Hi every one
Thanks HenrikOlsson for your coments on this code. I worked on your coments and do some monifications, here is challenge I faced
(1) I declare my handler as PBP type when I compile the code gives the following error WARNING: Unable to open INCLUDE file REENTERPBP-14.BAS although I include that file in the compilation folder why is this error?
(2) I'm confusing why the program declared as ASM type having PBP statement and the Label does not have an underscore before it gives error while that declared as ASM type having PBP statement and the Label have an underscore before it gives gives NO error.But accorgni to Darrel PBP type label should have un underscore before it.
code
define OSC 4
Wsave var byte   $70system
Wsave1 var byte  $A0system
Wsave2 var byte  $120system
Wsave3 var byte  $1A0system
    'pointer for phase one in sinearray
                'pointer for phase two  in sine array
ADCON0 = %00000000
ADCON1 = %00000000
LED1   VAR  PORTB.1
TRISB = %11111101
TRISC = %11111001  'PMW output for CCP1 AND CCP2
TRISA = %11111111
PR2 =  199   'set for 5Khz HPWM
CCP1CON = %00001100 'set CCP1 for PWM OPERATION
CCP2CON = %00001100 'set CCP2 for PWM OPERATION
T2CON = %00000100  'TIMER2ON and prescale of 1:1
index var byte
temp var word
timerone var word
INCLUDE "DT_INTS-14.bas"     ; Base Interrupt System          emp
INCLUDE "ReEnterPBP-14.bas"
        INT_Handler   TMR1_INT,   _TEST,  PBP,  yes
T1CON = 000001                 ; Prescaler = 1;1, TMR1 ON
@   INT_ENABLE  TMR1_INT     ; Enable Timer 1 Interrupts
timerone = 64980 ;gives about 50 htz sine
       PAUSE 5
GOTO Main
TEST:
 T1CON = 000000 'stop the timer
    TMR1L = timerone.byte0  'reload the timer
    TMR1H = timerone.byte1
    T1CON = 000001          ' start the timer
    gosub display
    CCP1CON.4 = Temp.0 ' bit 0
    CCP1CON.5 = Temp.1 ' bit 1
    CCPR1L = Temp>>2  'Bit 2-7
    index=index+1
  if index =36 then index =0
 @    INT_RETURN
 display:
  lookup index,[115,102,90,79,70,62,57,53,52,53,57,62,70,79,90,102,115,128,141,154,166,177,186,194,199,203,204,203,199,194,186,177,166,154,141,128],temp
  return    'return to the subroutine
  return    'return to the original GOSUB
thankx
