Mini problem with DT_INTS-14
Results 1 to 8 of 8
    Default Mini problem with DT_INTS-14
    Using PIC Pro 3.0.7.1 - the MPASM at C:\Program Files\Microchip\MPASM Suite\MPASMWIN.exe is 5.51 supplied with MPLAB 8.92 (LST file reports 5.51) - OS Win7 Ult SP1 x32.
    I'm trying to compile code from thread http://www.picbasic.co.uk/forum/showthread.php?t=14232 post #24. Only change is to add wsave as directed by compiler
    INCLUDE "DT_INTS-14.bas"     ; Base Interrupt System
    wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
    The following errors are generated -
    Perhaps DT-INTS-14 is corrupt? I include the copy I downloaded today.
    Attachment 7178
    Any help appreciated
    George
    Last edited by Demon; - 18th December 2013 at 19:26. Reason: Fixed your CODE box :)
    Feb 2012
    PERTH AUSTRALIA
    Default Re: Mini problem with DT_INTS-14
    what chip you using
    Oh how dim of me, 16F268A.
    George
    Quote Originally Posted by towlerg View Post
    George
    16F628A maybe?
    Yes, whot he said. I'm either dyslectic or I really should stick to one finger typing.
    George
    You need to change the "wsave" part in the included file.
    Start here
    http://www.picbasic.co.uk/forum/show...3355#post93355
    and the following post has the answer.
    Thanks for all the responses, turns out I can't read either because I didn't add - INCLUDE "ReEnterPBP.bas".
    The two "errors" at OverCREATE and AfterUserRoutine disappear because of conditional assembly. I don't know macros (and the three R's) but they ain't right.
    George
    (edit period timed out)
    Also the example "Timer Template" seems very odd to me. There's a chunck of Basic between ASM....ENDASM which never gets executed - following the comment ;---[TMR1 reload - interrupt handler]-----------
    Oh, so much to learn and such a small brain to do it with.
    George
  1. USART TX Interrupt problem. (DT_INTS)
    By HenrikOlsson in forum mel PIC BASIC Pro
    Last Post: - 17th August 2011, 13:34
  2. Problem with DT_INTS-14.bas and PIC16F628A
    By CesarP in forum mel PIC BASIC Pro
    Last Post: - 9th August 2010, 06:31
  3. DT_INTS-18 - problem with INT0
    By AndrewC in forum mel PIC BASIC Pro
    Last Post: - 5th January 2010, 21:42
  4. mini speaker
    By Ron Marcus in forum Off Topic
    Last Post: - 5th March 2007, 00:43
  5. Problem with DT_Ints-14
    By BobSpencerr in forum mel PIC BASIC Pro
    Last Post: - 1st March 2007, 06:27
