I would have liked to delete thread #18 because that issue was resolved, I was missing some piece of code for MIBAM.
Anyways, I started off using Sayzer's code, then I was able to bypass the POT and make the LEDs scan automaticly.
I then added the MIBAM code (with no apparent difference) and I am still back to square one; I am not able to have about 20 LEDs on at the same time (or appear to be) to produce an effect similar as the video in thread #11
I am obviously not getting it and I would appreciate some guidance.
Below is the code I have so far, it is turning on then off LED1 to LED64 at the right speed but I am trying to turn on LED1, LED2...LED20 and from there when LED21 turns on the LED1 will turn off, LED22 on - LED2 off and so on.
Code:@ __config _CONFIG1, _HS_OSC & _WDT_OFF & _PWRTE_OFF & _BOREN_OFF & _LVP_OFF & _CP_OFF CLEAR DEFINE OSC 20 BAM_COUNT CON 8 INCLUDE "MIBAM.pbp" ;____[ For 12F/16F only - Interrupt Context save locations]_________________ wsave var byte $20 SYSTEM ' location for W if in bank0 ;wsave var byte $70 SYSTEM ' Alternate save location for W ' if using $70, comment out wsave1-3 ; Comment them out to fix the problem ---- ; -- The chip being used determines which variables are needed ------------- wsave1 VAR BYTE $A0 SYSTEM ' location for W if in bank1 wsave2 VAR BYTE $120 SYSTEM ' location for W if in bank2 wsave3 VAR BYTE $1A0 SYSTEM ' location for W if in bank3 ;---DO NOT change these----------------------------------------------------- ssave VAR BYTE BANK0 SYSTEM ' location for STATUS register psave VAR BYTE BANK0 SYSTEM ' location for PCLATH register DEFINE LCD_DREG PORTD DEFINE LCD_DBIT 0 DEFINE LCD_RSREG PORTD DEFINE LCD_RSBIT 5 DEFINE LCD_EREG PORTD DEFINE LCD_EBIT 4 DEFINE LCD_BITS 4 DEFINE LCD_LINES 2 DEFINE LCD_COMMANDUS 2000 DEFINE LCD_DATAUS 50 DEFINE ADC_BITS 8 ' Set number of bits in result DEFINE ADC_CLOCK 3 ' Set clock source (rc = 3) DEFINE ADC_SAMPLEUS 50 ' Set sampling time in microseconds CM1CON0 = 0 CM2CON0 = 0 pauseus 10 ADCON1 = 0 ADCON0 = 0 ' All analog, we just need RA0. TRISA = 255 ' PORTA all input. Others output. TRISB = 0 TRISC = 0 TRISD = 0 test var byte X var PORTB Y var PORTC x = 0 ; make sure all LEDs are off y = 0 ; when powr is applied I var byte Index var byte Index2 var byte OldVal var byte Pause 10 ASM BAM_LIST macro ; Define PIN's to use for BAM BAM_PIN (PORTB,0, X) ; and the associated Duty variables BAM_PIN (PORTB,1, X) BAM_PIN (PORTB,2, X) BAM_PIN (PORTB,3, X) BAM_PIN (PORTB,4, X) BAM_PIN (PORTB,5, X) BAM_PIN (PORTB,6, X) BAM_PIN (PORTB,7, X) endm BAM_INIT BAM_LIST ; Initialize the Pins ENDASM ' Mirror Image BAM module Begin: pause 500 ;lcdout $fe,1,"Matrix Test" ;PAUSE 500 X = 0 Y = 255 index = 0 oldval = 255 Start: ; adcin 0, index ' Index = max 255. for i = 0 to 255 index = i / 4 ' To get index values between 0 to 63. ;if oldval <> index then ' Act only when the number changes. index2 = index/8 ' X scans 8 bits. x = 0 ' turn it Off. x.0[index2] = 1 ' Set the bit in line. y = 255 ' turn all pins on (output is off). lookup index2,[7,15,23,31,39,47,55,63],index2 ' Get matrix line. y.0[index2-index] = 0 ' Clear the bit in line (output is on) ;lcdout $fe,$c0,dec3 index , " ",dec3 index2 ;pause 10 oldval = index ;endif pause 1 next i pause 100 goto start end
