USART Interrupt + Pause
Results 1 to 3 of 3
    Jun 2005
    Wisconsin
    Default USART Interrupt + Pause
    I know first hand that placing the Pause command in any code causes the interrupt service to not respond during the pause.
    The problem I have is in a number of places in my code I want to stop to do something for say 500ms. For example an LED would light for 500ms or a timeout in a sub would occur after 30 seconds.
    I'm left scratching my head on how to do this. Although pause is easy and works because this device is a node I want the host PC to be able to communicate with it whenever it wants.
    Am I expect too much? What would be a good approach?
    For immediate response to interrupts - use assembler interrupts.
    For BASIC interrupts with a faster interrupt response time, break down
    your pause times into smaller increments in a loop.
    Instead of PAUSE 500 ' <-- 500mS delay before interrupt service
    X VAR WORD
    FOR X = 1 to 20000 ' ~500mS total
    PAUSEUS 25 ' <-- 25uS delay before interrupt service
    NEXT X
    Just take into account that the time spent in your interrupt handler will add
    to the overall time delay in your loop if the interrupt happens while in a delay
    loop.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jun 2005
    Wisconsin
    I want to stay out of ASM as much as possible That is, after all, the reason I use PicBasic and not ASM.
    I had contemplated using shorter and more frequent Pause times. I will go that route. The actual times are not huge in this case, they just need to be close enough.
    Thanks Bruce!
  1. Old and beyond help ?
    By DavidFMarks in forum mel PIC BASIC Pro
    Last Post: - 11th December 2008, 16:23
  2. Replies: 11
    Last Post: - 12th July 2008, 03:36
  3. Fade out LEDs question
    By Sam in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2008, 11:50
  4. USART interrupt not interrupting right
    By Morpheus in forum mel PIC BASIC Pro
    Last Post: - 6th March 2005, 02:07
  5. Help Quick Need to make code smaller
    By Programmednew in forum mel PIC BASIC Pro
    Last Post: - 25th January 2005, 04:46
