Newbie PIC program design help
Results 1 to 12 of 12
    Dec 2011
    Default Newbie PIC program design help
    Hi there,
    I have a PIC12F675 and am trying to write a program in basic. What I have is a reed switch, which is attached to a door. When the door opens the reed switch closes. There is a continuous tone buzzer connected to the output of the micro. Now after a period of 10 seconds I want the micro to beep the buzzer approx 1 sec high 1.5 sec low continuously while the door is open. If the door is closed regardless of if the door alarm has been activated or not, it will end the program and return the micro back to sleep mode. The other part is I want a analogue input to monitor the battery voltage, when the battery voltage drops below 1V every time the door is opened the micro will make the buzzer emit a long 2 sec beep immediately after the door is opened until the battery have been changed, while maintaining the usual timing function of the door open. Can anyone help me out with that?
    Default Re: Newbie PIC program design help
    What part are you having trouble with? Have you written any code yet or is this still is the conceptual stage?
    Dec 2011
    What do you think of this?. I don't know how to use sleep and interrupt on change though.
    Your code in the PDF is not PicBasicPro. Sorry, I do not do JAL.
    Dec 2011
    Can you show me a PICBasic version?
    http://melabs.com/samples/PBP-mixed/onint.htm
    For a different chip.
    What version of PBP do you have?
    Dec 2011
    I haven't started the source code yet. I have kids and just can't get the time to learn the basic language. I have also been doing some reading on JAL, I know vbscript and find a lot of similarities, but I just can't find the time to put anything together yet, so yes it is still in the conceptual stage. Is my idea feasible though?. With the voltage monitoring, the input would need to be connected to its own vcc, is this ok directly or would it need to go through I diode do you think?
    Yes, it is doable. You may want to power the MCU with a DC to DC converter to have a constant voltage, then the actual battery voltage can be measured. Or set up a reference voltage with a divider.
    Dec 2011
    I think I will scratch the battery monitor idea. I'll just go with the basic timer in JAL I think.
