powering from 1.5v...
Results 1 to 10 of 10
    Sep 2006
    Default powering from 1.5v...
    Hello,
    Just wandering if anyone ever did a project that require powering from a single 1.5v battery like the one used in watches or wall clock.
    Just wandering how they manage to get the device working from 1.5v or do they use a boost converter to 5v. If so how is the boost converter made. I looked into my wrist watch and could not see any coil or obvious boost up converter of any kind..
    K
    Jan 2006
    Istanbul
    Default Re: powering from 1.5v...
    MAX1674, MAX1675, MAX1676 ; High-Efficiency, Low-Supply-Current, Compact, Step-Up DC-DC Converters
    http://www.maxim-ic.com/datasheet/index.mvp/id/1878
    http://circuitschematic.blogspot.com/2010/07/15v-to-5v-converter-circuit.html
    Why use an extra chip when you already have a pic?! Here's a rather ingenious way to run a controller off a single cell!
    http://spritesmods.com/?art=ucboost&page=2
    Hope it helps.
    Anand Dhuru
    Miami, Florida USA
    Quote Originally Posted by lerameur View Post
    Hello,
    K
    Do you want to use a coin cell battery? Why don't you use a 3.0 volts lithium coin cell battery?
    Anonymous
    Sep 2006
    I want to keep the price as low as possible. Lithium batteries are very expensive compared to round alkaline battery. but even at 3v, it does not leave much space for its lifespan , no ? when it falls just .5v then its game over.. i guess, I could be wrong.
    I have heard that Lithium batteries have a flat discharge. A coin cell may last longer a 3 volts than several alkaline at 1.5. The alkaline will start showing a voltage drop as soon as it is used.
    Miami, Florida USA
    Many chips minimum operating voltage is at 1.8V, so I don't see any problem. Check out this application note about the coin cell lifetime.
    http://www.maxim-ic.com/app-notes/index.mvp/id/505
    Anonymous
    Lithium batteries are very expensive compared to round alkaline battery. .
    Really? Here in my city a CR2032 costs about 20 cents US, and thats retail. The cheapest alkaline would be at least twice as much.
    Forget coin and costs. Here is the final solution:
    http://www.microchip.com/wwwproducts...cName=en548192
    http://www.microchip.com/wwwproducts...cName=en548193
    These chips will drain every mV from your battery untill is very very dead!
    Miami, Florida USA
    Dave,
    Thanks. That is good to know for future design reference. According to the app note that I mentioned above the discharge rate of these Lithium batteries is pretty flat.
    Anonymous
