Firewall win, or programmed wrong ... the problem is me? (HSERIN-PC)
Results 1 to 12 of 12
    Aug 2012
    Comodoro Rivadavia - Patagonia Argentina
    Question Firewall win, or programmed wrong ... the problem is me? (HSERIN-PC)
    I'm playing with and I XSCADA problem arose when finished ... program it does not work ... Usually use software-controlled communication, but in this case, as I wanted to meet other microcontroller functions, preferably do control communication hardware ... It's where I start my problem that did not work and I read several topics and I could not take it forward to the project ....
    We split.
    This is the program I wrote for a PIC16F877A
    include "modedefs.bas"
    define osc 4
    ADCON1=000010
    TRISA=255
    TRISB=111111
    TRISC=000000
    OPTION_REG.7=0
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h ;"BRGH a 0 para 2400,-->20, para 9600 ponerlo a 24
    DEFINE HSER_BAUD 9600 ;"Velocidad de transmision 9600
    DEFINE LCD_DREG PORTD ;bit de datos del LCD empezando
    DEFINE LCD_BITS 4 ;en modo 4 bits
    DEFINE LCD_DBIT 4 ;por D.4, D.5, D.6 y D.7
    DEFINE LCD_RSREG PORTD ;bit de registro del LCD conectar
    DEFINE LCD_RSBIT 2 ;en el puerto D.2
    DEFINE LCD_EREG PORTD;bit de Enable conectar en el
    DEFINE LCD_EBIT 3 ;puerto D.3
    DEFINE LCD_LINES 2
    DEFINE    ADC_BITS    10
    DEFINE    ADC_CLOCK    3
    DEFINE    ADC_SAMPLEUS 50
    VOLT    VAR  WORD
    MV      VAR  BYTE
    MA      VAR BYTE
    HVD     var  word
    AMPER   var  word
    LECTURA VAR  WORD
    AUX_TX  var byte   ; NO SE USA
    AUX_TX1 VAR BYTE   ;PWM
    AUX_TX2 VAR BYTE   ;ADC
    AUX_TX3a VAR BYTE   ;ENTRADAS DIG
    AUX_TX3b VAR BYTE   ;ENTRADAS DIG
    AUX_TX3c VAR BYTE   ;ENTRADAS DIG
    AUX_TX3d VAR BYTE   ;ENTRADAS DIG
    AUX_TX4 VAR BYTE   ;SALIDAS DIG
    AUX_TX5 VAR BYTE   ;ESTADO PWM
    AUX_RX  var byte   ; NO SE USA
    AUX_RX1 VAR BYTE   ; NO SE USA
    AUX_RX2 VAR BYTE   ; NO SE USA
    AUX_RX3 VAR BYTE   ; NO SE USA
    AUX_RX4 VAR BYTE   ;ORDEN DEL SCADA
    tiempo  var byte
    bandera var byte
    x       var byte
    nivel   var byte
    PORTD=0
    VOLT=0
    PAUSE 100
    LCDOUT $FE,1
    arranque:
    ;INTCON = 000000         ' Habilita interrupciones
    INTCON.7 = 0        'apago interrupciones generales
    INTCON.6 = 0        'idem con perifericas
    INTCON.5 = 0        'idem con Int de TMR0
    ON INTERRUPT GoTo serialin ' Ante interrupcion ir a "serialin"
    ;PIE1.5 = 1                 ' Habilita interrupciones por USART
    PIE1 = 110000                                  'Enable interrupts
    nivel = 0
    INICIO:
           If PIR1.5 = 1 Then Goto serialin
           ;HSerIn [Dec AUX_RX]
           IF portc.4 = 0 THEN gosub sumarPWM1
           IF portc.5 = 0 THEN gosub restarPWM1
           IF portb.1 = 0 then
           AUX_TX3a = 11
           AUX_TX3a = 10
           if portb.2 = 0 then
           AUX_TX3b =21
           AUX_TX3b =20
           if portb.3 = 0 then
           AUX_TX3c =31
           AUX_TX3c =30
           if portb.4 = 0 then
           AUX_TX3d =41
           AUX_TX3d =40
           IF ADCON0.2= 1 THEN INICIO
           gosub lectura_ADC
           LCDOUT $FE,1
           LCDOUT $FE,$02,"V=",DEC VOLT,",",DEC1 MV," A=",DEC2 AMPER,",",DEC2 MA
           LCDOUT $FE,$C0,"pwm=",DEC tiempo
           AUX_TX5 = NIVEL
           AUX_TX4 = PORTD
           AUX_TX2 = AMPER
           AUX_TX1 = VOLT
           PWM PORTC.2,nivel,100
           pause 5
            HSEROUt ["[1;1;W;",dec AUX_TX1,13] ;envio adc volts
           HSEROUt ["1;1;W;",dec AUX_TX1,13] ;envio adc volts
           pause 5
           HSEROUt ["[","1","1","W",dec AUX_TX1,"]",13] ;envio adc volts
           HSEROUt ["[1;2;W;",AUX_TX2,13] ;envio adc amp
           pause 5
           HSEROUt ["[1;3;W;",AUX_TX3a,13] ;envio estado entradas digitales
           pause 5
           HSEROUt ["[1;3;W;",AUX_TX3b,13] ;envio estado entradas digitales
           pause 5
           HSEROUt ["[1;3;W;",AUX_TX3c,13] ;envio estado entradas digitales
           pause 5
           HSEROUt ["[1;3;W;",AUX_TX3d,13] ;envio estado entradas digitales
           pause 5
           HSEROUt ["[1;4;W;",AUX_TX4,13] ;envio estado salidas digitales
           pause 5
           HSEROUt ["[1;5;W;",AUX_TX5,13] ;envio estado PWM
           GOTO INICIO
    lectura_ADC:
           ADCIN 0,LECTURA
           HVD=((LECTURA+1)*/875)/10
           VOLT=HVD/10
           MV=(HVD)//10
           ADCIN 1,LECTURA
           HVD=(LECTURA+1)*/250
           AMPER=HVD/100
           MA=HVD//100
    sumarPWM1:
           if nivel => 255 then return
           nivel= nivel+5
    restarPWM1:
           if nivel => 1 then return
           nivel = nivel - 1
    DISABLE
    serialin:            ' Buffer the character received
    PIE1 = 000000                                  'Disable interrupts
    HSerIn [Dec AUX_RX, dec AUX_RX1, DEC AUX_RX2 , DEC AUX_RX3]
    Select case AUX_RX3
    case 1
    toggle PORTC.0
    case 2
    TOGGLE PORTC.2
    case 3
    TOGGLE PORTC.3
    case 4
    TOGGLE PORTC.4
    case 5
           if nivel => 255 then INICIO
           nivel= nivel+5
    CASE 6
           if nivel => 1 then INICIO
           nivel = nivel - 1
    END SELECT
    Resume
    The editor of scada, can handle multiple communication protocols.
    Ascii Protokol :
    Send String Via RS232
    [1;1;W;40] Format : [DeviceAdres;RegAdres;Write;Value]
    Receive String Via RS232
    [1;1;W;40] Format : [DeviceAdres;RegAdres;Read;Value]
    In my case, configure the different entries in different variables (addresses) to control the functions ... For example, to control the analog voltmeter and ammeter, select the Address List 1 and 2 ($ 1 - $ 2) ...
    I mean, from the pic would have to send
    [1,1, W, adc value Volts] and [1,2, W, Amp adc value].
    This same action, but with different addresses can complete them with the various functions of the software, but when run proteus and scada, and does not work in proteus rs-232 terminal, you see the error indicator ...
Size:  164.6 KB Name:  captura_2.JPG
    I help to find the problem that really do not understand?
    No if I firewall blocks port ...
    not if I am misusing HSERIN and HSEROUT ...
    or, is some small error
    Jun 2009
    Sc*nthorpe, UK
    Default Re: Firewall win, or programmed wrong ... the problem is me? (HSERIN-PC)
    This description
    is not the same as code
    should be
    HSEROUT [1,1,W,dec AUX_TX1,13] 'envio adc volts
    I think?
    SERIALIN interrupt subroutine has 1 RESUME and 2 RETURNs, not sure that will work as expected.
    PBP interrupts are "special". Darrel's interrupt routines are much more reliable and easy to use.
    Aug 2012
    Arrow Re: Firewall win, or programmed wrong ... the problem is me? (HSERIN-PC)
    hi thanks for replying ....
    Quote Originally Posted by EarlyBird2 View Post
    This description
    should be
    I think?
    changing those lines and did not work ... adding the probe in the "" W because that indicates if write or read and not have problems ... both to receive and send packets to the serial port ... .
    with serine and serout probe to see if it was a problem that the port is blocked and apparently, that's another mistake more than I have in this example.
    I'll investigate the issue of ports to get me doubt ...
    Robert, see, you could guide me in those breaks you mention?
    sorry for my spanglish
    Aug 2012
    Well! I found a problem and already almost solved ... this port is blocked, so use a virtual port for nesting
    but now I see communication by the hyper terminal, note that there is a speed problem, so I do not recognize the package and data ... this is the catch:
    test at a lower bauderate OR CHANGE PARITY? in this case as set HSERIN and HSEROUT to work at another speed? I think part of the problem here ... sure then continues with the theme of interruptions
    settings was 8n1 9600 for both applications
    Aug 2012
    ready .... one less problem ... I haven´t configured in the hyperterminal as reversed polarity
    now continue with the rest to see and understand that the package is not interpretedName:  solucion_1.PNG
    Aug 2012
    I struck me ... I'm locked ... I get angry that I can not take this issue forward ... I turned round and round and do not understand where is the error ... Copy and paste them as examples to work and backed away more , what progress, because now I understand much less than before the function HSERIN / HSEROUT ...
    Do you have a logic probe to see exactly what is transmitted?
    Edit: http://www.picbasic.co.uk/forum/showthread.php?t=18952
    Aug 2012
    Hello friend; It was first tested in a virtual version (Proteus + + Xscada Virtual Serial Port Driver).
    Xscaa brings a tool to read the data packet that enters and exits the ports ... you can write to them too.
    Just went up a video capture as I can write to the port to see ... now check the link you gave me to wake neurons also see ...
    Thanks for helping / bearings
    A simulation can only detect what it is programmed to detect.
    I'd love to afford one, but sometimes you have to build the real thing.
    Aug 2012
    You're right; Tonight I will go to the board and I do physical tests ... take them it with serine and serout and once it achieves communication, shall pass to HSERIN / OUT ... I did not find any complete example in SanGoogle which guide me.
    Tomorrow I commented as I was.
    Aug 2012
    I returned with news.
    Well, we can say that there were many things which would not let me make the project.
    On one hand, I had problems with the port of my PC, it crashes when more than one program wants to work with this.
    On the other hand, although I could not make it work with HSERIN-OUT, ​​accomplish it working with conventional serine and biggest mistake was in the way in which the variable sent ... In early attempts never included the "#". ..
    Serout PORTC.6, T9600, ["[1,1, W,", # VOLT, "]"]
    Another error in the first attempts, was the way in which the data expected. At first he was waiting at a specific point data and the program was obsolete (that is why I wanted to know how to use HSERIN-OUT, to do this to interrupt mode and keep the program running normal). The solution I found him, but only for short programs that do not have many instructions, is to use the following lines ...
    SERIN PORTC.7,10,["[1,3,W,"],DATO
    Interestingly, I can send a decimal variable and work it handles XSCADA to represent the analog graph.
    Here's a simpler than video achieved so far, as you can understand HSERIN-OUT, an article for the community http://www.picbasic.co.uk in the section where my other two articles arme next:
    http://www.picbasic.co.uk/forum/cont...=491-Sensor-02
    http://www.picbasic.co.uk/forum/cont...9-en-Espa%F1ol
  1. how to determine what programmed is in a PIC?
    By droptail in forum mel PIC BASIC Pro
    Last Post: - 4th June 2011, 17:55
  2. HSERIN/OUT Wrong
    By Kaldurenik in forum mel PIC BASIC Pro
    Last Post: - 8th October 2007, 11:40
  3. 18F4620 refuses to be re-programmed
    By MaxG in forum Off Topic
    Last Post: - 4th December 2006, 09:16
  4. Win Xp
    By PortlandJohn in forum mel PIC BASIC Pro
    Last Post: - 9th February 2005, 23:43
  5. win iPod
    By Ivasi in forum Off Topic
    Last Post: - 18th August 2004, 16:15
