StartUSB board from MikroE
Results 1 to 11 of 11
    Jan 2008
    Default Re: StartUSB board from MikroE
    I only use the USB for loading the program. so I don´t care if the USB not working in my PBP program.
    EDIT.
    Maybe the bootloader don´t allows me to change Configs from my PBP program?
    I changed the DEFINE OSC 8 to DEFINE OSC 48 and now the pause times is OK and the Serin/Serout also works so I assume that I with this bootloader I can only run my PBP program at 48Mhz?
    Jun 2009
    Sc*nthorpe, UK
    You are dealing with a PLL chip read this post.
    http://www.picbasic.co.uk/forum/showthread.php?t=18498
    look at your config section and you will find the settings for pll.
    for more info search for pll and if you understand it you can possibly explain it to me.
    Obviously Henrik understands it! amongst others.
    The board is designed for USB applications, hence the need for 48MHz.
    It's "possible" the bootloader overrides the CONFIGs, just like we can with a programmer (never used bootloader).
    That's correct. It's the bootloader that contains the CONFIG. When you download your PBP program using the bootloader then the CONFIG contained in your "download" will not be used. Exactly how it works may differ from bootloader to bootloader but basically the CONFIG is part of the bootloader and the bootloader protects itself from being overwritten.
    Had you been allowed to change the CONFIG via the bootloader then you could possibly set it to such a state the bootloader, which of course is just another piece of code in the PIC, wouldn't run as intended and you end up with a bricked PIC needing to be reprogrammed with a device programmer.
    Jun 2009
    Sc*nthorpe, UK
    I always used a bootloader because I used Rentron boards and have I always wondered why others coded configs. Now I know! Thanks guys one less thing to think about.
  1. Moving from Basic Stamp and MIKROE basic to PicBasic PRO
    Last Post: - 6th March 2013, 06:27
  2. RF development board
    By Bruce in forum Adverts
    Last Post: - 26th January 2011, 21:57
  3. New an what to know what board is best to start
    By asdhillon86 in forum General
    Last Post: - 9th December 2010, 20:10
  4. Sd interface board
    By T_J_W in forum mel PIC BASIC Pro
    Last Post: - 15th August 2007, 13:00
  5. 5v and 7v on same board - question
    By mark.oswald in forum Schematics
    Last Post: - 29th July 2007, 00:03
