Clock and Dual Termometer
Results 1 to 25 of 25
    Dec 2008
    Ploiesti, ROMANIA
    Default Clock and Dual Termometer
    Hi everyone !
    I try to build for my use , in home, one clock with dual termometer, using 16F628A, 2x16 LCD and 2 x DS18B20. I wrote the code, but... at every minute I have a few seconds more...I don't have a clue where it's the mistake. Can help me, please ? Thanks in advance !
    @ DEVICE pic16F628A, XT_osc, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_ON, LVP_OFF
    TRISA= %11111000                       ' RA0..3=Outputs RA4=Input
    TRISB= %00001111 			    ' RB0..RB2=Inputs, RB3..RB7=Outputs
    CMCON=7                                     ' Disable comparators
    OPTION_REG=%00000111
    DEFINE LCD_DREG PORTB               ' LCD on port B
    DEFINE LCD_DBIT 4                        ' Data bits B4..B7
    DEFINE LCD_RSREG PORTA            ' RS on PORTA
    DEFINE LCD_RSBIT 1                     ' RS on A1
    DEFINE LCD_EREG PORTA              ' E on PORTA
    DEFINE LCD_EBIT 0                       ' E on A0
    DEFINE LCD_BITS 4                      ' LCD 4 bit mode
    DEFINE LCD_LINES 2                     ' 2 line LCD display
    TempC           var     word
    Float           var     word
    Sign		    var	bit		   ' +/- sign
    DQ		    var     PORTA.4	   ' One-wire data pin
    TempC2          var     word
    Float2          var     word
    Sign2		    var	BIT		   ' +/- sign
    DQ2		    var     PORTA.3	   ' One-wire data pin
    Delay           var     byte
    Mode            var     byte
    semn		    var     word
    semn2           var     word
    DS18B20_1_12bit CON %01111111 	   ; 750ms,   0.0625°C  (default)
    DS18B20_2_12bit CON %01111111          ; 750ms,   0.0625°C  (default)
    Ticks		var	byte 	               ; Tick count (61 ticks=1 sec)
    Hour		var	byte 			   ; Hour variable
    Minute	var	byte 	               ; Minute variable
    Second	var	byte   	         ; Second variable
    ZIUA        var   byte
    LUNA        var   byte
    Disp		var	byte 	               ; Disp=1 to update display
    PAUSE 500 					   ; Wait 0.5sec for LCD to initialize
    Hour=0 : Minute=0 : Second=0
    Ticks=0  : ZIUA=01 : LUNA=01
    OPTION_REG=$05 				   ; Set prescaler
    ON INTERRUPT GOTO ISR			   ; ISR routine
    INTCON=$A0 					   ; Enable TMR
    LCDOUT $FE, 1 			         ; Clear LCD
    ' Init Sensor 1
     OWOUT DQ, 1, [$CC, $4E, 0, 0, DS18B20_1_12bit]
     OWOut DQ, 1, [$CC, $48]
     OWOut DQ, 1, [$CC, $B8]
     OWOut DQ, 1, [$CC, $BE]
     Pause 50
     OWIn DQ, 2, [TempC.byte0, TempC.byte1]
     Pause 50
    ' Init Sensor 2
     OWOUT DQ2, 1, [$CC, $4E, 0, 0, DS18B20_2_12bit]
     OWOut DQ2, 1, [$CC, $48]
     OWOut DQ2, 1, [$CC, $B8]
     OWOut DQ2, 1, [$CC, $BE]
     Pause 50
     OWIn DQ2, 2, [TempC2.byte0, TempC2.byte1]
     Pause 50
    LOOP:
    If PORTB.0=0 then                       ' Mode switch preSeconded
      	Pause 50                          ' Debounce
    	LcdOut $FE, 1
     	LcdOut $FE, $C0, "         SETTING"    ' Show that coMinuteand is accepted
    	PAUSE 500
     	LcdOut $FE, 1
    If PORTB.0=0 then Loop                  ' Wait until button is released
      Mode=Mode+1                           ' Increment mode
    If Mode=1 then                          ' SET HOUR
    LcdOut $FE, $80, dec2 Hour
    LcdOut $FE, $C0, "HOUR     SETTING"
    	if portb.1=0 then
          Hour=Hour+1
            IF Hour=24 then
              Hour=0
          Gosub Debounce
    	if portb.2=0 then
            IF Hour = 0 then
              Hour=24
          Hour=Hour-1
          Gosub Debounce
    EndIf
    If Mode=2 then                          ' SET MINUTES
    LcdOut $FE, $80, dec2 Hour,":",dec2 Minute
    LcdOut $FE, $C0, "MINUTES  SETTING"
    	if portb.1=0 then
          Second=0
          Minute=Minute+1
            IF Minute=60 THEN
              Minute=0
          Gosub Debounce
    	if portb.2=0 then
          Second=0
            IF Minute =<0 THEN
              Minute=60
          Minute=Minute-1
    	Gosub Debounce
    EndIf
    If Mode=3 then                          ' SET DAY
    LcdOut $FE, $80, dec2 Hour,":",dec2 Minute,":",dec2 Second,"   ",DEC2 ZIUA,"/"
    LcdOut $FE, $C0, "DAY      SETTING"
    	if portb.1=0 then
          ziua=ziua+1
                IF LUNA=2 THEN
                      IF ZIUA > 28 THEN
                      ZIUA=1
                IF LUNA=4 OR LUNA=6 OR LUNA=9 OR LUNA=11 THEN
                      IF ZIUA > 30 THEN ZIUA=1
                      IF ZIUA > 31 THEN ZIUA=1
          Gosub Debounce
    	if portb.2=0 then
          ZIUA=ZIUA-1
                IF ZIUA = 0 THEN ZIUA=31
          Gosub Debounce
    EndIf
    If Mode=4 then                           ' SET MONTH
    LcdOut $FE, $80, dec2 Hour,":",dec2 Minute,":",dec2 Second,"   ",DEC2 ZIUA,"/",DEC2 LUNA
    LcdOut $FE, $C0, "MONTH    SETTING"
    	if portb.1=0 then
          luna=luna+1
                if luna>12 then
                luna=1
          Gosub Debounce
    	if portb.2=0 then
          luna=luna-1
                if luna<1 then
                luna=12
          Gosub Debounce
    EndIf
    If Mode > 4 then
    	LCDOUT $FE, $C0, "END      SETTING"
    	PAUSE 1000
        LCDOUT $FE, 1, $FE, $0C
    	mode=0
    EndIf
    If Mode > 0 then Loop
    IF Disp=1 THEN
    LcdOut $FE, $80, DEC2 Hour, ":",DEC2 Minute, ":",DEC2 Second,"   ",DEC2 ZIUA,"/",DEC2 LUNA
    LCDOUT $FE, $C0, semn,DEC ABS TempC/100,".", DEC1 ABS TempC/10, 223,"C ", $FE, $C0 + 9, semn2,DEC ABS TempC2/100,".", DEC1 ABS TempC2/10, 223,"C   "
    Disp=0
    GOTO LOOP
    DISABLE
    ISR:
    Ticks=Ticks + 1
    IF Ticks < 61 THEN NoUpdate
    Ticks=0
    Second=Second + 1 		   ; Update second
    IF Second=60 THEN
    Second=0
    Minute=Minute + 1 		   ; Update Minute
    IF Minute=60 THEN
    Minute=0
    Hour=Hour + 1 			   ; Update Hour
    IF Hour=24 THEN
    Hour=0
    ZIUA=ZIUA+1
              IF LUNA=2 THEN
                   IF ZIUA > 28 THEN
                        ZIUA=1
                        LUNA=3
                   IF ZIUA > 30 THEN
                        ZIUA=1
                        LUNA=LUNA+1
              IF LUNA=1 OR LUNA=3 OR LUNA=5 OR LUNA=7 OR LUNA=8 OR LUNA=10  THEN
                   IF ZIUA > 31 THEN
                        ZIUA=1
                        LUNA=LUNA+1
      	    IF LUNA=12 THEN
                   IF ZIUA > 31 THEN
                        ZIUA=1
                        LUNA=1
    Disp=1 				   ; Set to update display
    Gosub Read_temp
    NoUpdate:
    INTCON.2=0 				   ; Re-enable TMR0 interrupts
    Resume
    ENABLE 				   ; Re-enable interrupts
    ;Subrutine
    Debounce:
    FOR Delay=1 To 200
    Pause 1 				   ; Delay 1ms inside a loop. This way,
    NEXT Delay 				   ; timer interrupts are not stopped
    Disp=1 				   ; Set display flag to 1
    Read_Temp:
        OWOut DQ, 1, [$CC, $44]
        Sign = TempC.15
        TempC = ABS(TempC)
        TempC = ((TempC >> 4)*100) + ((TempC & $F)*100 >> 4)
        IF Sign THEN TempC = -TempC
    IF TempC.15 THEN
    Semn="-"
    Semn="+"
        OWOut DQ2, 1, [$CC, $44]
        Sign2 = TempC2.15
        TempC2 = ABS(TempC2)
        TempC2 = ((TempC2 >> 4)*100) + ((TempC2 & $F)*100 >> 4)
        IF Sign2 THEN TempC2 = -TempC2
    IF TempC2.15 THEN
    Semn2="-"
    Semn2="+"
    END 					   ; End of program
    That is one of the problems with ON INTERRUPT. It does not interrupt until the main code gets a break. If, for example the code is in a PAUSE when the interrupt happens, the code will not go to the ISR until the PAUSE is complete.
    You will need to use ASM interrupts or DT's instant interrupts.
    Hi, Fratello
    Even using ON INTERRUPT ... you shouldn't have such a time error ... ( just display " not so regularly " the correct HH:MM:SS )
    but maybe you could write the shortest as possible interrupt stubb, not jumping from here to there ...
    the problem looks to be your interrupt stubb is longer than the time between two Timer interrupts. ( 1/61 s ? - from your ISR calculations )
    Dec 2008
    Ploiesti, ROMANIA
    Ok, I think that my previous code it's wrong in his essence...so...
    I try another two version, based on codes from : Paul R. Borgmeier, PhD (see EZCLOCK1) and Mr.Bruce (see RENTRON.COM). Still not good precision ... Any ideeas ?
    @ DEVICE pic16F628A, XT_osc, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_ON, LVP_OFF, CPD_OFF, PROTECT_OFF     ' for PBP 2.4
    INCLUDE "AllDigital.pbp"
    INTCON=0
    HzTimer         Var     Word
    HH              Var     Byte
    MM              Var     Byte
    SS              Var     Byte
    ZIUA            VAR     BYTE
    LUNA            VAR     BYTE
    X       	    Var     Byte
    col             Var     Bit
    TempC           Var     Word
    Float           Var     Word
    Sign		    Var	BIT		   ' +/- sign
    DQ		    Var     PORTA.4	   ' One-wire data pin
    TempC2          Var     Word
    Float2          Var     Word
    Sign2		    Var	BIT		   ' +/- sign
    DQ2		    Var     PORTA.3	   ' One-wire data pin
    Delay           var     byte
    Mode            VAR     BYTE
    semn		    var word
    semn2           var word
    HzTimer = $7A12
    HH=00 : MM=00 : SS=00 : ZIUA=01 : LUNA=01 : col=0  : Mode=0
    Pause 500
    LCDOUT $FE, 1, $FE, $0C                 ' Clear display, cursor off
    Pause 100
    ' Init Sensor 1
     OWOut DQ, 1, [$CC, $48]       	    ' Start temperature conversion
     Pause 50
     Pause 50
    ' Init Sensor 2
     OWOut DQ2, 1, [$CC, $48]       	    ' Start temperature conversion
     Pause 50
     Pause 50
    OPTION_REG.7=1
    TMR0=0
    INTCON.2=0
    Pause 500
    Pause 250
    LCDOUT $FE, $80,  "  TERMO-CLOCK   "
    LcdOut $FE, $C0,  "By NICULESCU DAN"
    PAUSE 3000
    MainLoop:
     If PORTB.0=0 then                      ' Mode switch pressed
      Pause 50                              ' Debounce
    LcdOut $FE, 1
     LcdOut $FE, $C0, "         SETTING"    ' Show that command is accepted
    PAUSE 500
     LcdOut $FE, 1
    If PORTB.0=0 then MainLoop              ' Wait until button is released
    LcdOut $FE, $80, dec2 HH
    	if portb.1=0 then
          HH=HH+1
            IF HH=24 then
              HH=0
          Gosub Debounce
    	if portb.2=0 then
            IF HH = 0 then
              HH=24
          HH=HH-1
          Gosub Debounce
    EndIf
    LcdOut $FE, $80, dec2 HH,":",dec2 MM
    	if portb.1=0 then
          SS=0
          MM=MM+1
            IF MM=60 THEN
              MM=0
          Gosub Debounce
    	if portb.2=0 then
          SS=0
            IF MM =<0 THEN
              MM=60
          MM=MM-1
    	Gosub Debounce
    EndIf
    LcdOut $FE, $80, dec2 HH,":",dec2 MM,":",dec2 ss,"   ",DEC2 ZIUA,"/"
    	if portb.1=0 then
          ziua=ziua+1
                IF LUNA=2 THEN
                      IF ZIUA > 28 THEN
                      ZIUA=1
          Gosub Debounce
    	if portb.2=0 then
          ZIUA=ZIUA-1
          Gosub Debounce
    EndIf
    LcdOut $FE, $80, dec2 HH,":",dec2 MM,":",dec2 ss,"   ",DEC2 ZIUA,"/",DEC2 LUNA
    	if portb.1=0 then
          luna=luna+1
                if luna>12 then
                luna=1
          Gosub Debounce
    	if portb.2=0 then
          luna=luna-1
                if luna<1 then
                luna=12
          Gosub Debounce
    EndIf
    If Mode > 4 then
    	PAUSE 1000
    	mode=0
    EndIf
    If Mode > 0 then Mainloop
    Main :
    ClockLoop : IF INTCON.2=0 THEN ClockLoop
    INTCON.2=0
    if portb.0=0 then Gosub MainLoop
    HzTimer = HzTimer - $1000  'decrement timer
    IF HzTimer<$1000  THEN
        IF Col=1 THEN 'update time'
            SS=SS+1
            IF SS=60 THEN
                SS=0
                MM=MM+1
                IF MM=60 THEN
                    MM=0
                    HH=HH+1
                    IF HH=24 THEN
                        HH=0
                        ZIUA=ZIUA+1
                             IF LUNA=2 THEN
                                 IF ZIUA > 28 THEN
                                 ZIUA=1
                                 LUNA=3
                                    IF ZIUA > 30 THEN
                                    ZIUA=1
                                    LUNA=LUNA+1
                                    IF ZIUA > 31 THEN
                                    ZIUA=1
                                    LUNA=LUNA+1
    				 IF LUNA=12 THEN
                                    IF ZIUA > 31 THEN
                                    ZIUA=1
                                    LUNA=1
    '==================================== display time with :
    '==================================== display time without :
         LcdOut $FE, $80, dec2 HH,":",dec2 MM," ",dec2 ss,"   ",DEC2 ZIUA,"/",DEC2 LUNA
        Col=Col+1
        HzTimer=HzTimer+$7A12
      gosub ReadTemp
    goto Main
    ' SUBROUTINES:
    ReadTemp:
        Sign = TempC.15
        TempC = ABS(TempC)
    IF TempC.15 THEN
    Semn="-"
    Semn="+"
        Sign2 = TempC2.15
    IF TempC2.15 THEN
    Semn2="-"
    Semn2="+"
    Debounce :
    For Delay= 1 to 200
    Pause 1
    next Delay
    END       					     ' Of program
    and
    DEFINE OSC 4  				   ' using a 4MHz crystal
    DEFINE LCD_COMMANDUS 2000 ' Command delay time in us
    DEFINE LCD_DATAUS 50      ' Data delay time in us
    TempC           var     word
    Float           var     word
    TempC2          var     word
    Float2          var     word
    Delay           var     byte
    Mode            var     byte
    semn		    var     word
    semn2           var     word
    ' setup vars for clock
    Time    VAR BYTE   			  ' accumulates TMR2 to PR2 match counts
    Minutes VAR BYTE   			  ' minutes
    Hours   VAR BYTE   			  ' hours
    Seconds VAR BYTE
    Match   VAR PIR1.1 			  ' TMR2 to PR2 match interrupt flag bit
    CMCON = 7          			  ' disable comparators
    INTCON = 0         			  ' not using interupts. Just monitoring int flag bits
    Time = 0           			  ' clear TMR2 to PR2 match counter
    Hours = 00         			  ' set clock starting hour here
    Minutes = 00       			  ' set clock starting minutes here
    Seconds = 0
    PR2 = 249           			  ' 249 +1 extra cycle for TMR2 reset = 250*5*16*1uS=20mS
    Match = 0           			  ' clear match flag
    ' setup & start TMR2
    T2CON = %00100110   			  ' 1:5 postscale, 1:16 prescale, TMR2 on
       ' every 20mS the TMR2IF flag is set, and this routine is entered.
       ' Plenty of time to do other stuff.
       IF Match THEN           	 	 ' has TMR2 matched PR2? (should happen every 20mS)
          Match = 0           	 	 ' yes. clear TMR2 to PR2 match flag bit
          Time = Time + 1     	 	 ' increment 20mS count
          IF Time = 50 THEN   	 	 ' 50 x 20mS = 1 second
             Time = 0         	 	 ' show time in 1 second intervals
    LcdOut $FE, $80, DEC2 Hours, ":",DEC2 Minutes, ":",DEC2 Seconds,13,10
    Gosub readtemp
    	Seconds = Seconds + 1
          IF Seconds = 60 THEN     	 ' has 60 seconds passed?
             Seconds = 0
             Minutes = Minutes + 1 	 ' increment minute count
             IF Minutes = 60 THEN  	 ' have 60 minutes passed?
                Minutes = 0         	 ' yes. roll-over minutes 00
                Hours = Hours + 1  	 ' update hours
                IF Hours = 24 THEN Hours = 0 ' roll-over hours from 24 to 00
             ENDIF 			 	 ' end IF Minutes = 60
          ENDIF    			 	 ' end IF Seconds = 60
       ENDIF       			 	 ' end IF Match
       GOTO Main
    ReadTemp:
        Sign = TempC.15
        TempC = ABS(TempC)
    IF TempC.15 THEN
    Semn="-"
    Semn="+"
        Sign2 = TempC2.15
    IF TempC2.15 THEN
    Semn2="-"
    Semn2="+"
    Sorry for long post... It's a proof of hard ( useless ) work...
    Aug 2010
    Maryland, USA
    First thing I would try is take out the gosub readtemp. Just for testing purpose. Then report back, tell us exactly how it is not precision. is it losing 1 second per min. is it gaining 1? what is the output you are seeing?
    BTW, I am looking at the second program
    -Bert
    I have not tested it, but me thinks:
            INT_Handler   TMR0_INT,   int_handler,   ASM,  yes
    is a NO NO.
    Try using a unique name to name your handler.
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for support ! I changed the name, but...
    It compiles here. I renamed the interrupt handler to ISR (changed the label) and adjusted the DT-Ints declaration accordingly:
            INT_Handler   TMR0_INT,   ISR,   ASM,  yes
        INT_ENABLE  TMR0_INT     ; Enable Timer 0 Interrupts
    And
    ;  INTERRUPT HANDLER     (runs this code each timer0 interrupt)
    ISR
    I compiled it for a 16F628A for which I had to add
    INCLUDE DT_Ints-14.bas
    wsave VAR BYTE $70 SYSTEM
    wsave1 VAR BYTE $A0 SYSTEM
    wsave2 var BYTE $120 SYSTEM
    Make sure your compiling "from" the main source file and not from within the timp.pbp.txt file.
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for support ! Yes, in this way I compiled the code. Unfortunately the result are so strange ...the display show random numbers - quickly changed, the errors messages are without end
    Dec 2008
    Ploiesti, ROMANIA
    OK, now the code for clock works fine now.
    Let's return to my sheeps ...How can I put in "timp.pbp.txt" the code for reading the two DS18B20 ? The author say : "Add your own code here for your one second event". How can I make this ? I don't have a clue...
    INCLUDE "DT_INTS-14.bas"     ; Base Interrupt System
            INT_HANDLER  TMR0_INT,  PISR,   ASM,  yes
        INT_CREATE               	; Creates the interrupt processor
        INT_ENABLE  TMR0_INT     	; Enable Timer 1 Interrupts
           OPTION_REG = %00001000	' Set TMR0 configuration
           INTCON = %10100000	' Enable TMR0 interrupts
    		bres_hi	VAR	BYTE bank0 system		' hi byte of our 24bit variable
    		bres_mid	VAR	BYTE bank0 system		; mid byte
    		bres_lo	VAR	BYTE bank0 system		; lo byte
    bres_hi = $0F
    bres_mid= $42
    bres_lo= $40
    		tick	VAR	BYTE bank0 system
    PISR			;
    	tstf bres_mid			  ; first test for mid==0
    	skpnz				        ; nz = no underflow needed
    	decf bres_hi,f			  ; z, so is underflow, so dec the msb
    	decfsz bres_mid,f		        ; dec the mid byte (subtract 256)
    	goto int_exit			  ; nz, so definitely not one second yet.
    	tstf bres_hi			  ; test hi for zero too
    	skpz					  ; z = both hi and mid are zero, is one second!
    	goto int_exit			  ; nz, so not one second yet.
    	movlw 0x0F			        ; get msb value
    	movwf bres_hi			  ; load in msb
    	movlw 0x42			        ; get mid value
    	movwf bres_mid			  ; load in mid
    	movlw 0x40			        ; lsb value to add
    	addwf bres_lo,f		        ; add it to the remainder already in lsb
    	skpnc				        ; nc = no overflow, so mid is still ok
    	incf bres_mid,f		        ; c, so lsb overflowed, so inc mid
    						  ; now we do the "event" that we do every one second.
    						  ; Note! for this example we toggle a led, which
    						  ; will give a flashing led which is on for a second
    						  ; and off for a second.
    						  ; Add your own code here for your one second event
    						  ; Note! My led is on porta,3
    						  ; your led may be on a different pin.
      movlw b'00000001'		        ; mask for bit 3
      xorwf tick,f			        ; toggle PORTA,bit3 (toggle the led)
    int_exit
    	INT_RETURN
