problem with HMC6352 compass
Results 1 to 9 of 9
Threaded View
    Question problem with HMC6352 compass
    Hello,
    I tried to port this code from a BS2, to get it to work on a 16F877A. I am experiencing erratic
    behavior. The display flickers terribly and the values are meaingless. What am I missing?
               INCLUDE "Modedefs.Bas"
    @ Device pic16F877A, HS_OSC, LVP_OFF, WDT_OFF,protect_off
             DEFINE OSC 20
    ; Set port direction and turn off unused peripherals
            CMCON  = 7                      ' shut offcomparators
            TRISA = %00000000                ' Set PORTA to input "1" or output "0"
            TRISB = %00000000                ' set portB to output "0" or input "1"
            TRISC = %00000000
            TRISD = %00000000
            TRISE = %00000000
    ; initialize all ports to low
            portA = %00000000
            portB = %00000000
            portC = %00000000
            portD = %00000000
            portE = %00000000
    ; define LCD 4 line x 20, 4 bit interface
            Define  LCD_DREG  PORTD
            Define  LCD_DBIT  0
            Define  LCD_RSREG PORTD
            Define  LCD_RSBIT 4
            Define  LCD_EREG  PORTD
            Define  LCD_EBIT  5
            Define  LCD_BITS 4
            Define  LCD_LINES  4
            define  LCD_COMMANDUS   1500
            DEFINE  LCD_DATAUS   44
    'main2:
    '        Lcdout $fe, 1, $fe, $80   ' Clear LCD screen
    '        Lcdout $FE, $80, "testing"
    '        Pause 2000       ' Wait .5 second
    '        goto main2
    ' -----[ Pins/Constants/Variables ]-------------------------------------------
    SDA            VAR    portB.0                ' PB0 transceives to/from SDA
    SCL            VAR    portB.1                ' PB1 sends clock pulses
    HMC6352_READ   CON      $43                  ' HMC6352 read address
    HMC6352_WRITE  CON      $42                  ' HMC6352 write address
    GET_HEADING    CON      $41                  ' Read in the calculated heading
    START_CALIB    CON      $43                  ' Start the calibration routine
    END_CALIB      CON      $45                  ' Finish the calibration routine
    Heading        VAR      Word                 ' Heading read from compass
    I2C_DATA       VAR      Byte                 ' Temporary I2C variable
    I2C_LSB        VAR      Bit                  ' Temporary I2C variable
    ' -----[ Main Routine ]-------------------------------------------------------
    DO
      GOSUB Compass_Get_Heading                  ' Get angle
      ;DEBUG HOME, "Heading = ", DEC Heading / 10, " degrees" ' Print aingle
    Lcdout $FE, $80, "Heading = ", DEC Heading / 10, " deg"
    LOOP
    ' -----[ Subroutines ]--------------------------------------------------------
    Compass_Get_Heading:                         ' Compass module subroutine
      GOSUB I2C_Start                            ' Start communications on the I2C buss
      I2C_DATA = HMC6352_WRITE
      GOSUB I2C_Write                            ' Address the HMC6352 in write mode
      I2C_DATA = GET_HEADING
      GOSUB I2C_Write                            ' Send the get heading command
      GOSUB I2C_Stop                             ' End communications on the I2C buss
      I2C_DATA = HMC6352_READ
      GOSUB I2C_Write                            ' Address the HMC6352 in read mode
      PAUSE 6                                    ' Give the HMC6352 time to calculate the heading
      GOSUB I2C_Read
      Heading.HIGHBYTE = I2C_DATA                ' Read in the high byte
      GOSUB I2C_ACK
      GOSUB I2C_Read
      Heading.LOWBYTE = I2C_DATA                 ' Read in the low byte
      GOSUB I2C_NACK
    I2C_Start:
      LOW SDA                                    ' Pull SDA low
      LOW SCL                                    ' Pull SCL low
    I2C_Stop:
      INPUT SCL                                  ' Let SCL float high
      INPUT SDA                                  ' Let SDA float high
    I2C_ACK:
    I2C_NACK:
    I2C_Read:
      SHIFTIN SDA, SCL, MSBPRE, [I2C_DATA]       ' Read in 8 bits, MSB first
    I2C_Write:
      I2C_LSB = I2C_DATA.BIT0                    ' Store the status of the LSB
      I2C_DATA = I2C_DATA / 2
      SHIFTOUT SDA, SCL, MSBFIRST, [I2C_DATA\7]  ' Write out the first 7 bits, MSB first
      IF I2C_LSB THEN
        INPUT SDA
        LOW SDA     ' Write the 8th bit
      INPUT SCL                                  ' Using an open collector output
      LOW SCL
      INPUT SDA                                  ' Leave SDA as an input
      INPUT SCL                                  ' Ignore the ACK bit
      LOW SCL
    Last edited by ScaleRobotics; - 26th May 2010 at 18:06. Reason: code brackets added
