Last Post: - 26th December 2005, 18:39
