I2C Comm with Digital Compass HMC6352
Results 1 to 11 of 11
    Mar 2008
    Default I2C Comm with Digital Compass HMC6352
    This is my first post to the group.
    I'm designing a heading hold autopilot for a free flight glider. I'm basing it on a PIC16F88, and using an HMC6352 digital compass (http://www.sparkfun.com/datasheets/C...ts/HMC6352.pdf).
    I've never played with I2C before, and figured that I would try something simple first, like reading an EEPROM register in the compass module. My problem is that no matter what I do, I seem to always read back a value that is exactly 1/2 of what it should be.
    So then I tried writting a value to a RAM address and reading it back. Again, same issue, the value read back is 1/2 the value written.
    I'm using PIC BASIC PRO, on a LABX18 development board. Here's the code I'm using for the EEPROM read, which is modified from some of the example programs:
    Define  LCD_DREG        PORTA
    Define  LCD_DBIT        0
    Define  LCD_RSREG       PORTB
    Define  LCD_RSBIT       6
    Define  LCD_EREG        PORTB
    Define  LCD_EBIT        3
    ' Define I2C Interface
    SDA    Var    PORTB.1                    ' Data pin
    SCL    Var    PORTB.4                    ' Clock pin
    cmd  Var Byte
    addr Var Byte
    cont Var Byte
        ANSEL = 0                      ' PORTA is digital
        CMCON = 7                      ' PORTA is digital
        Pause 100                    ' Wait for LCD to start up
    loop1:
        pauseus 1000
        cmd = $72                    ' Read from compass EEPROM
        addr= $00                    ' EPROM address $00
        I2CWRITE SDA, SCL, $42, [cmd, addr], nowrite
        pauseus 1000
         I2CREAD SDA, SCL, $42, [cont], noread
        Lcdout $fe, 1, "Data: ", cont
        goto loop1
    nowrite:
        Lcdout $fe, 1, "Write Err"
        goto nowrite
    noread:
        Lcdout $fe, 1, "Read Err"
        goto noread
    If anyone can point me to the error of my ways, it would be greatly appreciated.
    John Ihlein
    Albuqueruqe, NM
    Last edited by ScaleRobotics; - 26th May 2010 at 18:07. Reason: code brackets added
    skimask's Avatar
    skimask Guest
    I'm fairly you don't have the I2C command syntax's correct.
    Double check the PBP manual and see what you come up with.
    Mar 2008
    Skimask,
    The manual shows the addr parameter as option. Since this isn't an EEPROM, and from looking at the HMC6352 data sheet, I figured that the commands should be sent as data arguements.
    I can try sending what I'm calling cmd as the address argument:
    becomes
    I2CWRITE, SDA, SCL, $42, cmd, [addr], nowrite
    later today. It does seem like my write commands are somewhat working, however. If I change the commands to write and read RAM rather than just read EEPROM, I can see the RAM data change with the read command, it's just off by 1/2.
    Looking at how the module responds to commands, I'm not sure how I would restructure the I2CREAD command. Maybe it needs a dummy addr argument??
    At the moment I can't tell if the issue is on the write or the read side, but since I've tried to read known values from EEPROM and they are off by 1/2, I tend to think the read side is where my problem lies. I'm wondering if it's a data type issue, although the documentation says the data will be transmitted in bytes.
    John
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by jihlein View Post
    Yep, I got that.
    But I still don't think they're right for what you want.
    And is the module getting the 70uSec delay it requires after requesting the data from the eeprom?
    Mar 2008
    Texas, USA
    Values that come in as 1/2 what they should have been shifted right one bit. You are loosing the LSB somewhere? I don't know the in's and out's of exactly what PBP does when shifting in I2C, but it might be that PBP is expecting one more bit. Does that compass send out 8 bits... or does it send out 7? Maybe it's sending out 9?
    Anywho, it's a byte shifted right... some where, some how.
    Does this from the datsheet have anything to do with your problem?
    "Negative binary values will be in two’s complement form"
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by JD123 View Post
    Or maybe...
    North 360 / 2 = 180 South ..... 1/2 the value
    Are those values always exactly 1/2? Or are they just close to 1/2...
    Mar 2008
    It sure does look like a byte shift. For reading EEPROM/RAM locations, I believe it is just sending back an 8 bit byte. If you choose to read raw magnetometer data rather than computed heading, that's where the 2's complement comes into play. I haven't got that far yet, and FWIW, plan to read computed heading. Thought it would be a good simple test to just try to read an write some simple values to the unit before trying to take measurements....
    The delay I put in is consdierbaly longer than the delays mentioned in the data sheet. From my understanding og the I2C protocol, the extra wait time should not be a factor. Whether or not it "bugs" the compass processing I can't see. Can reduce the wait time to the recommended 70 usecs and see if that changes anything.
    If else fails, I'll take it to work and watch the transaction on a digital storage scope and see what's occuring.
  1. I2C Master/Slave 16F88/16F767 working code
    By DanPBP in forum Code Examples
    Last Post: - 23rd October 2012, 23:31
  2. HARDWARE I2C SAMPLE CODE question
    By Michael Wakileh in forum Code Examples
    Last Post: - 16th June 2009, 22:07
  3. I2C Master Slave issues.
    By cpayne in forum mel PIC BASIC Pro
    Last Post: - 29th March 2008, 20:33
  4. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  5. Digital Compass Project
    By BJSmith in forum Serial
    Last Post: - 7th April 2006, 20:32
